//-----------------------------------------3DofDuino 0.01 - tonehack for gazz---------------------------------------
//-------------------------------Daniel Christiansen - X-Sim->Arduino mega Interface -------------------------------
//--------------------------------------daniel.christiansen@gmail.com ----------------------------------------------
//--------------------------------------------------USAGE-----------------------------------------------------------
// ##protocol##
// syntax:
// $<axis><value>#<checkvalue>*
// example:
// $X123#123*
// 1-axis example for x-sim2:
// ~36~X~a01~~35~~a01~~42~ // Axis in CAPITAL letters
// 3-axis example for x-sim2:
// ~36~X~a01~~35~~a01~~42~~36~Y~a02~~35~~a02~~42~~36~Z~a03~~35~~a03~~42~ // Axis in CAPITAL letters
// Use the USO output 16 bits - decimal - 115200 - 8 - NOPARITY - ONESTOPBIT
//--------------------------------------------Configuration---------------------------------------------------------
// ##Pin Assignment##
int rxOkLed = 32;
int rxNotOkLed = 33;
int ServoXPin = 7;
int ServoYPin = 8;
int tonePin = 9; //pin for rpmcounter
int servosMinValue = 0; // servos motion range minimum value
int servosMaxValue = 180; // servos motion range maximum value
unsigned int servoval = 90; // servos initial start point
#include <Servo.h>
Servo servoX;
Servo servoY;
Servo servoZ;
unsigned int charbuffer[50];
int bytesread = 0;
int serialchar;
int axis;
boolean packageRecieved = false;
boolean PackageVaild = false;
int packageLength;
void setup() {
Serial.begin(115200); // Connect to the serial port
pinMode(rxOkLed,OUTPUT); // Package verified led
pinMode(rxNotOkLed,OUTPUT); // Package Corrupt led
servoX.attach(ServoXPin);
servoY.attach(ServoYPin);
void loop () {
unsigned int axisValue;
unsigned int axisValueCheck;
if(Serial.available() > 0) {
serialchar = Serial.read();
// Serial.print("\nbyte: ");
// Serial.print(serialchar);
if (serialchar == 42){
packageRecieved = true;
packageLength = bytesread;
bytesread = 0;
// Serial.print("\nPackage recieved!!");
else {
if ((serialchar == 36) || (bytesread > 0) && (packageRecieved == false)) {
charbuffer[bytesread] = serialchar;
bytesread ++; // ready for next char
//Serial.print("\nbytesread: ");
//Serial.print(bytesread);
//Serial.print("\nbyte: ");
//Serial.print(serialchar);
digitalWrite(rxOkLed,LOW);
digitalWrite(rxNotOkLed,LOW);
if (packageRecieved == true){
int valueLength = (packageLength - 3) / 2;
int decMultiplier = 1;
axisValue = 0;
axisValueCheck= 0;
for (int i=valueLength; i > 0; i--){
axisValue = axisValue + ((charbuffer[i + 1 ] - 48) * decMultiplier);
axisValueCheck = axisValueCheck + ((charbuffer[i + valueLength + 2] - 48) * decMultiplier);
decMultiplier = decMultiplier * 10;
if (axisValue == axisValueCheck){
axis = charbuffer[1];
PackageVaild = true;
//Serial.print("\naxisValue: ");
//Serial.print(axisValue);
//Serial.print("\naxisValueCheck: ");
//Serial.print(axisValueCheck);
if (PackageVaild == true){
digitalWrite(rxOkLed,HIGH); // blink the OK led
switch (axis) {
case 88: //ascii for X
servoval = map(axisValue, 0, 65535, servosMinValue, servosMaxValue);
servoX.write(servoval);
break;
case 89: //ascii for Y
servoY.write(servoval);
break;
case 90://ascii for Z
servoval = map(axisValue, 0, 65535, 0, 433);
tone(tonePin,servoval);
else {
digitalWrite(rxNotOkLed,HIGH); //blink the Not OK led
packageRecieved = false; // were now done with this package - on to the next one
}/*** TMC - Tippett Motion Control
**** Timer 0B - PMW Motor 1
**** Timer 1 - PID Timer Run PID Calculations every PIDDELAY (Currently 2500 for every 10ms)
**** TO control Motors change OCR2B, OCR0B, OCR0A
#include <avr/io.h>
#include <stdio.h>
#include <stdlib.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include "pid.h"
#include "lcd.h"
#include <string.h>
#define NO_OF_POTS 3
#define NO_OF_AXIS 3
#define NO_OF_INPUTS (NO_OF_AXIS * 2)
#define potSensitivity 10
/* UART SERIAL DEFINES */
#define F_CPU 16000000UL
#define BAUD 9600
#define MYUBRR F_CPU/16/BAUD-1
#define PIDDELAY 2500
//Put in header file
void InitPIDTimer(void);
void ADC_Init(int preScaler, int tenBit);
//To Do. make these values editable via lcd and buttons
double K_P = 3;
double K_I = 35;
double K_D = 10;
//TO DO. DELETE THESE VARIABLES
volatile int desiredPosition;
volatile int actualPosition;
volatile uint8_t inputBuffer[NO_OF_INPUTS];
volatile uint8_t position;
struct Motors
uint16_t CurrentPosition;
uint16_t DesiredPosition;
struct PID_DATA PidData;
uint16_t PWMspeed;
} Motor1, Motor2, Motor3;
/* ADC METHODS */
// Initate ADC.
// Input prescaler amount, and 10bit or 8bit results
ADCSRA |= (1 << ADEN); //Enable ADC
//To Do. Set Different prescalers.
if (preScaler == 128)
ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); //set prescaler to 128
if (!tenBit)
ADMUX |= (1 << ADLAR); //Left adjust ADC result to allow easy 8 bit reading
ADMUX |= (1 << REFS0); //USE AVCC as refernece;
ADCSRA |= (1 << ADSC); //start first conversion
/* PWM Methods */
void PWM_init(void)
/* Init Timer 0A PORT D6 or PORT 6 on Arduino */
DDRD |= (1 << DDD6);
// PD6 is now an output
OCR0A = 100;
// set PWM for 50% duty cycle
TCCR0A |= (1 << COM0A1);
// set none-inverting mode
TCCR0A |= (1 << WGM00); //PWM Phase Corrected
TCCR0B |= (1 << CS00);
// set prescaler to 8 and starts PWM
/* Init Timer 0B PORT D5 or PORT 5 on Arduino */
DDRD |= (1 << DDD5);
OCR0B = 128; // set PWM for 50% duty cycle
TCCR0A |= (1 << COM0B1);
OCR0B = 128;
/* INIT Timer 2B Port D3 or 3 oon Arduino*/
DDRD |= (1 << DDD3);
OCR2B = 150;
TCCR2A |= (1 << COM2B1) | (1 << WGM20);
// set none-inverting mode & set PWM Phase correct Mode
TCCR2B |= (1 << CS21);
/* SERIAL METHODS */
/* SETUP UART */
void USART_Init( unsigned int ubrr)
/*Set baud rate */
UBRR0H = (unsigned char)(ubrr>>8);
UBRR0L = (unsigned char)ubrr;
/*Enable receiver and transmitter */
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
/* Set frame format: 8data, 1stop bit */
UCSR0C = (3<<UCSZ00);
/*Turn on Receive Complete Interrupt*/
UCSR0B |= (1 << RXCIE0);
position = -1;
void InitPIDTimer()
TCCR1B |= (1 << WGM12); // Configure timer 1 for CTC mode
TIMSK1 |= (1 << OCIE1A); // Enable CTC interrupt
TCCR1B |= ((1 << CS10) | (1 << CS11)); // Start timer at Fcpu/64
OCR1A = PIDDELAY;
void Init(void)
//Setup PID structs
pid_Init(K_P, K_I, K_D, &Motor1.PidData);
pid_Init(K_P, K_I, K_D, &Motor2.PidData);
pid_Init(K_P, K_I, K_D, &Motor3.PidData);
/* Init LCD */
lcd_init(LCD_DISP_ON);
/* Setup ADC */
//ADC_Init(128, 1);
/*Turn on ADC Interrupt */
ADCSRA |= (1 << ADIE);
//Turn on PORTB 12 to input
DDRB &= ~(1 << PINB4); //set input direction
lcd_clrscr();
lcd_puts("Init Okay");
int main(void)
PWM_init();
Init();
InitPIDTimer();
/* INITALISE SERIAL */
USART_Init(MYUBRR);
//turn on interrupts
sei();
int LCDCount = 0;
while (1)
if (LCDCount > 10000)
LCDCount = 0;
char Motor1String[7];
char Motor2String[7];
sprintf(Motor1String,"%u ", Motor1.DesiredPosition);
itoa(Motor1.PWMspeed, Motor2String, 10);
lcd_clrscr(); /* clear the screen*/
lcd_puts(Motor1String);
lcd_gotoxy(0,1);
lcd_puts(Motor2String);
Motor1.CurrentPosition += Motor1.PWMspeed;
Motor3.CurrentPosition += Motor3.PWMspeed;
LCDCount++;
/* INTERRUPTS */
//Timer 1A Interrupt
/*Every 10ms Calcualte the PWM value via pid_controller in pid.c*/
ISR(TIMER1_COMPA_vect)
Motor1.PWMspeed = pid_Controller(Motor1.DesiredPosition, Motor1.CurrentPosition, &Motor1.PidData);
Motor2.PWMspeed = pid_Controller(Motor2.DesiredPosition, Motor2.CurrentPosition, &Motor2.PidData);
Motor3.PWMspeed = pid_Controller(Motor3.DesiredPosition, Motor3.CurrentPosition, &Motor3.PidData);
//SERIAL INTERRUPT
ISR (USART_RX_vect)
int input = UDR0;
if (input == 'R')
position = 0;
else if ((input != 'E') && (position > -1))
if (position < NO_OF_INPUTS)
inputBuffer[position] = input;
position++;
else
//error; ignore and restart
position = -1;
else if (input == 'E')
if (position == 5)
/* Correct Packet Count Recevied. Commit Values */
Motor1.DesiredPosition = (inputBuffer[0] << 8) | inputBuffer[1];
Motor2.DesiredPosition = (inputBuffer[2] << 8) | inputBuffer[3];
Motor3.DesiredPosition = (inputBuffer[4] << 8) | inputBuffer[5];
position = -1;
//ADC INTERRUPT
ISR(ADC_vect)
switch (ADMUX)
case 0x40:
if ((Motor1.DesiredPosition > ADC + potSensitivity) || (Motor1.DesiredPosition < ADC - potSensitivity))
Motor1.DesiredPosition = ADC;
ADMUX = 0x41;
break;
case 0x41:
if ((Motor2.DesiredPosition > ADC + potSensitivity) || (Motor2.DesiredPosition < ADC - potSensitivity))
Motor2.DesiredPosition = ADC;
ADMUX = 0x42;
break;
case 0x42:
if ((Motor3.DesiredPosition > ADC + potSensitivity) || (Motor3.DesiredPosition < ADC - potSensitivity))
Motor3.DesiredPosition = ADC;
ADMUX = 0x40;
break;
ADCSRA |= (1 << ADSC); //next conversion
/*-----------------------------------------------3DofDuino 0.02-----------------------------------------------------
1) Modify The "Setup" Below. And define our outputs.
2) Configure X-Sim USO:
##protocol##
syntax:
$<value><axis><value><axis><value><axis>#
example:
$1234X4567Y89ABZ#
~36~~a01~Y~~35~ // Axis in CAPITAL letters
~36~~a01~Y~a02~X~a03~Z~35~ // Axis in CAPITAL letters
Use the USO output settings: 16 bits - HEX - 115200 - 8 - NOPARITY - ONESTOPBIT
//-----------------Includes---------------------
#include <Dans3dofServo.h> //should we only include this if we define servos?
#include <PID_v1.h> //likewise with pid
//--------------Servo Objects-------------------
Servo servo[6];//can we only create the amount we need? For now we create an array of six servos
//--------------PID Objects---------------------
const int numOfPids = 6;
int activePids = 0;
double pidInput[numOfPids];
double pidOutput[numOfPids];
double pidSetpoint[numOfPids];
// Adjust the P-I-D here - referrs to the order of definePwm
PID pid0(&pidInput[0], &pidOutput[0], &pidSetpoint[0],2,5,1, DIRECT);
PID pid1(&pidInput[1], &pidOutput[1], &pidSetpoint[1],2,5,1, DIRECT);
PID pid2(&pidInput[2], &pidOutput[2], &pidSetpoint[2],2,5,1, DIRECT);
PID pid3(&pidInput[3], &pidOutput[3], &pidSetpoint[3],2,5,1, DIRECT);
PID pid4(&pidInput[4], &pidOutput[4], &pidSetpoint[4],2,5,1, DIRECT);
PID pid5(&pidInput[5], &pidOutput[5], &pidSetpoint[5],2,5,1, DIRECT);
//------------Global variables-----------------
boolean debug;
boolean serialHeaderRecieved = false;
char inputString[50];
int numOfConfiguredOutputs = 0;
int numOfServos = 0;
int inputStringIndex=0;
unsigned int output[20][12];
//--------------Setup---------------------
//Change to match your setup
void setup() {
Serial.begin(115200); //set the serial rate
debug = false;
defineServo('X',9,0,255,32768);
definePwm('Y',45,0,1023,32768,50,51,0,52,20000);
/* Usage
Please declare the same number of axis as those configured in x-sim
defineServo('<axis from x-sim>',<pinnumber>,<rangeLow>,<rangeHigh>,<startpos>)
definepwm('<axis from x-sim>',<pwmOutputPin>,<rangeLow>,<rangeHigh>,<startpos>,<LimitSwLowPin>,<LimitSwHighPin><analog PID-feedbackPin><reversePin><pwm frequency)
Be aware that pins <44,45> <6,7,8> <2,3,5> are grouped together - changing the frequency for
one pin also changes the frequency for the other pins in that group.
<range> is the range of feedback for feedbackPin - typically 0-1023 for the analog input.
"Debug = true" prints a lot of stuff to the serial port -
Use serial monitor and send a corectly formatted package to see debugging messages
void loop() {
//--------------Serial stuff---------------------
if (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
if (inChar == '$'){ //if the new byte is our header
inputStringIndex=0; //start at the beginning of our char array
serialHeaderRecieved = true; //
if (debug)
Serial.println("\nHeader found.");
if (inChar == '#'){ //if the new byte is our trailer :)
serialHeaderRecieved = false; // be ready for the next package
// Serial.println("\nEnd of Package found.");
if (serialHeaderRecieved == true) { // only begin joining our package when we have recievede a start-of-package
if ((inChar >= 'A' && inChar <= 'F') || (inChar >= '0' && inChar <= '9')){ //we only want HEX digits in our inputstring
inputString[inputStringIndex]= inChar; //add the chars to inputstring one at a time as they arrive.
inputStringIndex ++;
if (debug){
Serial.print("\nHex Digit Found: ");
Serial.print(inputString[inputStringIndex -1]);
else { //this byte is not a valid HEX caracter - maybe its an axis..
int inCharAsInt = inChar; //convert from char to integer
for (int i=0; i < numOfConfiguredOutputs; ++i){ //search the output array for an axis matching our recieved byte
if (output[i][0] == inCharAsInt){
if (debug){
Serial.print("\nOutput Axis found: ");
Serial.print(output[i][0]);
inputString[inputStringIndex] = '\0'; //finish our char array
output[i][5] = strtol(inputString,NULL,16);
inputStringIndex=0;
if (debug){
Serial.print(" With DEC-value: ");
Serial.print(output[i][5],DEC);
//--------------Output stuff---------------------
for (int i=0; i <= numOfConfiguredOutputs; i++){ // run through our outputs,
switch(output[i][2]) {
case 1: // Pwm
pidSetpoint[output[i][6]] = map(output[i][5], 0, 65535, output[i][3], output[i][4]); // where we would like to be
pidInput[output[i][6]] = analogRead(output[i][9]); //where we are
pidHandler(output[i][6],'C', NULL); //compute the error offset
if (pidOutput[output[i][6]] > 0 && pidSetpoint[output[i][6]] > pidInput[output[i][6]])
digitalWrite(output[i][10],LOW); // set reverse pin low - we are going forward
analogWrite(output[i][1],pidOutput[output[i][6]]); //send the corrected value to pwm pin
else if(pidOutput[output[i][6]] < 0 && pidSetpoint[output[i][6]] < pidInput[output[i][6]])
digitalWrite(output[i][10],HIGH); // set reverse pin High - we are reversing
analogWrite(output[i][1],(-1 * pidOutput[output[i][6]])); //send the corrected value to pwm pin
else
analogWrite(output[i][1],0); //motor stopped
if (debug){
Serial.print("\n Input value : ");
Serial.print("\n scaling to match feedback : ");
Serial.print(pidSetpoint[output[i][6]],DEC);
Serial.print("\n feedback : ");
Serial.print(pidInput[output[i][6]],DEC);
Serial.print("\n pid correction : ");
Serial.print(pidOutput[output[i][6]],DEC);
break;
case 2: // Servo
unsigned int servoval = map(output[i][5], 0, 65535, output[i][3], output[i][4]); //scale it to match the specified motion range
if (servoval >= 0 && servoval < 256)
servo[output[i][6]].write(servoval);
break;
} // The END
//------------------Functions-----------------------
void pidHandler(int pidNum, int cmd, int pwmResolution){
switch (pidNum) {
case 0:
if (cmd == 'M'){
pid0.SetMode(AUTOMATIC);
pid0.SetOutputLimits((-1 * pwmResolution),pwmResolution);
if (cmd == 'C')
pid0.Compute();
break;
case 1:
if (cmd == 'M'){
pid1.SetMode(AUTOMATIC);
pid1.SetOutputLimits((-1 * pwmResolution),pwmResolution);
if (cmd == 'C')
pid1.Compute();
break;
case 2:
if (cmd == 'M'){
pid2.SetMode(AUTOMATIC);
pid2.SetOutputLimits((-1 * pwmResolution),pwmResolution);
if (cmd == 'C')
pid2.Compute();
break;
case 3:
if (cmd == 'M'){
pid3.SetMode(AUTOMATIC);
pid3.SetOutputLimits((-1 * pwmResolution),pwmResolution);
if (cmd == 'C')
pid3.Compute();
break;
case 4:
if (cmd == 'M'){
pid4.SetMode(AUTOMATIC);
pid4.SetOutputLimits((-1 * pwmResolution),pwmResolution);
if (cmd == 'C')
pid4.Compute();
break;
case 5:
if (cmd == 'M'){
pid5.SetMode(AUTOMATIC);
pid5.SetOutputLimits((-1 * pwmResolution),pwmResolution);
if (cmd == 'C')
pid5.Compute();
break;
void defineServo(int axis, int pinNum, unsigned int rangeLow, unsigned int rangeHigh, unsigned int startPos){
output[numOfConfiguredOutputs][0] = axis;
output[numOfConfiguredOutputs][1] = pinNum;
output[numOfConfiguredOutputs][2] = 2; //servo Type
output[numOfConfiguredOutputs][3] = rangeLow;
output[numOfConfiguredOutputs][4] = rangeHigh;
output[numOfConfiguredOutputs][5] = startPos; //is later value
output[numOfConfiguredOutputs][6] = numOfServos; //servo identifier
servo[numOfServos].attach(pinNum); //set the servo output pin
numOfConfiguredOutputs ++; //total number of outputs has increased by 1
numOfServos ++; //so has the total number of servos
if (debug){
Serial.print("\nServo ");
Serial.print(numOfServos);
Serial.print(" on pin ");
Serial.print(pinNum);
Serial.print(" attatched to axis: ");
char charAxis = axis;
Serial.print(charAxis);
void definePwm(int axis, int pinNum, unsigned int rangeLow, unsigned int rangeHigh, unsigned int startPos, int LimitSwLowPin, int LimitSwHighPin, int feedbackPin, int reversePin, int pwmFrequency){
output[numOfConfiguredOutputs][2] = 1; //PWM Type
output[numOfConfiguredOutputs][3] = rangeLow; //range start (Analog is at minimum 0) (quadcoder is at minimum 0)
output[numOfConfiguredOutputs][4] = rangeHigh; // range stop (analog is max 1023) (quadcoder can be at most 65535)
output[numOfConfiguredOutputs][5] = startPos; //will later be used as value
output[numOfConfiguredOutputs][6] = activePids; //our personal pid controller
output[numOfConfiguredOutputs][7] = LimitSwLowPin; //inputPin Used to signal end of travel LOW
output[numOfConfiguredOutputs][8] = LimitSwHighPin; //input Pin Used to signal end of travel High
output[numOfConfiguredOutputs][9] = feedbackPin; // analog input for positioning feedback
output[numOfConfiguredOutputs][10] = reversePin; //Pin Used to signal reverse
pinMode(output[numOfConfiguredOutputs][1], OUTPUT);
pinMode(output[numOfConfiguredOutputs][10], OUTPUT);
pinMode(output[numOfConfiguredOutputs][7], INPUT);
pinMode(output[numOfConfiguredOutputs][8], INPUT);
int Freq = pwmFreq(pwmFrequency,pinNum); //set frequency for pwm by manipulationg the correct timer -- returns the pwm resolution for this pin
pidHandler(activePids,'M',Freq); //set pid mode and activate current pid
activePids ++; //so has the total number of Pids
int pwmFreq(int desiredFreq, int pinNum) {
int regCounter = 8000000 / desiredFreq; //cpu freq div by 2 = 8000000 / desired frequency = pwm resolution
if (pinNum == 2 || pinNum == 3 || pinNum == 5){ //timer 3
TCCR3A = B00101001; // Phase and frequency correct PWM change at OCRA
TCCR3B = B10001; // System clock
OCR3A = regCounter; // this is now our pwm resolution
if (pinNum == 6 || pinNum == 7 || pinNum == 8){ //timer 4
TCCR4A = B00101001; // Phase and frequency correct PWM change at OCRA
TCCR4B = B10001; // System clock
OCR4A = regCounter; // this is now our pwm resolution
if (pinNum == 44 || pinNum == 45){ //timer 5 (I didn't know that was here :-) cool huh
TCCR5A = B00101001; // Phase and frequency correct PWM change at OCRA
TCCR5B = B10001; // System clock
OCR5A = regCounter; // this is now our pwm resolution
return regCounter; // we will need tihs to scale our output to the pwm resolution
rainman2002z wrote:Ok think im having dumb moment, testing a rig with adruino uno r3 and adafruit motor server, two servos .. Learning curve with code .. But seeing error writing to com port as soon as click start - servos start to twitch but have tried all different setups but still error.. Outside of xsim all works not issues
Anyone got any ideas ??
