How big the motor need?
Re: How big the motor need?
Postby shanothegreat » Fri 2. Nov 2012, 08:30
Have a look at these Motiondave http://www.motordrives.com.au/special_projects.asp
Check the right hand column under the picture titled "Movie Theater Chair Drives"
The motors are rated at 350 to 500 Watts and the gear ratios can be specified from 5:1 to 100:1
They are pricey at $380 per unit, but the specs and full metal hardened gears seem to offset this.
Shane
shanothegreat
Postby motiondave » Fri 2. Nov 2012, 11:10
shanothegreat wrote:Have a look at these Motiondave http://www.motordrives.com.au/special_projects.asp
Shane
Nice, they look like 240v units though.
Postby shanothegreat » Fri 2. Nov 2012, 14:58
I spoke to the guys there about the specs. The ones pictured are either supplied as 12 or 24 volt hence the 350-500 Watt range.
I'll post the link with respect to the cad drawings when I find the rest of my notes.
From what I've read these would be the next step up from the ones from motion dynamics.
The gear ratios range from 5:1 to 10:1 in 2.5 increments, then from 10:1 to 25:1 in 5 increments, then 30:1 to 80:1 in 10's then 100:1.
Taking into account the length of the lever arm, angular velocity and hence current draw, an optimum gear ratio should be available.
shanothegreat
Postby motiondave » Sun 21. Apr 2013, 02:01
If they are 350 to 500 watts, you will not be able to run them on a JRK. I tested a 350watt motor on jrks and I had to run them at 40 amps continuous, too hight for a JRK.
Use an AMC or arduino and h-bridges.
Postby futuresims » Sat 25. May 2013, 01:42
go to these two links,
viewtopic.php?f=38&t=909
viewtopic.php?f=38&t=910
You will be able to calculate every aspect of your new Motion Platform.
Thank you
futuresims
Been thanked: 7 times
Return to Motors
