Using scooter DC motors-question
Re: Using scooter DC motors-question
Postby speedy » Tue 16. Oct 2012, 05:43
Imagination in started :!: ... got an Idea :idea: ... then you may wonder ... how to test it :?: ... here you go ...
look at this ...
speedy
Has thanked: 14 times
Postby motiondave » Tue 16. Oct 2012, 13:58
interesting...
Postby speedy » Tue 16. Oct 2012, 14:44
want some more ...
speedy
Postby motiondave » Tue 16. Oct 2012, 14:48
are we going off tangent here?.......
Postby speedy » Tue 16. Oct 2012, 15:04
NO .. NO .. just for presenting test materials that are not expensive to be afraid to make errors with ...
OK .. I think my point is clear now ... motor selection as per given numbers aren't hard ... but to make that motor do the job, that's hard ...!!
regards
spe ;) edy
speedy
Postby motiondave » Wed 17. Oct 2012, 02:07
groovy....I can make gears from polished mahogany.... ;)
ummm...what were we talking about? :lol:
Postby dearn » Wed 17. Oct 2012, 08:59
Turn wrote:dearn - do you mean your scooter accelerated slowly, or you had a scooter motor on a bench unloaded and you found that it sped up slowly (because of inertia, etc.)? If it was the second scenerio, which motor did you have, and do you know its specs?
dearn wrote:I had recenly a electric scooter, this engine is powerfull but starts very slow. Like a router (starts slow then after 2 sec it's on full speed).
Unloaded it was speed up slowly. It was a e-scooter type like this:
It had 2 lead acid batterys 12 volt each with 14AH. The motor was a 250watt 24 volts running through a simple speed controller.
The specs i found on the internet:
- Model # MY1016
- Output: 250 Watts
- 24 VDC
- Rated current: 13.5 Amps
- Rated speed: 2650 RPM
- 4 holes on bottom bracket to mount to scooter
- 11 tooth gear for # 25 chain
- casing of the motor measures 3inches deep x 4 inches in diameter
- shaft is 1 inch long
This motor was a bit slow at the start and had not so much power, but after a few seconds, on full speed it has some power (and noise :lol: ). It could be that the speed controller reduced it's speed at the start.
dearn
Images: 139
Postby Turn » Wed 17. Oct 2012, 18:19
dearn - Thanks. Did you ever have the motor off the scooter on a bench, or were your tests only with it on the scooter? Also, did you ever try testing it without the speed controller?
Code: Select all
[quote="dearn"][quote="Turn"]dearn - do you mean your [u]scooter[/u] accelerated slowly, or you had a scooter motor on a bench unloaded and you found that it sped up slowly (because of inertia, etc.)? If it was the second scenerio, which motor did you have, and do you know its specs?
[quote="dearn"]I had recenly a electric scooter, this engine is powerfull but starts very slow. Like a router (starts slow then after 2 sec it's on full speed).[/quote][/quote]
[/quote]
Turn
Postby thecure » Wed 17. Oct 2012, 19:16
http://www.youtube.com/watch?v=Edsc_NUH ... e=youtu.be
i use for rotation , this motor http://shop.mat-con.net/epages/62158737 ... y1020_500w ...but the speed of rotation and very reduced :cry: ........goes much faster :twisted: :D ;)
thecure
Been thanked: 5 times
Postby Turn » Wed 17. Oct 2012, 19:24
Turn
Return to Motors
