DIY WRC Handbrake
DIY WRC Handbrake
Postby beeratis » Mon 1. Apr 2013, 22:18
It's about a diy usb vertical handbrake with gas spring 10kg that can be used both analog or digital depends on game.
I used an old Logitech attack 3 joystick that I don't using it anymore and disassembled it
1348
I cut the frame and kept the mounting holes like the pic
1349
I used plexiglass to lock one axis and also glued a micro switch (from attack 3 joystick) for analog axis
1350
The aluminum ready for paint ;)
1351
Assembling...
1352 1353
Small aluminum tube 1354 with fitted thread adapter for gear knobs 1355
and the result :)
1356
The rca cable will be connected to my g25 shifter (chilicoke modification)
1357
beeratis
Re: DIY WRC Handbrake
Postby prodigy » Mon 1. Apr 2013, 22:40
Really nice!
It doesn't look that hard to built, I have several unused gamepads at home, also with analog sticks which I can use for this.
What does rca cable do while connected to g25?
Postby motiondave » Mon 1. Apr 2013, 23:48
I used an old game pad, pulled apart then wired 2 buttons to my DIY shifter, and then used the existing USB cable.
The RCA cable , I suspect, I as plug to connect to his G25 so he can use some buttons on that, save having to use a new cable.
Postby lucaschr » Tue 2. Apr 2013, 00:00
I have the same Joystick here and I already Disassembled it already, but I needed a little Idea how the handbrake gotta look. this one looks awesome. Thanks for the tutorial! :)
lucaschr
Postby Bankrival » Fri 2. Oct 2015, 10:27
I wish I had something like this at home, enjoy some good.
Bankrival
Return to Peripheral Projects
