SparksFun dual Moto Monster China Edition H-Bridge
Postby sirnoname » Fri 11. Jul 2014, 10:05
Hello builders,
I do here a quick handling tutorial for the Moto Monster board.
The fitting arduino firmware / software thread is located here:
Open Source Arduino Firmware X-PID with autodetection X-Sim plugin and graphical PID tuning
Insure you do use the moto monster branch of the firmware, do not use the standard X-PID firmware!
Technical datas:
- power amplifier to control 2 DC motors
- power rating at about 14 Amperes (big heatsinks required, plus fan), this means no motors with measured power above this value
- power (short) peak rating 30A
- PWM controlled input
- over current detection (not used in X-PID firmware)
- around 20€ at eBay from china (delivery around 4 weeks, use shops with over 10.000 transactions and paypal)
The Moto Monster is a SMD chip based controller board, controlling two DC motors (wiper motors), for the arduino UNO board of any revision. However some arduino boards have more pins than the moto monster have. Be carefull by connecting the board to such boards and have a look to the names of the pins on the arduino and the moto monster. The moto monster comes with the mounted board and some header pins. You have to solder yourself the header pins to the board. Because of some mechanical problems you should read the below hints to avoid electrical shorts. The cables are also not connected to the board. Insure you use thick cables because of the big power (30 Amperes). If you use small cables (that have not the diametre of the moto monster board holes, you get warm cables and the power to the motor can be limited or reduced. The cables MUST be as short as possible from battery to the moto monster shield, and from the moto monster to the engines. Do not combine USB cables and the power cables, they should be positioned away from each other. For higher power you should search for an optical/galvanic board to avoid power over the mass.
Only 14 Amperes are not much and the limit for DC wiper engines. A wiper engine takes about 2 Amperes only for moving without load. So the maximum power can be 12 Amperes at 12 Volts = 144 Watts. Around 150 Watts are recommended as minimum for a 2DOF wiper simulator where only the racing chair is moving. You must use a multimeter and check your DC motor connected to a battery before you connect it to the Moto Monster shield. Check the maximum amperes that can be reached with equal motor load. More amperes than two needs a bigger heatsink connected to the chips of the moto monster. The following heatsink are requiried for a test without load and a maximum of 2 amperes.
Soldering:
The following hint will increase the distance to the critical mechanical positions.
Moto Monster soldering
This is a preperation for a machanical short:
Be carefull with using this bridge. Because it has limited power you must assemble it without load, check the heatsink. Then assemble the DC motor to the simulator and check the heatsink again. After this you can try some minutes a ride but then check the heatsink again. Use a fan if it is getting hotter than 50°C, this means you cannot touch the heatsink anymore.
Firmware:
Code: Select all
   X-Sim PID - Moto Monster Edition Firmware
   Copyright (c) 2014 Martin Wiedenbauer, particial use is only allowed with a reference link to the x-sim.de project
   This firmware comes with a X-SIM GUI (Graphically User Interface = X-Sim Plugin) interface and easy setup interface to play around
   with PID values. It is designed for   users with less knowlege about programming and that want to simple upload and use the firmware.
   After loading this firmware to the arduino, the firmware is detected in the interface setup automatically on any USB port.
   Do not forget to clean the X-Sim Converter USO setup. If you have loaded another 3rd party firmware before, you might block the comport.
   Same for the X-Sim Extractor OBD2 setup, remove the Moto Monster arduino comport from the list.
   It comes with many additionally   features like brake, 360°, GUI for pot scaling, power disable options etc. to get all the X-Sim features.
   This program will control the Moto Monster Shield of Sparksfun, with a analogue pot feedback, compared to a serial target input value from X-Sim
   You can get this H-Bridge easy and cheap from eBay.
   Target is a Arduino UNO R3 but will work on all Arduino with Atmel 328.
   This means, Arduino nano, micro, Duemilanove and UNO are tested. The moto monster shield does mechanically only be plug'n'play with UNO and Duemilanove, else you must wire it.
   Arduinos with an FTDI serial chip need a change to lower baudrates of 9600 bit/s.
   Read the below code and comment or uncomment the needed baudrate option with a double slash (//).
   Help for wiring the Moto Monster Shield
   Motor Pins (on Moto Monster Shield)
   JP3 VCC - 12V from power supply
   JP3 GND - GND from power supply
   JP1 OUTA1 - connect to Motor A
   JP1 OUTB1 - connect to Motor A
   JP2 OUTA2 - connect to Motor B
   JP2 OUTB2 - connect to Motor B
   You may switch the two cables to the motor if you see that the feedback is not working (motor move in wrong direction).
   Instead of switch the motor cable you can of course switch the +5V and GND cable of the pot which do the same.
   If the motor control is working but you must change the direction, you have to simple switch pot and motor cables.
   Analog Pins, must be connected not to the Moto Monster Shield but to a feedback pot connected to the motor axis
   Pin A4 - input of feedback positioning from motor A, wire here the feedback pot middle pin
   Pin A5 - input of feedback positioning from motor B, wire here the feedback pot middle pin
            Other pot pins go to +5V and GND of arduino.
   Important:
   Do not wire a motor monster GND power supply pin with GND of arduino or the pot!
   Use a heatsink on the VNH2SP30 chips on the motor monster shield. Maybe a fan is additionally attached.
   Start with a low PWM frequency setup in the X-Sim GUI. The PWM setup is only for reducing hearable switching noise.
   Pin out setup of arduino for Moto Monster Shield of SparksFun (needed only for programming and understanding code)
   Pin  5 - PWMA - Speed for Motor 1.
   Pin  6 - PWMB - Speed for Motor 2.
   Pin  4 - INA1 - motor 2 turn
   Pin  7 - INA2 - motor 1 turn
   Pin  8 - INB1 - motor 1 turn
   Pin  9 - INB2 - motor 2 turn
   Pin A0 - ENA  - current status input (not used)
   Pin A1 - ENB  - current status input (not used)
   Pin A2 - CSA  - power sense analogue input for over current detection (not used)
   Pin A3 - CSB  -   power sense analogue input for over current detection (not used)
   As well 5v and GND pins tapped in to feed feedback pots too.
   Command input protocol   (always 5 bytes, beginning with 'X' character and ends with a XOR checksum)
   'X' 1 H L C            Set motor 1 position to High and Low value 0 to 1023
   'X' 2 H L C            Set motor 2 position to High and Low value 0 to 1023
   'X' 3 H L C            Set motor 1 P Proportional value to High and Low value
   'X' 4 H L C            Set motor 2 P Proportional value to High and Low value
   'X' 5 H L C            Set motor 1 I Integral value to High and Low value
   'X' 6 H L C            Set motor 2 I Integral value to High and Low value
   'X' 7 H L C            Set motor 1 D Derivative value to High and Low value
   'X' 8 H L C            Set motor 2 D Derivative value to High and Low value
   'X' 200 0 0 C         Send back over serial port both analogue feedback raw values
   'X' 201 0 0 C         Send back over serial port the current pid count
   'X' 202 0 0 C         Send back over serial port the firmware version (used for x-sim autodetection)
   'X' 203 M V C         Write EEPROM on address M (only 0 to 255 of 1024 Bytes of the EEPROM) with new value V
   'X' 204 M 0 C         Read EEPROM on memory address M (only 0 to 255 of 1024 Bytes of the EEPROM), send back over serial the value
   'X' 205 0 0 C         Clear EEPROM
   'X' 206 0 0 C         Reread the whole EEPRom and store settings into fitting variables
   'X' 207 0 0   C         Disable power on motor 1
   'X' 208 0 0   C         Disable power on motor 2
   'X' 209 0 0   C         Enable power on motor 1
   'X' 210 0 0   C         Enable power on motor 2
   'X' 211 0 0   C         Send all debug values
   EEPROM memory map
   00      empty eeprom detection, 111 if set, all other are indicator to set default
   01-02   minimum 1
   03-04   maximum 1
   05      dead zone 1
   06-07   minimum 2
   08-09   maximum 2
   10      dead zone 2
   11-12   P component of motor 1
   13-14   I component of motor 1
   15-16   D component of motor 1
   17-18   P component of motor 2
   19-20   I component of motor 2
   21-22   D component of motor 2
   23      pwm1 offset
   24      pwm2 offset
   25      pwm1 maximum
   26      pwm2 maximum
   27      pwm frequency divider (1,8,64)
#include <EEPROM.h>
//Some speed test switches for testers ;)
#define FASTADC  1 //Hack to speed up the arduino analogue read function, comment out with // to disable this hack
// defines for setting and clearing register bits
#ifndef cbi
   #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
   #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define LOWBYTE(v)   ((unsigned char) (v))                        //Read
#define HIGHBYTE(v)  ((unsigned char) (((unsigned int) (v)) >> 8))
#define BYTELOW(v)   (*(((unsigned char *) (&v) + 1)))               //Write
#define BYTEHIGH(v)  (*((unsigned char *) (&v)))
#define   GUARD_MOTOR_1_GAIN   100.0
#define   GUARD_MOTOR_2_GAIN   100.0
//Firmware version info
int firmaware_version_mayor=2;
int firmware_version_minor =0;
//360° option for flight simulators
bool turn360motor1 = false;
bool turn360motor2 = false;
int virtualtarget1;
int virtualtarget2;
int currentanalogue1 = 0;
int currentanalogue2 = 0;
int target1=512;
int target2=512;
int low=0;
int high=0;
unsigned long hhigh=0;
unsigned long hlow=0;
unsigned long lhigh=0;
unsigned long llow=0;
int buffer=0;
int buffercount=-1;
int commandbuffer[5]={0};
unsigned long pidcount   = 0;      // unsigned 32bit, 0 to 4,294,967,295
byte errorcount   = 0;      // serial receive error detected by checksum
//Atmel chip port number for direct port manipulation
//http://arduino.cc/en/Hacking/PinMapping
#define ATMELA 0
#define ATMELB 1
#define ATMELC 2
#define ATMELD 3
#define ATMELE 4
#define ATMELF 5
//Structure for direct port manipulation data
struct mp
   int port;         //Atmel port, not Arduino
   int *portstatus;   //Pointer to current register value
   int pinnumber;      //Pinnumber of port at Atmel chip, not the arduino digital port!
   int arduino_pin;   //For I/O setup with arduino framework
// fixed DATA for direct port manipulation, exchange here each value if your h-Bridge is connected to another port pin
// This pinning overview is to avoid the slow pin switching of the arduino libraries
//            PC6  1|    |28  PC5 (AI 5)
//      (D 0) PD0  2|    |27  PC4 (AI 4)
//      (D 1) PD1  3|    |26  PC3 (AI 3)
//      (D 2) PD2  4|    |25  PC2 (AI 2)
// PWM+ (D 3) PD3  5|    |24  PC1 (AI 1)
//      (D 4) PD4  6|    |23  PC0 (AI 0)
//            VCC  7|    |22  GND
//            GND  8|    |21  AREF
//            PB6  9|    |20  AVCC
//            PB7 10|    |19  PB5 (D 13)
// PWM+ (D 5) PD5 11|    |18  PB4 (D 12)
// PWM+ (D 6) PD6 12|    |17  PB3 (D 11) PWM
//      (D 7) PD7 13|    |16  PB2 (D 10) PWM
//      (D 8) PB0 14|    |15  PB1 (D 9) PWM
int portdstatus            =PORTD;    // read the current port D bit mask
int portbstatus            =PORTB;    // read the current port B bit mask
//Fill the pin swaping for direct port manipulation
//Warning: using arduinos digitawrite() instead of using port manipulation will decrease the PID update rate and will heat up the H-BRIDGE because directions are both enabled
//Following structure: Atmel chip port name, pointer to portstatus variable for store old values, Atmel portpin, Arduino digital portpin for I/O setup
mp ControlPinM1Inp1   ={ATMELD,&portdstatus,7,7}; // motor A INP1 output, this is the atmel chip pin description, PortD7, InA1 Motor1 clockwise, Arduino Pin 7
mp ControlPinM1Inp2   ={ATMELB,&portbstatus,0,8}; // motor A INP2 output, this is the atmel chip pin description, PortB0, InB1 Motor1 counterclockwise, Arduino Pin 8
mp ControlPinM2Inp1   ={ATMELD,&portdstatus,4,4}; // motor B INP1 output, this is the atmel chip pin description, PortD4, InA2 Motor2 clockwise, Arduino Pin 4
mp ControlPinM2Inp2 ={ATMELB,&portbstatus,1,9}; // motor B INP2 output, this is the atmel chip pin description, PortB1, InB2 Motor2 counterclockwise, Arduino Pin 9
int PWMPinM1            =5;         // motor A PWM output
int PWMPinM2            =6;         // motor B PWM output
// Pot feedback inputs
int FeedbackPin1         = A4;      // select the input pin for the potentiometer 1, port PC4 on atmel chip
int FeedbackPin2         = A5;      // select the input pin for the potentiometer 2, port PC5 on atmel chip
int FeedbackMax1         = 1021;      // Maximum position of pot 1 to scale, do not use 1023 because it cannot control outside the pot range
int FeedbackMin1         = 2;      // Minimum position of pot 1 to scale, do not use 0 because it cannot control outside the pot range
int FeedbackMax2         = 1021;      // Maximum position of pot 2 to scale, do not use 1023 because it cannot control outside the pot range
int FeedbackMin2         = 2;      // Minimum position of pot 2 to scale, do not use 0 because it cannot control outside the pot range
int FeedbackPotDeadZone1   = 0;      // +/- of this value will not move the motor
int FeedbackPotDeadZone2   = 0;      // +/- of this value will not move the motor
// 360° Case detection border values
float quarter1            = 254.75;
float quarter2            = 254.75;
float threequarter1         = 764.25;
float threequarter2         = 764.25;
//PID variables
int motordirection1      = 0;         // motor A move direction 0=brake, 1=forward, 2=reverse
int motordirection2      = 0;         // motor B move direction 0=brake, 1=forward, 2=reverse
int oldmotordirection1   = 0;
int oldmotordirection2   = 0;
double K_motor_1      = 1;
double proportional1   = 4.200;      //initial value
double integral1      = 0.400;
double derivative1      = 0.400;
double K_motor_2      = 1;
double proportional2   = 4.200;
double integral2      = 0.400;
double derivative2      = 0.400;
int OutputM1               = 0;
int OutputM2               = 0;
double integrated_motor_1_error = 0;
double integrated_motor_2_error = 0;
float last_motor_1_error      = 0;
float last_motor_2_error      = 0;
int disable                  = 1; //Motor stop flag
int pwm1offset               = 50;
int pwm2offset               = 50;
int pwm1maximum               = 255;
int pwm2maximum               = 255;
float pwm1divider            = 0.8039;
float pwm2divider            = 0.8039;
float pwmfloat               = 0;
int pwmfrequencydivider         = 1; //31kHz
byte debugbyte =0;            //This values are for debug purpose and can be send via
int debuginteger =0;         //the SendDebug serial 211 command to the X-Sim plugin
double debugdouble =0;
void setPwmFrequency(int pin, int divisor)
   byte mode;
   if(pin == 5 || pin == 6 || pin == 9 || pin == 10)
      switch(divisor)
         case 1: mode = 0x01; break;
         case 8: mode = 0x02; break;
         case 64: mode = 0x03; break;
         case 256: mode = 0x04; break;
         case 1024: mode = 0x05; break;
         default: return;
      if(pin == 5 || pin == 6)
         TCCR0B = TCCR0B & 0b11111000 | mode;
      else
         TCCR1B = TCCR1B & 0b11111000 | mode;
   else
      if(pin == 3 || pin == 11)
         switch(divisor)
            case 32: mode = 0x03; break;
            case 64: mode = 0x04; break;
            case 128: mode = 0x05; break;
            case 256: mode = 0x06; break;
            case 1024: mode = 0x7; break;
            default: return;
         TCCR2B = TCCR2B & 0b11111000 | mode;
void setup()
   //Serial.begin(115200);   //Uncomment this for arduino UNO without ftdi serial chip
   Serial.begin(9600);  //Uncomment this for arduino nano, arduino with ftdi chip or arduino duemilanove
   portdstatus=PORTD;
   portbstatus=PORTB;
   pinMode(ControlPinM1Inp1.arduino_pin, OUTPUT);
   pinMode(ControlPinM1Inp2.arduino_pin, OUTPUT);
   pinMode(ControlPinM2Inp1.arduino_pin, OUTPUT);
   pinMode(ControlPinM2Inp2.arduino_pin, OUTPUT);
   pinMode(PWMPinM1,        OUTPUT);
   pinMode(PWMPinM2,        OUTPUT);
   analogWrite(PWMPinM1,     0);
   analogWrite(PWMPinM2,     0);
   UnsetMotor1Inp1();
   UnsetMotor1Inp2();
   UnsetMotor2Inp1();
   UnsetMotor2Inp2();
   disable=1;
   //TCCR1B = TCCR1B & 0b11111100; //This is a hack for changing the PWM frequency to a higher value, if removed it is 490Hz
   setPwmFrequency(PWMPinM1, 1);
   setPwmFrequency(PWMPinM2, 1);
#if FASTADC
   // set analogue prescale to 16
   sbi(ADCSRA,ADPS2) ;
   cbi(ADCSRA,ADPS1) ;
   cbi(ADCSRA,ADPS0) ;
#endif
void WriteEEPRomWord(int address, int intvalue)
   int low,high;
   high=intvalue/256;
   low=intvalue-(256*high);
   EEPROM.write(address,high);
   EEPROM.write(address+1,low);
int ReadEEPRomWord(int address)
   int low,high, returnvalue;
   high=EEPROM.read(address);
   low=EEPROM.read(address+1);
   returnvalue=(high*256)+low;
   return returnvalue;
void WriteEEProm()
   EEPROM.write(0,111);
   WriteEEPRomWord(1,FeedbackMin1);
   WriteEEPRomWord(3,FeedbackMax1);
   EEPROM.write(5,FeedbackPotDeadZone1);
   WriteEEPRomWord(6,FeedbackMin2);
   WriteEEPRomWord(8,FeedbackMax2);
   EEPROM.write(10,FeedbackPotDeadZone2);
   WriteEEPRomWord(11,int(proportional1*10.000));
   WriteEEPRomWord(13,int(integral1*10.000));
   WriteEEPRomWord(15,int(derivative1*10.000));
   WriteEEPRomWord(17,int(proportional2*10.000));
   WriteEEPRomWord(19,int(integral2*10.000));
   WriteEEPRomWord(21,int(derivative2*10.000));
   if(pwm1offset > 180 || pwm2offset > 180 || pwm1maximum < 200 || pwm2maximum < 200)
      pwm1offset=50;
      pwm2offset=50;
      pwm1maximum=255;
      pwm2maximum=255;
      pwm1divider=0.8039;
      pwm2divider=0.8039;
   EEPROM.write(23,pwm1offset);
   EEPROM.write(24,pwm2offset);
   EEPROM.write(25,pwm1maximum);
   EEPROM.write(26,pwm2maximum);
   if(pwmfrequencydivider != 1 && pwmfrequencydivider != 8)
      pwmfrequencydivider=1;
   EEPROM.write(27,pwmfrequencydivider);
void ReadEEProm()
   int evalue = EEPROM.read(0);
   if(evalue != 111) //EEProm was not set before, set default values
      WriteEEProm();
      return;
   FeedbackMin1=ReadEEPRomWord(1);
   FeedbackMax1=ReadEEPRomWord(3);
   FeedbackPotDeadZone1=EEPROM.read(5);
   FeedbackMin2=ReadEEPRomWord(6);
   FeedbackMax2=ReadEEPRomWord(8);
   FeedbackPotDeadZone2=EEPROM.read(10);
   proportional1=double(ReadEEPRomWord(11))/10.000;
   integral1=double(ReadEEPRomWord(13))/10.000;
   derivative1=double(ReadEEPRomWord(15))/10.000;
   proportional2=double(ReadEEPRomWord(17))/10.000;
   integral2=double(ReadEEPRomWord(19))/10.000;
   derivative2=double(ReadEEPRomWord(21))/10.000;
   pwm1offset=EEPROM.read(23);
   pwm2offset=EEPROM.read(24);
   pwm1maximum=EEPROM.read(25);
   pwm2maximum=EEPROM.read(26);
      pwm1offset=50;
      pwm2offset=50;
      pwm1maximum=255;
      pwm2maximum=255;
      pwm1divider=0.8039;
      pwm2divider=0.8039;
   else
      pwmfloat=float(pwm1maximum-pwm1offset);
      pwm1divider=pwmfloat/255.000;
      pwmfloat=float(pwm2maximum-pwm2offset);
      pwm2divider=pwmfloat/255.000;
   pwmfrequencydivider=EEPROM.read(27);
   quarter1=float(FeedbackMax1-FeedbackMin1)/4.000;
   quarter2=float(FeedbackMax2-FeedbackMin2)/4.000;
   threequarter1=quarter1*3.000;
   threequarter2=quarter1*3.000;
   setPwmFrequency(5, pwmfrequencydivider);
   setPwmFrequency(6, pwmfrequencydivider);
void SendAnalogueFeedback(int analogue1, int analogue2)
   high=analogue1/256;
   low=analogue1-(high*256);
   Serial.write('X');
   Serial.write(200);
   Serial.write(high);
   Serial.write(low);
   high=analogue2/256;
   low=analogue2-(high*256);
   Serial.write(high);
   Serial.write(low);
void SendPidCount()
   unsigned long value=pidcount;
   hhigh=value/16777216;
   value=value-(hhigh*16777216);
   hlow=value/65536;
   value=value-(hlow*65536);
   lhigh=value/256;
   llow=value-(lhigh*256);
   Serial.write('X');
   Serial.write(201);
   Serial.write(int(hhigh));
   Serial.write(int(hlow));
   Serial.write(int(lhigh));
   Serial.write(int(llow));
   Serial.write(errorcount);
void SendDebugValues()
   //The double is transformed into a integer * 10 !!!
   int doubletransfere=int(double(debugdouble*10.000));
   Serial.write('X');
   Serial.write(211);
   Serial.write(debugbyte);
   Serial.write(HIGHBYTE(debuginteger));
   Serial.write(LOWBYTE(debuginteger));
   Serial.write(HIGHBYTE(doubletransfere));
   Serial.write(LOWBYTE(doubletransfere));
void SendFirmwareVersion()
   Serial.write('X');
   Serial.write('-');
   Serial.write('P');
   Serial.write('I');
   Serial.write('D');
   Serial.write(' ');
   Serial.write(48+firmaware_version_mayor);
   Serial.write('.');
   Serial.write(48+firmware_version_minor);
void EEPromToSerial(int eeprom_address)
   int retvalue=EEPROM.read(eeprom_address);
   Serial.write('X');
   Serial.write(204);
   Serial.write(retvalue);
void ClearEEProm()
   for(int z=0; z < 1024; z++)
      EEPROM.write(z,255);
void ParseCommand()
   if(commandbuffer[0]==1)         //Set motor 1 position to High and Low value 0 to 1023
      target1=(commandbuffer[1]*256)+commandbuffer[2];
      disable=0;
      return;
   if(commandbuffer[0]==2)         //Set motor 2 position to High and Low value 0 to 1023
      target2=(commandbuffer[1]*256)+commandbuffer[2];
      disable=0;
      return;
   if(commandbuffer[0]==200)      //Send both analogue feedback raw values
      SendAnalogueFeedback(currentanalogue1, currentanalogue2);
      return;
   if(commandbuffer[0]==201)      //Send PID count
      SendPidCount();
      return;
   if(commandbuffer[0]==202)      //Send Firmware Version
      SendFirmwareVersion();
      return;
   if(commandbuffer[0]==203)      //Write EEPROM
      EEPROM.write(commandbuffer[1],uint8_t(commandbuffer[2]));
      return;
   if(commandbuffer[0]==204)      //Read EEPROM
      EEPromToSerial(commandbuffer[1]);
      return;
   if(commandbuffer[0]==205)      //Clear EEPROM
      ClearEEProm();
      return;
   if(commandbuffer[0]==206)      //Reread the whole EEPRom and store settings into fitting variables
      ReadEEProm();
      return;
   if(commandbuffer[0]==207 || commandbuffer[0]==208)      //Disable power on both motor
      UnsetMotor1Inp1();
      UnsetMotor1Inp2();
      UnsetMotor2Inp1();
      UnsetMotor2Inp2();
      disable=1;
      return;
   if(commandbuffer[0]==209 || commandbuffer[0]==210)      //Enable power on both motor
      analogWrite(PWMPinM1,     128);
      UnsetMotor1Inp1();
      UnsetMotor1Inp2();
      analogWrite(PWMPinM2,     128);
      UnsetMotor2Inp1();
      UnsetMotor2Inp2();
      disable=0;
      return;
   if(commandbuffer[0]==211)      //Send all debug values
      SendDebugValues();
      return;
void FeedbackPotWorker()
   currentanalogue1 = analogRead(FeedbackPin1);
   currentanalogue2 = analogRead(FeedbackPin2);
   //Notice: Minimum and maximum scaling calculation is done in the PC plugin with faster float support
bool CheckChecksum() //Atmel chips have a comport error rate of 2%, so we need here a checksum
   byte checksum=0;
   for(int z=0; z < 3; z++)
      byte val=commandbuffer[z];
      checksum ^= val;
   if(checksum==commandbuffer[3]){return true;}
   return false;
void SerialWorker()
   while(Serial.available())
      if(buffercount==-1)
         buffer = Serial.read();
         if(buffer != 'X'){buffercount=-1;}else{buffercount=0;}
      else
         commandbuffer[buffercount]=buffer;
         buffercount++;
         if(buffercount > 3)
            if(CheckChecksum()==true){ParseCommand();}else{errorcount++;}
            buffercount=-1;
void CalculateVirtualTarget()
   if(turn360motor1==true)
      virtualtarget1=target1;
      if(currentanalogue1 > int(threequarter1) && target1 < int(quarter1)){virtualtarget1+=FeedbackMax1;}
      else{if(currentanalogue1 < int(quarter1) && target1 > int(threequarter1)){virtualtarget1=0-FeedbackMax1-target1;}}
   else
   if(turn360motor2==true)
      virtualtarget2=target2;
      if(currentanalogue2 > int(threequarter2) && target2 < int(quarter2)){virtualtarget2+=FeedbackMax2;}
      else{if(currentanalogue2 < int(quarter2) && target2 > int(threequarter2)){virtualtarget2=0-FeedbackMax2-target2;}}
   else
void CalculateMotorDirection()
   if(virtualtarget1 > (currentanalogue1 + FeedbackPotDeadZone1) || virtualtarget1 < (currentanalogue1 - FeedbackPotDeadZone1))
      if (OutputM1 >= 0)
         motordirection1=1;            // drive motor 1 forward
      else
         motordirection1=2;            // drive motor 1 backward
         OutputM1 = abs(OutputM1);
   else
      motordirection1=0;
   if(virtualtarget2 > (currentanalogue2 + FeedbackPotDeadZone2) || virtualtarget2 < (currentanalogue2 - FeedbackPotDeadZone2))
      if (OutputM2 >= 0)
         motordirection2=1;            // drive motor 2 forward
      else
         motordirection2=2;            // drive motor 2 backward
         OutputM2 = abs(OutputM2);
   else
      motordirection2=0;
   OutputM1 = constrain(OutputM1, -255, 255);
   OutputM2 = constrain(OutputM2, -255, 255);
int updateMotor1Pid(int targetPosition, int currentPosition)
   float error = (float)targetPosition - (float)currentPosition;
   float pTerm_motor_R = proportional1 * error;
   integrated_motor_1_error += error;
   float iTerm_motor_R = integral1 * constrain(integrated_motor_1_error, -GUARD_MOTOR_1_GAIN, GUARD_MOTOR_1_GAIN);
   float dTerm_motor_R = derivative1 * (error - last_motor_1_error);
   last_motor_1_error = error;
   return constrain(K_motor_1*(pTerm_motor_R + iTerm_motor_R + dTerm_motor_R), -255, 255);
int updateMotor2Pid(int targetPosition, int currentPosition)
   float pTerm_motor_L = proportional2 * error;
   integrated_motor_2_error += error;
   float iTerm_motor_L = integral2 * constrain(integrated_motor_2_error, -GUARD_MOTOR_2_GAIN, GUARD_MOTOR_2_GAIN);
   float dTerm_motor_L = derivative2 * (error - last_motor_2_error);
   last_motor_2_error = error;
   return constrain(K_motor_2*(pTerm_motor_L + iTerm_motor_L + dTerm_motor_L), -255, 255);
void CalculatePID()
   OutputM1=updateMotor1Pid(virtualtarget1,currentanalogue1);
   OutputM2=updateMotor2Pid(virtualtarget2,currentanalogue2);
void SetPWM()
   //Calculate pwm offset and maximum
   pwmfloat=OutputM1;
   pwmfloat*=pwm1divider;
   pwmfloat+=float(pwm1offset);
   OutputM1=pwmfloat;
   if(OutputM1 > pwm1maximum){OutputM1=pwm1maximum;}
   pwmfloat=OutputM2;
   pwmfloat*=pwm2divider;
   pwmfloat+=float(pwm2offset);
   OutputM2=pwmfloat;
   if(OutputM2 > pwm2maximum){OutputM2=pwm2maximum;}
   //Set hardware pwm
   if(motordirection1 != 0)
      analogWrite(PWMPinM1, int(OutputM1));
   else
   if(motordirection2 != 0)
      analogWrite(PWMPinM2, int(OutputM2));
   else
//Direct port manipulation, change here your port code
void SetMotor1Inp1()
   *ControlPinM1Inp1.portstatus |= 1 << ControlPinM1Inp1.pinnumber;
   if(ControlPinM1Inp1.port==ATMELB){PORTB = *ControlPinM1Inp1.portstatus;}
   if(ControlPinM1Inp1.port==ATMELD){PORTD = *ControlPinM1Inp1.portstatus;}
void UnsetMotor1Inp1()
   *ControlPinM1Inp1.portstatus &= ~(1 << ControlPinM1Inp1.pinnumber);
void SetMotor1Inp2()
   *ControlPinM1Inp2.portstatus |= 1 << ControlPinM1Inp2.pinnumber;
   if(ControlPinM1Inp2.port==ATMELB){PORTB = *ControlPinM1Inp2.portstatus;}
   if(ControlPinM1Inp2.port==ATMELD){PORTD = *ControlPinM1Inp2.portstatus;}
void UnsetMotor1Inp2()
   *ControlPinM1Inp2.portstatus &= ~(1 << ControlPinM1Inp2.pinnumber);
void SetMotor2Inp1()
   *ControlPinM2Inp1.portstatus |= 1 << ControlPinM2Inp1.pinnumber;
   if(ControlPinM2Inp1.port==ATMELB){PORTB = *ControlPinM2Inp1.portstatus;}
   if(ControlPinM2Inp1.port==ATMELD){PORTD = *ControlPinM2Inp1.portstatus;}
void UnsetMotor2Inp1()
   *ControlPinM2Inp1.portstatus &= ~(1 << ControlPinM2Inp1.pinnumber);
void SetMotor2Inp2()
   *ControlPinM2Inp2.portstatus |= 1 << ControlPinM2Inp2.pinnumber;
   if(ControlPinM2Inp2.port==ATMELB){PORTB = *ControlPinM2Inp2.portstatus;}
   if(ControlPinM2Inp2.port==ATMELD){PORTD = *ControlPinM2Inp2.portstatus;}
void UnsetMotor2Inp2()
   *ControlPinM2Inp2.portstatus &= ~(1 << ControlPinM2Inp2.pinnumber);
void SetHBridgeControl() //With direct port manipulation for speedup the arduino framework!
   //Motor 1
   if(motordirection1 != oldmotordirection1)
         if(motordirection1 == 1)
            SetMotor1Inp1();
            UnsetMotor1Inp2();
         else
            UnsetMotor1Inp1();
            SetMotor1Inp2();
      else
         UnsetMotor1Inp1();
         UnsetMotor1Inp2();
      oldmotordirection1=motordirection1;
   //Motor 2
   if(motordirection2 != oldmotordirection2)
         if(motordirection2 == 1)
            SetMotor2Inp1();
            UnsetMotor2Inp2();
         else
            UnsetMotor2Inp1();
            SetMotor2Inp2();
      else
         UnsetMotor2Inp1();
         UnsetMotor2Inp2();
      oldmotordirection2=motordirection2;
void loop()
   //Read all stored PID and Feedback settings
   ReadEEProm();
   //Program loop
   while (1==1) //Important hack: Use this own real time loop code without arduino framework delays
      FeedbackPotWorker();
      SerialWorker();
      CalculateVirtualTarget();
      CalculatePID();
      CalculateMotorDirection();
      if(disable==0)
         SetPWM();
         SetHBridgeControl();
      pidcount++;
Re: SparksFun dual Moto Monster China Edition H-Bridge
Postby profetadelmus » Fri 11. Jul 2014, 12:31
Hi Sirnoname,
Whats the difference of two codes (master Brand and Moto-Monster brand)... only the change in the pinouts to accomodate the arduino over the shield directly?
Thanks!
profetadelmus
Images: 32
Has thanked: 10 times
Postby sirnoname » Sat 12. Jul 2014, 23:16
Firmware for arduino + Monster is now finally changed and successfully verified as working.
Latest Github Repository for download the firmware
Postby Tfou57 » Fri 18. Jul 2014, 22:00
Hello there
:mrgreen: Thank you for giving us another code Arduino Uno - H bridge.
This new code has features closer than the previous use
(Signal speed signals and two direction changing motor)
I try to control AC motors with an Arduino board
I think using any map H-Bridge
My intended use:
1- Map Arduino (without card Moto Monster)
2- Interface adapter voltage 0V -10V / 5V-12V ( advised by Vicpopo) :P
:?: Adapt.Zip http://www.x-sim.de/forum/download/file.php?id=2147I do happen to read the PDF, you know what software other files open?
3-Inverter frequency Omron 3G3EV AB007 Multifunction 220V Tri / 750W
4- 220V three-phase asynchronous gearmotor
:?: :oops: Being new to Arduino programming, I beseech you to tell me which parts of the code that INO are useless if no card Motorcycle Monster is used?
Texte Original en Français
Bonjour
:mrgreen: Merci de nous avoir fourni un autre code Arduino Uno - H bridge.
Ce nouveau code a des fonctionnalités plus proches que l’usage que le précédent
(Signal vitesse et 2 signaux de changement de direction par moteur)
Je cherche à piloter des moteurs triphasés avec une carte Arduino
Je pense utiliser aucune carte H-Bridge
Mon utilisation prévue :
1- Carte Arduino (sans carte Moto Monster )
2- Interface adaptatrice de tension 0V -10V / 5V-12V (conseillée par Vicpopo) :P
:?: Adapt.Zip http://www.x-sim.de/forum/download/file.php?id=2147 : Je n’arrive qu’à lire le PDF, savez –vous avec quel logiciel les autres fichiers s’ouvrent ?
3- Variateur de fréquence Omron 3G3EV AB007 Multifonctions en 220V Tri / 750W
4- Motoréducteur asynchrone 220V triphasé
:?: :oops: Etant novice en programmation Arduino, je vous sollicite pour m’indiquer quelles sont les parties du code INO qui sont inutiles si aucune carte Moto- Monster est utilisée ?
Tfou57
Postby sirnoname » Fri 18. Jul 2014, 23:50
the next firmware is for the sabertooth 2x60 like you can follow in the repository.
Did you search the arduino forum for code snipets with AC control?
Postby RacingMat » Thu 21. Aug 2014, 16:11
Tfou57 wrote:2- Interface adapter voltage 0V -10V / 5V-12V ( advised by Vicpopo) :P
the gbr files are "gerber" file: you can open them this a CAD software or PCB dedicated software
free on line viewer http://www.gerber-viewer.com/
Spark PCBhttp://fr.rs-online.com/web/generalD ... park-Jan11
Eagle http://www.cadsoftusa.com/download-eagl ... anguage=en
Postby wallytattoo » Tue 7. Oct 2014, 12:32
Hi all, a question, the analog signal of the potentiometer must be connected both the arduino and the monster?
Because I do not see how the connection is made to the potentiometers in the photos.
these are the only external input signals that I have, the rest are between the Arduino and the monster. this is so or am I wrong
wallytattoo
Has thanked: 5 times
Postby RiftFlyer » Wed 25. Feb 2015, 22:46
I've read all the info I can find on this bridge but I'm still having problems. See the second video here viewtopic.php?f=37&t=1779
I have read through the code and also tried adjusting PID values in the converter but have had little success in solving a vibration issue. If I run a lower pwm frequency the vibration is less severe and sometimes stops.
I see this comment in the code
Important:
(Edit- there is continuity between the power supply ground and the ground pin on the motor shield)
Without ground between arduino board and shield I can not get any movement!
Right now I have 5v and ground between both boards and the pot with the signal wire only connected to the arduino. Is this wrong?
I'd really appreciate some help. Thanks!
RiftFlyer
Images: 22
Postby PepeWah » Thu 28. Jan 2016, 17:34
Hallo,
schaue gerade nach MotoMonster. Ich habe eine Frage bei Sparkfun steht max 16V und bei dx.com 16-41V. Hat jemand die Variante aus China von DX.com mit 12V im Einsatz.
Grüsse
Peter
PepeWah
Postby nskmedia » Mon 11. Jul 2016, 12:47
Hello friend i need for a best alternative Motomonster & jrk 12v12 because booth are not able in my country India if there any best solution please share with me as possible soon thanks
nskmedia
