Module Features:
Dual BTS7970 chip structure (max current 68A)
5V isolation from MCU. This way MCU is effectively protected.
Eurospike wrote:If I adjust the motor position in both directions the motor moves nice and smooth. I then switched on the SIN oscillator and this works fine with no jerking. If I then switch on the Meande (Square wave) oscillator then I start to see problems again. This only seems to be a minor problem now but will cause me issues. If I increase the frequency of the oscillation then my power supply will trip out. Please let me know if you think this would be normal? I am using 2 server power supplies that I have converted, do you think these may be a problem, one is 62A and the other 47A?
Eurospike wrote:If I increase the frequency of the oscillation then my power supply will trip out. Please let me know if you think this would be normal? I am using 2 server power supplies that I have converted, do you think these may be a problem, one is 62A and the other 47A?
