As per the so simple powerful AMC board and big minds behind it ... what made it the center of this site and others are looking and admiring it from behind the scene ... good work my friends.
tell me slowly what do you think ?
speedy
vicpopo wrote:If I downgrade the Crystal on the amc1.6 to 18,432 Mhz , I can't test the Ale's sofware because there are no software and hardware according on this crystal with atmega644?
prilad wrote:In our case, a strange combination of circumstances led to this problem. May be the problem is a mismatch between firmware and hardware...
prilad wrote:For example: Suppose that some processor pin attached to the ground bus. And at the beginning of the communication firmware is trying to set this pin on a logic high. In this case (and in this moment only) we will have a shorting between power and the ground. And because USB power supply is not strong (only 500 mA max for current) it will go down and atmega go to reset.
This is just one example of how the incorrect firmware can lead to resetting of the processor in this case.
prilad wrote:speedy wrote:what do you think I should do ...?
We will try together to make it to work right. (If you want)For this I should know all your hardware features, as you say
prilad wrote: Both of them are have equal electrical levels (0 and +5V) for logic LOW and HIGH signals on this lines. And both are have equal timing diagrams on this lines -
USART standart.
prilad wrote:Another fact - there is no hardware reason related with lines RxD and TxD, which can lead to reboot atmega. It may be only firmware problem. But firmware works good with MAX232.
That's why I'm trying to understand what else is changed by changing the interface module. What do you think about this?
speedy wrote: Hooping I'm a good learner , tell me what I need to know more ...feel free to correct me If I'm wrong.
speedy wrote: for the above reasons I guess in the datasheet if there is a micro delay ... USB causes ATMEGA8535 to Malfunction and restarts .
