Re: Thanos AMC1.6 USB 2DOF Motion Controller
Postby tronicgr » Mon 2. Feb 2015, 20:52
micma80 wrote:
gzezelj wrote:... old AMC 1.5. Controller gives only high values for POT 2, in range 800-1023.
Hi, I make a simple observation ,
you have tried to change pot ? have you checked the cables of the pot and the PCB connection ?
micma80
He fixed it. It was wrong wiring, causing short circuit to the end of travel of the potentiometer.
Postby vthinsel » Sat 7. Feb 2015, 20:20
Hello !
I found out why the LCD was silent... the contrast pot was KO :? . I wired pin 3 to ground and then LCD came to life !
I'll double check the AREF pot * By the way, what is to be done with this pot ?
I need now to find out why the COM port remains silent when opening it with termianl application (I see the TX LED blink on the USB/RS232 adpater so I guess I should be able to see something)
Vincent.
vthinsel
Postby vthinsel » Mon 16. Feb 2015, 18:22
I finally got everything working 8-)
Oen of the issues was with the FTDI USB/RS232 clone, which I replaced : I was then able to receive the data from the AMC board.
Then I configured XSIM Extractor and Converter, using USO output and bingo !!!
I received today my sabertooth, so I'll start to play with it. I'll post a couple of pictures soon.
Thanks for your help !
V.
vthinsel
Postby vthinsel » Wed 18. Feb 2015, 23:27
Me again...
Things are improving on the electronic side ;)
I just have a last issue with the sabertooth module. I connected PWM1 to S1 and PWM2 to S2, configured the switches (1,4,6 to OFF) but I always get +12V on the two outputs :?
Any idea what I missed ?
Then I'll start the mecanic part with the 24V wipers motors I got.
Thanks.
Vincent
vthinsel
Postby ne02005 » Wed 1. Apr 2015, 13:44
Hello again! I´m back!!
Thanos:
I´ve ordered my Atmega 644, BUT they send it to me Atmega 1284P (they say "it´s the same"), but I can´t program it with latest firmware "FTISP for AMC1.6 1.1h both crystals.zip", I had 18 mhz crystal.
Can you compile for me the "1.1h" to Atmega 1284P?
Thanks for your help!
ne02005
ne02005
Postby ne02005 » Wed 1. Apr 2015, 13:48
Another question:
Is it posible, to run Amc 1.6 with 2 Lcd Displays? (one on the board and anotherone in front of me near the wheel.
Maybe connect both in paralell?
ne02005
Postby lucasdiulbern » Sun 31. May 2015, 18:50
What is the PWM frequency of the AMC1.6 ?
lucasdiulbern
Images: 20
Postby tronicgr » Sun 31. May 2015, 22:07
lucasdiulbern wrote:What is the PWM frequency of the AMC1.6 ?
17kHz
Postby ne02005 » Tue 23. Jun 2015, 16:53
Thanos:
ne02005
ne02005
Postby tronicgr » Thu 25. Jun 2015, 17:22
ne02005 wrote:Thanos:
ne02005
I'll try to find the old project files and see if I can compile it for this new chip.
Users browsing this forum: No registered users and 25 guests
