Postby motiondave » Sun 28. Apr 2013, 11:19
Just a question, who software and plug in are you using?
x-sim? bff?
Postby postsol » Tue 30. Apr 2013, 14:40
I need your help because I do not know what happens
I made Thanos AMC 1.6 and it seems to be working as it should
I use a AS5145H-hsst as encoder and counter finely 0-255 on display
I do not know why amc 1.6 run only 8 bit and I do not how to get it to run 16 bit.
I use mortor from motion control one 90ZYT-155-12 with gears 1 to 25 output
and I use an H-bridge. The DBK-HT dual motor driver
I've tried with xsim control software with firmware from ale take my engine 1 and turn and run back and forth between 0 and 255 and about 1 sec later there comes a loud pop from the h-bridge and it is dead.
I switched back to Thanos firmware started x-sim and a game and at the moment I pressed start on the x-sim. race motor back and forth and a new h-bridge was dead.
unfortunately I have not record a video of what happened and do not want to sacrifice a h-bridge again.
what should i do
thank you in advance for your help is appreciated
postsol
postsol
Images: 3
Postby wptm » Tue 30. Apr 2013, 17:59
postsol wrote:I've tried with xsim control software with firmware from ale take my engine 1 and turn and run back and forth between 0 and 255 and about 1 sec later there comes a loud pop from the h-bridge and it is dead.
postsol
It's very familiar to me. However I play with Arduino + dsmhb 1.2 h-bridge (diy one, designed by Thanos). For first time I "sacrificed" also an ebay h-bridge. Then I decided to build dsmhb 1.2 , not to throw away again an other h-bridge (only the mosfets ;) ). Well, well. I think I've already consumed the 2nd set of mosfets. The local store here has already a shortage, due to me. :lol:
Today one of the mosfets had some fire also. Now, I'm at that I take from it some distance at every test. :roll:
I'm lucky, because last week I could see to move my seat. So I know it works, I had it already. Just something else comes always. We say here some "stray current" .
I cannot help you with AMC1.6 . But, some general hints which would helped already to me: isolate everything. I've isolated even the pots, the motor, the actuator rods from each other and also from the frame. Take care of the pots. Today before I started x-sim, everything was ok with my h-bridge: it was turning my motors with a custom arduino code. But after starting x-sim I've noticed, that one of my pots was weird. I did not pay much attention on that, and when I pushed "Start" the motor was just turning for and backward very fast and very small and within some seconds the fire was there.
And one more: I made a proper cooling for the h-bridge also, with heat sinks and cooler.
wptm
Images: 57
Postby gamerbeter » Thu 2. May 2013, 13:24
hey guys how much dof support this module?
gamerbeter
Postby vicpopo » Thu 2. May 2013, 13:48
Amc1.6= 2 dof
Postby gamerbeter » Thu 2. May 2013, 14:04
i want a module to support 6 dof.can someone get me a link to i start? :?:
gamerbeter
Postby sirnoname » Thu 2. May 2013, 14:06
Read the first post, read the signature.
Postby kbssa » Fri 3. May 2013, 15:38
Hi all,
Anybody here knows how works the feature to change the pot limit range with the potentiometer ?
When I trun the pot the porcentage number change from 5% to 95%, but I really don't know what that means.
If any guy here can explain it to me I'd appreciate it.
kbssa
Images: 16
Has thanked: 5 times
Postby tronicgr » Fri 3. May 2013, 15:56
Since Firmware 1.1f the range of the end limits deadzone is defined with a potentiometer connected on pot3.
Read the first post... ;)
Postby kbssa » Fri 3. May 2013, 16:16
tronicgr wrote:Hi,
I have read the first post a lot of times, but I still don't know how that feature works, what I know is that when I turn the potentiometer connected on pot3 the porcentage value on LCD screen changes from 5% to 95%, but what that means ?
If I let it with 5% what is gonna happen ?
I hope you understood what I mean.
Bruno
kbssa
Images: 16
