Postby sirnoname » Tue 5. Feb 2013, 19:49
As former explained you can connect as much arduinos as you like, but he is talking about one arduino and three axis.
For your bridges is no coding needed, they are used in the pictures.
Postby wptm » Wed 6. Feb 2013, 00:43
Hi Sirnoname,
Thank you from me too! I'm still before investing the money into motor driver electronics. I'm really interested in you arduino solution.
I've looked after the boards on ebay. Unfortunatelly the 43a single and the 60a dual h-bridges labelled as not shipping to Hungary. So I found the "Another dual bridge with 68A from the ebay shop 1984yht888". This has also a cheap price (16.87$) .
But, and now comes my question, I'm not sure if it can really drive two motors. I've never used h-bridges before, but from the picture it seems it has also 4 ports (at the green connectors), just like the single one above. As far as I understand there're 2 ports for current (+ and -), and two for the motors. I've no problem ordering two of them, just want to be sure.
Thanks and regards,
Tamas
wptm
Images: 57
Postby wptm » Wed 6. Feb 2013, 12:24
Hello BobBuilt,
Here it is:
http://www.ebay.com/itm/Double-BTS7960B-H-bridge-68A-Motor-Driver-Module-For-Smart-Car-Arduino-/170917911112?pt=LH_DefaultDomain_0&hash=item27cb805a48
This is the third picture at "H-Bridge reqirements:" in the first page of this thread.
bye
wptm
Images: 57
Postby sirnoname » Wed 6. Feb 2013, 14:19
In China a 1,2GHz tablet comes with a 800MHz main CPU and a 400MHz graphic CPU. They combine the MHz to 1,2Ghz tablet. However it is slow because it is only a 800MHz tablet.
Same with H-Bridges, I think a 60Ampere double H-Bridge can handle 2x30Ampere. I have seen some guys which have connected the power sources together and use for one motor both H-Bridges on a board (and same control pins for both bridges). I do not know how save this is? Perhaps someone has some experince with this?
Buying exact the amount of H-Bridges that you need will make you trouble because they get very soon unknown and inavailable. If you damage one of them you have to wait for the next one.
Result: You cannot have enough H-Bridges :lol:
Postby prilad » Wed 6. Feb 2013, 14:22
It is not "Dual H-bridge" module. It is ONE full bridge, based on two H-bridge drivers BTN7970 - Edge
http://edge.rit.edu/content/P12215/publ ... _DS_11.pdf
One module can control only one DC motor
And you can't connect this module directly to Arduino with Sir (or mine) firmwares.
Regards,
ALE
prilad
Been thanked: 37 times
Postby wptm » Thu 7. Feb 2013, 23:09
Thanks! Yes, it was suspicious that it can drive one motor only.
wptm
Images: 57
Postby Racerr87 » Fri 8. Feb 2013, 02:24
The arduino can handle even 6dof Looking at this site:
http://www.fullmotiondynamics.com/about ... /progress/
My Arduino is ordered :D
Racerr87
Images: 7
Been thanked: 5 times
Postby motiondave » Fri 8. Feb 2013, 11:02
what video?
Postby ericRacer » Sat 9. Feb 2013, 02:35
As said a nice found.
The document has a copyright, is there a link for this document that we can exchange to your upload?
Or are we allowed to use it?
Racerr87 wrote:The arduino can handle even 6dof Looking at this site:
It could be a dream to own a 6 dof platform ! :P but it could turn fast into nightmare when we try to introduce a classic washout filter and/or predictive algorythm :oops: It is very difficult to fight against parasite force ! :shock:
I thing the best type of simulator for some people and me are those they works with proprioception 8-) = Simple, compact, less expensive, accurate...
MOTION PLATFORMS OR MOTION SEATS.pdf
Very interresting for the beginner .
(59.19 KiB) Downloaded 2235 times
ericRacer
Images: 36
Postby sirnoname » Sat 9. Feb 2013, 02:40
Of topic but a very good document!
