Postby Senetor » Tue 8. Jan 2013, 18:38
Hi Watkykj,
I have a pcb for the AS5145 chip, it uses 1206 smd resistors and 0805 smd capacitors. The 10k resistor can be substituted for a 10K multiturn resistor like the AMC board if you want it adjustable. The PCB is 25mm square, I also have a 20mm square version as well.
Here is the 25mm version. It is in Sprint Layout 5.0 format.
AS5145 Rotary Encoder 25mm PCB.pdf
(7.26 KiB) Downloaded 999 times
AS5145 Rotary Encoder 25mm.pdf
(456.67 KiB) Downloaded 990 times
AS5145 Rotary Encoder 25mm.rar
(8.13 KiB) Downloaded 981 times
Senetor.
Senetor
Postby cubizme » Sun 13. Jan 2013, 16:42
Hi guys !
I'm Letrung and I not good about programming and electric , I have problem with AMC 1.5 ( use FT232RL ), I loaded firmware for AMC 1.5 use FT232RL, but when I connected it to PC I didn't get anything from X-Sim , " Interface settings tab" didn't display my device ???
Might you help me ?
some pictures I connected FT232RL to AMC 1.5 , Did I wrong ?
101310121014
sorry my bad english :(
Best regards,
cubizme
Images: 73
Has thanked: 9 times
Postby vicpopo » Sun 13. Jan 2013, 22:06
Hi ,
You won't find your device at the place you attached the photo.You have to use the USO parser to send the data to the amc .
Look at the first page of this thread , Thanos give explaination for the string to communicate between amc and xsim.
Best Regards
Postby cubizme » Mon 14. Jan 2013, 10:48
vicpopo wrote:Hi ,
Best Regards
It worked :D ,thanks for your tips .
Now I have a new problem, when I connected it with X-sim ( using firmware of Thanos ) , it worked for 3-4s then it restarded continously . Then I try firmware of Prilad use X-SimCTRL , It still restarded ... I using crytals 18.432Mhz for AT8535 .
Best Regards,
cubizme
Images: 73
Postby vicpopo » Mon 14. Jan 2013, 11:00
I know that someone had this problem but I didn't remember how they fixed it!
Try reading previous posts in this thread or searching in x sim with keywords amc reset.
Best Regards
Postby cubizme » Tue 15. Jan 2013, 03:49
vicpopo wrote:Hi,
Best Regards
I found that topic and I fixed , but my board still reset .
I forgot to tell you, I used 10uf/50v to replaced 10uf/16v, is it my problem ?
Best Regards
cubizme
Images: 73
Postby vicpopo » Tue 15. Jan 2013, 07:18
Hi ,
For the capacitor it's OK.
Did you use the last xsim release(xsim3) and not an old one(xsim2)?
Try to disabling your firewall.
Did you write the string in Uso parser exactly as Thanos written?
If someone else could help?
Best Regards
Postby vicpopo » Wed 16. Jan 2013, 09:03
Hi Cubizme,
Open a New topic for your simulator.
In request to your questions .
How many axis did you use ? If 2 axis write the string in Uso parser as Thanos shows on the first topic page (AB-255--....)
For profile making look at the section Tutorial on xsim and the video from Motiondave.
You can have look here : http://www.x-sim.de/forum/viewtopic.php?f=83&t=305
Best Regards
Postby cubizme » Wed 16. Jan 2013, 15:01
vicpopo wrote:Hi Cubizme,
Best Regards
I am very grateful to you !
Thank you, again !
Best Regards,
cubizme
Images: 73
Postby Mknorr » Fri 18. Jan 2013, 06:35
Hello,
I'm very new here and was wondering if anyone makes a kit or at least a pcb for this?
My apologies if this has already been answered somewhere. I could not find it.
Many thanks for any help provided.
Manfred
Mknorr
