Postby thecure » Sun 11. Nov 2012, 19:36
I can create the circuit , can I supply it with 24 v ? If the mosfet doesn't burn I think that it is working...tks
thecure
Been thanked: 5 times
Postby tronicgr » Mon 12. Nov 2012, 07:31
You can contact vicpopo for layout files. Can't say if it will work with 24v because of the 15v zeners
Postby tronicgr » Thu 15. Nov 2012, 01:42
Today I had some time to test higher serial speeds using a beta version that Sirnoname provided me. I achieved speeds up to 230400bps with no problems.
Then I took the time to measure the main loop cycle time compared to the serial stream... in the following link you will find what happened:
http://motionsim.blogspot.com/2012/11/new-speed-measures-on-latest-firmware.html
Postby sirnoname » Thu 15. Nov 2012, 02:23
Did you stop developing your new board after you have seen this result :mrgreen:
A simple editbox can do fresh ideas, thanks goes to prilad who has requested this trick.
Better late than never :!:
Postby tronicgr » Thu 15. Nov 2012, 02:41
No, didn't stop, but I need a reference for comparison right???
We could have this little editbox from years ago... :D
Postby tronicgr » Sat 17. Nov 2012, 22:35
BTW, I have for sale my prototype AMC1.6 board: http://www.x-sim.de/forum/viewtopic.php?f=7&t=598&p=3977#p3977
This doesn't mean that I abandon this project... I just have a newer PCB version that I'm using and can give this prototype to someone less fortunate with soldering skills. ;)
Postby ferslash » Sun 18. Nov 2012, 07:43
Just by curiosity, what is the price my dear tanos?
ferslash
Postby tronicgr » Sun 18. Nov 2012, 07:47
Hi ferslash,
Did you look in the sale thread link? ... http://www.x-sim.de/forum/viewtopic.php?f=7&t=598&p=3977#p3977
Its already there...
Postby tronicgr » Mon 19. Nov 2012, 22:01
After a major fix in the ADC routines, I finally got my controller run at 5000 times per second all the time, not only for digital encoders...
ADC is now more immune to noise as well. So potentiometers or analog hall-effect sensors can be used with all available resolution.
Have a look here for the logic analyzer capture timings: http://motionsim.blogspot.com/2012/11/real-breakthrough-in-speed-again.html
Thanks,
Postby nury961 » Mon 19. Nov 2012, 22:11
tronicgr wrote:Hi,
Thanks,
congratulations...
Thanks a lot !
nury961
Images: 12
