Hi Thanos ,
A quick demonstration using your AMC 1.6 with Prilad SW and FW and Speedy nmofset h-bridge.
http://www.x-sim.de/forum/viewtopic.php?f=43&t=246&start=80#p3032
Many Thanks
Best Regards
jsmith2307 wrote:
The feedback potentiometers are wired the same way as the AVR1.5, no problem on that one! I even reversed wired them to see if that was the problem!
Also, I reverted back to X-Sim2 to check if that was the problem. I guess it wasn't.
jsmith2307
Yes, but they still are not attached on the motor. At least that is what I understand from the video. In order for the potentiometers to be called "Feedback" potentiometers, they should report back to the AMC the position of the motor output (axle rotation position).
I removed the zener and the resistor completely because of parasitic noise in the power lines and replaced it with a LM7805 and a 22uF capacitor.
