vicpopo wrote:Hi Ale,
Thanks for the video.You are running your macbook with bootcamp or with another windows emulator?
Regards
Gilles
prilad wrote:Hi BobBuilt!
I want to inform you (and all community) what we both (me and nullrnd) tested firmware and isolators ( based on 6N137 (for me) and ADuM1400 (for nullrnd)) on Arduino Duemilanowe. Not on Arduino Nano.
When nullrnd was try to test with Nano there were errors and failures in the FT232R. Maybe he has a bad sample of Arduino Nano?
best regards,
Ale
BobBuilt wrote:But once I mark the sending the set point bounces up and down even with it not set to occilate,
BobBuilt wrote:What could be the problem or can I not worry about that and test with xsim direct.
BobBuilt wrote:Plus whats the USO needed to run, same as tronics.
BobBuilt wrote:Ok.
1. didnt make any diff
2. Changed kphi/lo to 10 press enter to send. Doesnt change anything set pos (red) still jumps all over the place. Save to eeprom is greyed out never been avail.
Is it possible that Im missing a ddl or a redistribitable file thats needed to run xsimctrl. Plus Im running it from the desktop.
Apart from this the card seems to be working properly will test through xsim.
I have even check the device manager to confirm baud rate set right in windows.
