Postby speedy » Wed 26. Jun 2013, 06:20
Hi Mr. Prilad:
sorry for interruption ... but with the hazing numbers on Mr./jsmith2307 video ... I see that he had the SensLo and SensHi values for motor 1=>"Y" are reversed .... isn't that could be the problem ?
This amazing program can do some tricks :lol: ... for the simulator protection ... they should be used right .
regards
spe ;) edy
speedy
Has thanked: 14 times
Postby prilad » Wed 26. Jun 2013, 06:59
speedy wrote:Hi Mr. Prilad:
sorry for the hazing numbers on Mr./jsmith2307 video ... I see that he had the SensLo and SensHi values for motor 1=>"Y" are reversed .... isn't that could be the problem ?
regards
spe ;) edy
Hi, Speedy. ;)
About SensLo and SensHi - if they are reversed, it's mean that the "sensor" is reversed. It is programm way to change sensor's direction instead wires re-soldered.
Regards,
Ale
prilad
Been thanked: 37 times
Postby jsmith2307 » Wed 26. Jun 2013, 19:26
Greetings, :D
check with multimeter (voltmeter) potential on pin DIR (p1d1). It must change level from +5V to 0V and back when PWM is changed sign.
I checked the voltage out with the program on oscillator, checked the multimeter set to DCV @ 20volts on p1d1 to DIR and got ZERO on the readout .
Next I checked the other side on p2d1 to DIR and got a readout from 4.7 to 0 per/oscillation.
The thing is why did p1d1 to DIR not give me any thing other than ZERO?
jsmith2307 :D
jsmith2307
Images: 8
Has thanked: 12 times
Postby prilad » Wed 26. Jun 2013, 19:41
jsmith2307 wrote:Greetings, :D
jsmith2307 :D
There are three variants:
1 - in firmware p1d1 assigned to the other pin
2 - it's the ground fault
3 - pin p1d1 of atmega is broken
I recommend disconnect power, to check (with multimeter) the resistance between Ground and p1d1.
After to disconnect AMC from H-bridge and check voltage on p1d1.
And if there is not voltage on p1d1 - reconnect H-bridge to p2d1.
Regards,
Ale
prilad
Postby jsmith2307 » Wed 26. Jun 2013, 20:19
Greetings,
I hope I did this right! :D
Power off, using the multimeter set on 200k resistance, I measured from the GND pin on the board, to p1d1 pin everything stayed attached @ 47.0
then
I measured from the GND pin on the board, to p1d1 pin everything off @ 00.0
Did you mean reconnect.....?
jsmith2307
jsmith2307
Images: 8
Postby jsmith2307 » Wed 26. Jun 2013, 20:26
Deleted... see above.
jsmith2307
Images: 8
Postby prilad » Wed 26. Jun 2013, 20:34
Power off, using the multimeter set on 200k resistance, I measured from the GND on the board, to p1d1 everything stayed attached @ 47.0
then
I measured from the GND on the board, to p1d1 everything off @ 00.0
jsmith2307
Sorry, jsmith2307... I mean to check voltage on pin without connecting to H-bridge. But if you have 0 ohm resistance (if I right understand) between GND and p1d1 - check soldering. Or you have broken pin of atmega. If Atmega in socket - you can extract Atmega and check resistance again
Regards
prilad
Postby jsmith2307 » Wed 26. Jun 2013, 21:46
Greetings, :D
I've changed over to p1d2 from p1d1, and it appears it does what p1d1 was supposed to do! I'm in early testing...videos to come! :lol:
jsmith2307
jsmith2307
Images: 8
Postby spartan300 » Thu 27. Jun 2013, 10:44
ok
spartan300
Images: 16
Postby jsmith2307 » Fri 28. Jun 2013, 17:20
Greetings Ale!!! :D
It is with great pleasure, I declare a minor level of success!! It WORKS! Thank you, thank you for everything. While probing with the multimeter I discovered a reading from 0 - 4.8 and back again on P1d2 pin and moved over to that. I've been checking the CW & CCW it works great!....Except a grinding sound coming from the motor.
Video [YouTube] http://youtu.be/LOElu-MlMME [/YouTube]
Once again, Thank you!
I've got another question for you, but I have to do my homework before asking! :D
jsmith2307
jsmith2307
Images: 8
