L298: 4Ampere is for pussies.
You can connect it.
BobBuilt wrote:Sir lists a couple of good drivers at 40 odd amps try to find theses as the code is written for them and supported by sir (as in he has tested them).
zecaEU01 wrote:Good morning everyone
Remaking the question of the potentiometer: the type below is good for our type of work.
http://www.digikey.com/product-detail/e ... -ND/297614
ZECA
Port geschlossen
Port geöffnet durch Vorgang "javaw.exe" (PID: 1556)
DOWN (0x00000000): IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size
InSize=2048
OutSize=1024
UP (0x00000000): IOCTL_SERIAL_GET_PROPERTIES: Retrieve COM properties
Packet Size=64
Packet Version=2
services implemented=SP_SERIALCOMM
Max Tx bufsize=0
Max Rx bufsize=0
Max baud rate=Changeable bps
Specific provider type=MODEM
Capabilities supported=DTRDSR, RLSD, PARITY_CHECK, TOTALTIMEOUTS, INTTIMEOUTS
Changeable parameters=PARITY, BAUD, DATABITS, STOPBITS, HANDSHAKING, PARITY_CHECK, RLSD
Allowable baud rates=300 bps, 600 bps, 1200 bps, 2400 bps, 4800 bps, 9600 bps, 19200 bps, 38400 bps, 115200 bps, 57600 bps
Allowable byte sizes=7, 8
Stop bits/parity allowed=1 stop bit, None Parity, Odd Parity, Even Parity, Mark Parity, Space Parity
Tx buffer size=0
Rx buffer size=16384
UP (0x00000000): IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate
Baud Rate=115200
UP (0x00000000): IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control
WordLength=8
StopBits=1 stop bit
Parity=No parity
UP (0x00000000): IOCTL_SERIAL_GET_CHARS: Retrieve special characters
EofChar=0x0
ErrorChar=0x0
BreakChar=0x0
EventChar=0x0
XonChar=0x0
XoffChar=0x0
UP (0x00000000): IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information
ControlHandShake=0
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=115200
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x0
ErrorChar=0x0
BreakChar=0x0
EventChar=0x0
XonChar=0x0
XoffChar=0x0
ControlHandShake=0
FlowReplace=0
XonLimit=0
XoffLimit=0
UP (0x00000000): IOCTL_SERIAL_GET_TIMEOUTS: Retrieve timeouts
ReadIntervalTimeout=5000
ReadTotalTimeoutMultiplier=5000
ReadTotalTimeoutConstant=5000
WriteTotalTimeoutMultiplier=0
WriteTotalTimeoutConstant=0
Baud Rate=115200
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x0
ErrorChar=0x0
BreakChar=0x0
EventChar=0x0
XonChar=0x0
XoffChar=0x0
ControlHandShake=0
FlowReplace=0
XonLimit=0
XoffLimit=0
DOWN (0x00000000): IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate
Baud Rate=9600
DOWN (0x00000000): IOCTL_SERIAL_CLR_RTS: Clear RTS
DOWN (0x00000000): IOCTL_SERIAL_SET_DTR: Set DTR
DOWN (0x00000000): IOCTL_SERIAL_SET_LINE_CONTROL: Set line control
WordLength=8
StopBits=1 stop bit
Parity=No parity
DOWN (0x00000000): IOCTL_SERIAL_SET_CHARS: Set special characters
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
DOWN (0x00000000): IOCTL_SERIAL_SET_HANDFLOW: Set handshake information
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
DOWN (0x00000000): IOCTL_SERIAL_SET_TIMEOUTS: Set timeouts
ReadIntervalTimeout=0
ReadTotalTimeoutMultiplier=0
ReadTotalTimeoutConstant=0
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
ReadIntervalTimeout=4294967295
UP (0x00000000): IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
WaitForImmediate=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
UP (0x00000000): IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=9600
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
DOWN (0x00000000): IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask
WaitMask=RXCHAR: Any Character received
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
DOWN (0x00000000): IOCTL_SERIAL_CLR_DTR: Clear DTR
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
DOWN (0x00000000): IOCTL_SERIAL_SET_RTS: Set RTS
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Modem status=None
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Errors=0
HoldReasons=0
AmountInInQueue=0
AmountInOutQueue=0
EofReceived=FALSE
Port geschlossen
Port geöffnet durch Vorgang "avrdude.exe" (PID: 3904)
InSize=1024
OutSize=1024
Baud Rate=9600
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x4
ErrorChar=0x0
BreakChar=0x0
EventChar=0xa
XonChar=0x0
XoffChar=0x0
ControlHandShake=1
FlowReplace=0
XonLimit=0
XoffLimit=0
Baud Rate=115200
WordLength=8
StopBits=1 stop bit
Parity=No parity
EofChar=0x0
ErrorChar=0x0
BreakChar=0x0
EventChar=0x0
XonChar=0x0
XoffChar=0x0
ControlHandShake=0
FlowReplace=0
XonLimit=0
XoffLimit=0
ReadIntervalTimeout=250
ReadTotalTimeoutMultiplier=250
ReadTotalTimeoutConstant=250
14 10 ..
14 10 ..
14 .
10 .
14 .
03 .
10 .
14 .
03 .
10 .
14 .
10 .
14 .
10 .
14 .
10 .
14 1E 95 0F 10 ....
14 .
00 .
10 .
14 .
00 .
10 .
14 .
00 .
sirnoname wrote:Yes I know that.
If you upload the firmware the rs232 converter on the arduino get better initialized than with my plugin code.
I thought it is solved but it seems to be not working for you.
I am searching for windows host source code which explain how I have to init the arduino to work as the firmware upload do.
The last change I did was to init the DTR/CTS lines which has solved this on my device and which I saw in a sample code.
There is a trick I did not found for now how the firmware upload is failsave to init the converter speed and I not.
Will now install the serial port monitor and sample the exact solution with a firmware upload and try to implement this init into the X-Sim plugin.
