Hi Thanos.
Once again I cannot agree with you
tronicgr wrote:Its not only the available channels or the voltage rating...
Afaik the ADUM1400CRW is the only one rated for 45 MHz logic signal freq (90Mbps).
The ADUM1400BRW is rated only for 5 MHz logic signal freq (10Mbps), and the ADUM1400ARW for 1 MHz logic signal freq (2Mbps)... Kind of useless for fast and error free serial communications...
What do you say? what the "serial communications" do you mean? We are talking about isolation for DIR and PWM lines between Arduino and H-Bridge.
Or you think, that 1 MHz is very "slow" for this mission? But you use in your "optolink" (
http://www.x-sim.de/forum/viewtopic.php?f=39&t=132&start=20#p978) optocouplers 4n35, which EIGHT times more SLOWLY than ADUM1400ARW.
In 4n35 Datasheet we can see, that rise time (Tr) for output pulse is
3.2 us and fall time (Tf) is
4.7 us.
It mean, what full pulse width can not be smaller then
3.2+4.7 = 7.9 us and max pulse "frequency" is only
127 kHz instead 1MHz for ADUM1400ARW
- 4N35 Rise and Fall times description
- 4N35 Rise and Fall times values
And 4n35 has propagation delay more then
5.7 us (Time-off delay) instead
100 ns (0.1 us) for ADUM1400ARW or 65 ns for ADUM1410 .
- ADUM1410 Propagation delay
Regards,
ALE
