Build Your Own Ardruino 6DOF Motion Platform
Re: Build Your Own Ardruino 6DOF Motion Platform
Postby viawave77 » Mon 15. Jul 2013, 03:55
Thanks Thanos, dont worry you told me the you were busy, thats way I try varius channels, I will study your tip, Thank you again.
Thank you, too, Telfel , so you were RC enthusist, too. I used to build multicopters thats way knowladge about mini servos is not to much for me. Thank you for your tip, I will concider if I not resolved with Thanos electronic tip.
Regards.
Italo
viawave77
Postby viawave77 » Mon 15. Jul 2013, 03:58
Thanos, I almost forgot!!!
CONGRATULATION for the new job!!! Qualcomm...the future is mobile.Live it now!!!
Regards
Italo
viawave77
Postby rkoo » Thu 12. Sep 2013, 13:11
Hi futuresims,
Thanks for sharing this project. It's great to get experiment with 6DOF / Steward platform on the desk without having to build the full size thing.
> I'll talk about incorporating some type of realtime position input in another instructable.
oh yes, Please share ;)
brad
rkoo
Postby Shadow041 » Sun 29. Dec 2013, 05:20
Hey Guys,
I'm pretty new to all this so you'll have to forgive me if im asking stupid questions...
I've been following this fantastic guide as something to get me started in understanding how everything works as i would like to build a 6dof sim in the not too distant future.
So far ive built the sim rig and had hooked up the arduino but seem to be having a problem with the code. I copied the code across from the 1st post cause i couldn't find the .ino file.. and when i hit verify it came up with 3 errors:
_6DOF_Motion_Code:3: error: 'oat' does not name a type
_6DOF_Motion_Code:6: error: expected unqualified-id before ',' token
_6DOF_Motion_Code:7: error: expected constructor, destructor, or type conversion before '=' token
Any ideas on how i can fix it and get it running?
I only have very limited knowledge of programming but am trying to learn.
Also i see that most people use Thanos's AMB controller to link this with x-sim because its fast and better but is there any way to do it with the arduino board just for testing purposes?
Cheers guys, i really appreciate any help you can give me on this.
Shadow041
Postby tronicgr » Mon 30. Dec 2013, 19:19
Hmm,
This piece of code in the start of this thread will not work with the 6DOF plugin for x-sim. There are several reason:
1. Serial speed
The arduino code requires 9.6 kbps
The 6DOF plugin uses 250 kbps (which the AMC1280USB can handle).
2. Datatype
The arduino code requires 8-bit values.
The 6DOF plugin outputs packets of 16-bit values and only if the interface is autodetected on the other end (AMC1280USB compatible).
3. Data format
The arduino code reads time values between positions
The 6DOF plugin outputs destination positions.
Regards,
Postby maykids » Fri 22. May 2015, 16:26
Anyone can help me, please how can i setup arduino with xsim, have three days i try and i can't finish this configs, anyone have a profile for i use my 6 dof? Please!? :cry:
maykids
Postby Funkmidget » Sat 30. May 2015, 20:55
Do you have an eps file for the servo arms?
Funkmidget
Postby novoum » Sun 31. May 2015, 18:58
Hi I'v build this 6dof as instructed.
I connected servos to Arduino uno. I pasted code to uno, but
I get no movement, servos just don't move. Please advise
if the code in this instructions is valid and OK
regards
Mario
novoum
Postby tronicgr » Sun 31. May 2015, 22:11
novoum wrote:Hi I'v build this 6dof as instructed.
regards
Mario
Never tried that arduino code. I use my own ide environment that is NOT based in arduino for the amc1280usb....
Postby novoum » Mon 1. Jun 2015, 08:25
6thank you tronicgr for your answer
but I already used Arduino.
Anyone else already builded Arduino based 6dof
Mario
novoum
