If you don't mind read the maker's guidelines cautiously before continuing with establishment. Ensure that you are agreeing to all wellbeing and operational direction given by the producer.
The main thing to fit onto the casing is the Power Supply Unit (PSU). The best area for this is promptly toward the back of the middle section, on the principle cross part. At that point there will be no threat of it being hit by the top edge when at its most minimal position. Take the Clamor Rail and cut a 400mm length. Make two edge sections out of extra bits of edge or channel and mount the rail onto the back most edge of the cross part utilizing 6mm stray pieces. At that point cut the PSU onto the rail at the left end and two 5-way commoning obstructs at the correct end of the Clamor rail.
You will see that the ventilation spaces of the PSU are confronting upwards. This is so the interior cooling of the unit can work best. You have to ensure that you spread these spaces at whatever point there is a danger of little metal sections (swarf) dropping onto the unit. These spaces ought to never be secured when the unit is working.
Cut appropriate lengths of red and dark 45A link to associate one commoning square to the positive yield from the PSU and one to the negative yield. At long last, cut an appropriate length of 3-center mains link to associate the PSU to your mains supply. This ought to be equipped for around 13A limit. Interface the mains link and fitting in the PSU. Switch it on and, utilizing a Computerized VoltMeter (DVM) watch that the yield voltage at the commoning squares is 24V.
In the wake of checking the yield, turn off the PSU and disengage from the mains supply before continuing further.
