any ideas on pedals and wheel adjusment?
Postby ferslash » Fri 31. Aug 2012, 17:05
Hi folks:
I am sourcing materials to construct an hibrid between seat mover and frex sim style...
so, it will only move the seat, but i would like to include in the sim place to put pedals and wheel ... so the question is... could you reccomend me an easy sistem to adjust pedals and wheel so if my wife for instanse use it, she can adjust the distance from the pedals to the seat? ... there are a lot of sistems but i need the easyest one...
any recomendations??
best regards from mex
fer
ferslash
Re: any ideas on pedals and wheel adjusment?
Postby cthiggin » Sat 1. Sep 2012, 01:57
"Modifying" a PlaySeat to accommodate for movement. All the other adjustments you need come with it.
www.playseat.com - you can also get them on eBay at a good price.
Good Luck
cthiggin
cthiggin
Postby motiondave » Sat 1. Sep 2012, 02:02
maybe weld some old car seat rails to a frame and then weld a frame to that so as the wheel and pedals can slide back and forth to you.
