2dof wiper motor, Arduino and H Monster
Postby johnnydb » Mon 4. May 2020, 20:54
Dear All,
I Start my project.
I Will post the progress here.
Layout:
3d model
johnnydb
Re: 2dof wiper motor, Arduino and H Monster
Postby johnnydb » Mon 4. May 2020, 20:58
First part's:
johnnydb
Postby johnnydb » Mon 4. May 2020, 20:59
Seat Model:
johnnydb
Postby johnnydb » Tue 5. May 2020, 14:17
Position Feedback 3d Printed:
Motor Arm:
johnnydb
Postby johnnydb » Tue 5. May 2020, 14:20
Arm Join:
johnnydb
Postby johnnydb » Fri 15. May 2020, 00:53
More progress!
johnnydb
Postby johnnydb » Thu 21. May 2020, 01:30
Today I order more alu part's to make all rig with the v-slot.
The final layout is more less like this:
johnnydb
Postby johnnydb » Thu 28. May 2020, 20:43
hi all!
I change the H-bridge to IBT-2 because have more option to the future change to 24v motors and the current is bigger (43A) x Monster that have 20A nominal.
Finish the wiring and make test and adjust on PID. Everthing work fine. I use the code of "Sirnoname" XPID, and work very well!
I make the joint with 3d printer, bolt's and universal end joint.
I test too the triple screen in assetto corsa competizione:
In this video show the 2dof base in work:
https://youtu.be/6WeMJkuAOVM
johnnydb
Postby loadedlouie » Sun 2. Aug 2020, 20:48
Hi, I'm planning on building something like this, but I was wondering how much would it cost ?
In your case how much did it cost, and can I get the parts used?
thanks in advance
loadedlouie
Postby flotis » Mon 10. Aug 2020, 19:54
Hi. Good proyect. What arduino code have you used?
flotis
Users browsing this forum: No registered users and 64 guests
