2dof simulator
2dof simulator
Postby sudca » Thu 23. Nov 2017, 20:39
After one month reading and watching everithing about 2 dof sim i start the project :P
thanks very much for this software and people who help me with they guides like this
http://www.x-sim.de/forum/viewtopic.php?f=36&t=1617
or this
http://www.x-sim.de/forum/viewtopic.php?f=37&t=1103
i start with electronical conennection with this wiring
4444
and i use
arduino uno
4442
monster motor shield
4441
2xwiper motor 12v
4445
2xpots 10k ohm linear
4446
2x 12v8,5A power supply one is for motor and monstershield and second is for fans and leds :)
4461
heatsink
4448
Motor holder
4456
Pots holder
4460
Pots holder
4458
i made this hole to hold the pots
4459
connection 1
4457
connection 2
4454
connection 3
4455
to arduino i write code from RacingMat but i change this in the code from wiring diagram and upload to arduino
4452
pots position i use from soraz
test this now i made video later
4451
test with project cars
made box for everything :)
4449
4450
is working and alive so i start build the sim :)
4453
For converter setup i use video tutorial from here in video tutorials
4462
4463
i change this becouse i have rotate motors different way maybe i change later i will see :)
4464
i change invert for left side and right side
befour mount the pots to motor check rotation pot and motor have to go different way
4465
video
Hard work :D
4466
4467
4498
4499
4500
4501
4502
4503
4504
4505
4506
4507
4508
4509
4510
4511
4512
4513
4514
4515
4516
4517
4518
4519
4520
4521
4522
4523
4524
4525
4526
day to day near to finish :D
anti vibration ;)
4549
4545
4547
4548
4546
4551
4550
sudca
Images: 72
Re: 2dof simulator
Postby andre » Wed 20. Dec 2017, 02:15
Beautiful project! I don't understand why you had 0 reply (until I post 1 !). I posted a question got 31 views but no help.
Good job and good luck with your project!
andre
Re: 2dof simulator
Postby baxbax » Wed 3. Jan 2018, 19:35
Great work!!!
I'm starting , to know this world, from few weeks.
About electronic and software, no problems. Many, for the mechanics.
Can I ask you, what kind of wiper motor model , have you bought?
And the model of motor driver?
Thanks in advance
Bye
Bax
baxbax
Re: 2dof simulator
Postby sudca » Thu 4. Jan 2018, 21:35
hello thank you i am not finish the project now i hope finish project this month :D
the motor i use Magneti Marelli wiper motor i am not test now becouse is not complete i will see if will by strong enough i hope :D
it should this one https://www.ebay.co.uk/sch/Magneti-Marelli-Windscreen-Wiper-Motors/61941/bn_40229493/i.html
sudca
Images: 72
Re: 2dof simulator
Postby baxbax » Thu 4. Jan 2018, 21:45
Thanks for the answer.
I will wait your finished project, so you could say something about the motors.
What is the name of motor board that you are using, now?
Bye
Bax
baxbax
Re: 2dof simulator
Postby Miotornut » Sat 20. Jan 2018, 11:04
I want to do it myself. I can do it, but a little bit late.
Miotornut
Re: 2dof simulator
Postby pipeferr » Tue 30. Jan 2018, 23:50
Buen proyecto y muy bien expuesto enhorabuena
pipeferr
Images: 3
Re: 2dof simulator
Postby aspe » Thu 15. Feb 2018, 19:16
muy bien documentado
aspe
Re: 2dof simulator
Postby sudca » Thu 15. Feb 2018, 19:47
Gracias :)
sudca
Images: 72
Re: 2dof simulator
Postby Charlines » Sun 18. Feb 2018, 17:54
si señor buena currada las que te as pegado. alguna que otra idea te la voy a robar para el proyecto mio jejejej un 10 si señor
Charlines
Users browsing this forum: No registered users and 57 guests
