2 dof (wiper motor - arduino - motomonster)
Postby impalone » Fri 2. Dec 2016, 22:47
Sorry if there are errors in English.
I state with pleasure thanking "Racing Mat" user from which I was inspired for my project. I present my "sim 2 dof". For my homemade simulator, I chose the iron rods of 35x35mm 2 mm size for the base and 30x30mm and 20x20 sp.2mm for the upper float. The all welded.
I will show you step by step my realization.
4213
_________________________________________________________________________________________________________________________
Chassis
The upper part of my frame
4210
The lower base with adjustable feet.
4211
4212
The cardan joint used in the assembly of the top and the bottom of the frame, is a joint of a transmission of a buggy, cut and greased.
4234
I created a hole on the two parts. I reinforced the hole with two iron rings and then I fastened the cardan joint by welding
4227
The result is this
4226
Electronic and motor
The utilized solution to move the frame, are two wiper motors, exactly SMOLKA VALEO 404458. Powered and controlled by motomonster card and "Arduino", controlled by 10Kohm linear potentiometers.
I was inspired by the shared schema from "Racing Mat".
4209
I've got all the necessary material on various internet sites.
Wiper motor - Smolka Valeo 404.458 12V Wiper Motor
4237
Linear pot
4236
Arduino and motomoster
4224
Electric cables
4219
power supply 12V 50A
The motomoster can be attached on top of the Arduino. I preferred to make them work parallel, so there is no danger of a short circuit and overheating, I have also connected the potentiometers as the diagram of "Racing Mat".
4223
4214
Then I connected Arduino to the PC and I upload this "Sketch" in Arduino.
Code: Select all
 Arduino code for dynamic playseat 2DOF
 Created 24 May 2011 by Jim Lindblom   SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
 Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
 Updated 20 May 2013 by RacingMat in english http://www.x-sim.de/forum/posting.php?mode=edit&f=37&t=943&p=8481  in french : http://www.gamoover.net/Forums/index.php?topic=27617
 Updated 30 April 2014 by RacingMat (bug for value below 16 corrected)
#define BRAKEVCC 0
#define RV  2 //beware it's depending on your hardware wiring
#define FW  1 //beware it's depending on your hardware wiring
#define STOP 0
#define BRAKEGND 3
#define pwmMax 255 // or less, if you want to lower the maximum motor's speed
const int potMini=208;
const int potMaxi=815;
#define motLeft 0
#define motRight 1
#define potL A0
#define potR A1
//  DECLARATIONS
/*  VNH2SP30 pin definitions*/
int inApin[2] = {
  7, 4};  // INA: Clockwise input
int inBpin[2] = {
  8, 9}; // INB: Counter-clockwise input
int pwmpin[2] = {
  5, 6}; // PWM input
int cspin[2] = {
  2, 3}; // CS: Current sense ANALOG input
int enpin[2] = {
  0, 1}; // EN: Status of switches output (Analog pin)
int statpin = 13;  //not explained by Sparkfun
/* init position value*/
// INITIALIZATION
void setup()
  // serial initialization
  Serial.begin(115200);
  digitalWrite(statpin, LOW);
  for (int i=0; i<2; i++)
    pinMode(inApin[i], OUTPUT);
    pinMode(inBpin[i], OUTPUT);
    pinMode(pwmpin[i], OUTPUT);
    digitalWrite(inApin[i], LOW);
    digitalWrite(inBpin[i], LOW);
void loop()
  int sensorL,sensorR;
  readSerialData();   // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
  sensorR = analogRead(potR);  // range 0-1024
  sensorL = analogRead(potL);  // range 0-1024
void readSerialData()
  byte Data[3]={
    '0','0','0'          };
  if (Serial.available()>2){
    //parse the buffer : test if the byte is the first of the order "R"
    Data[0]=Serial.read();
    if (Data[0]=='L'){
      Data[1]=Serial.read();
      Data[2]=Serial.read();
      //  call the function that converts the hexa in decimal and that maps the range
      DataValueR=NormalizeData(Data);
    if (Data[0]=='R'){
      //  call the function that converts the hexa in decimal and maps the range
      DataValueL=NormalizeData(Data);
  if (Serial.available()>16) Serial.flush();
  //could be a parameter read from a pot on an analogic pin
  int gap;
  int pwm;
  int brakingDistance=30;
  gap=abs(targetPos-actualPos);
  if (gap<= Tol) {
  else {
    pwm=195;
    if (gap>50)   pwm=215;
    if (gap>75)   pwm=235;
    if (gap>100)  pwm=255;
    pwm=map(pwm, 0, 255, 0, pwmMax);  //adjust the value according to pwmMax for mechanical debugging purpose !
    // go forward (up)
    // go reverse (down)
void motorOff(int motor){ //Brake Ground : free wheel actually
  digitalWrite(inApin[motor], LOW);
  digitalWrite(inBpin[motor], LOW);
  analogWrite(pwmpin[motor], 0);
void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
  digitalWrite(inApin[motor], HIGH);
  digitalWrite(inBpin[motor], HIGH);
void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
  if (motor <= 1)
    if (direct <=4)
      // Set inA[motor]
      if (direct <=1)
      else
      // Set inB[motor]
      if ((direct==0)||(direct==2))
      else
      analogWrite(pwmpin[motor], pwm);
void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
  // more readable function than Jim's (for educational purpose)
  // but 50 octets heavier ->  unused
  if (motor <= 1 && direct <=4)
    switch (direct) {
      break;
      break;
      break;
      break;
// testPot
void testPot(){
  Serial.print(analogRead(potL));
  Serial.print(";");
  Serial.println(analogRead(potR));
  delay(250);
void testpulse(){
  int pw=120;
  while (true){
    motorGo(motLeft, FW, pw);
    delay(250);
    motorOff(motLeft);
    delay(250);
    motorGo(motLeft, RV, pw);
    delay(250);
    motorOff(motLeft);
    delay(500);
    motorGo(motRight, FW, pw);
    delay(250);
    motorOff(motRight);
    delay(250);
    motorGo(motRight, RV, pw);
    delay(250);
    motorOff(motRight);
    Serial.println("testpulse pwm:80");
    delay(500);
// Function: convert Hex to Dec
int NormalizeData(byte x[3])
  int result;
  if ((x[2]==13) || (x[2]=='R') || (x[2]=='L'))  //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
    x[2]=x[1];  //move MSB to LSB
    x[1]='0';     //clear MSB
  for (int i=1; i<3; i++)
    if (x[i]>47 && x[i]<58 ){//for x0 to x9
      x[i]=x[i]-48;
      if (x[i]>64 && x[i]<71 ){//for xA to xF
      x[i]=(x[i]-65)+10;
  // map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
  result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
  return result;
Next, I created the engine mounts on the frame
4230
4228
4229
4222
4216
It remains to connect the linear potentiometers to their respective drive shafts. I created a connection shaft 6mm, connecting it to the motor shaft with M5x0.8 thread. I added Loctite to have more resistance to unscrewing. Fixed the connecting shaft, I have created a bracket for supporting the linear potentiometer, and connect it, with "firm metal cable 6mm", in axis with the motor shaft.
4235
4233
4217
4231
4221
4215
4225
Many details are missing, unfortunately a lot of pictures were lost. But the end result is remarkable.
Connected all. The simulator is ready for use.
4213
1°test
https://www.youtube.com/embed/rMvdPpXldcU
after arranging and painted the frame
2°test (my father)
https://www.youtube.com/watch?v=_V7qReoXTrI
impalone
Re: 2 dof (wiper motor - arduino - motomonster)
Postby RagnarFAH » Tue 13. Dec 2016, 06:39
Que tal
Ya que soy nuevo en esto y me acabo de comprar un logitech g27 quiero precisar de tu ayuda para poder construirme un 2 dof y si tiene tiempo que me hagas un acompañamiento paso a paso ya que después de ver muchos tutoriales y leer muchos foros quede totalmente confundido.
Como también soy nuevo en la pagina quisiera saber si hay algún meto por el que nos podamos comunicar por privado de manera que pueda ser mas fluida la conversación.
Desde ya muchas gracias
Saludos desde Paraguay
RagnarFAH :!: :!:
RagnarFAH
Postby impalone » Tue 13. Dec 2016, 22:36
RagnarFAH wrote:Que tal
RagnarFAH :!: :!:
Hola, puedo tratar de hablar a través de un traductor. Desafortunadamente través de este foro aprendí la cantidad de trabajo que hay dientro cada puesto y si le hemos proporcionado todo el apoyo privado no habría ninguna información útil para la comunidad en línea. Así que puedo ofrecer todo el apoyo necesario atramite este post. Pídeme lo que quieras a continuación y tal vez abrir un post de su propia área reservada para proyectos en construcción.
impalone
Users browsing this forum: No registered users and 77 guests
