2DOF Simulator with Moto Monster
Postby Bora » Wed 31. Aug 2016, 18:57
I have just started my 2DOF project and i only made electronics and programming.
Some photos about my projects;
X-Sim Calibrations;
4178
4179
4180
4181
This is the platform for controling and testing the motion and it's also a prototype;
4304
4303
4302
4300
Simulator Motors and Motor Driver links with Arduino Uno;
4301
The Simulator Code:
Code: Select all
 /* Arduino code for dynamic playseat 2DOF
 Created 24 May 2011 by Jim Lindblom   SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
 Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
 Updated 20 May 2013 by RacingMat in english http://www.x-sim.de/forum/posting.php?mode=edit&f=37&t=943&p=8481  in french : http://www.gamoover.net/Forums/index.php?topic=27617
 Updated 30 April 2014 by RacingMat (bug for value below 16 corrected)
#define BRAKEVCC 0
#define RV  2 //beware it's depending on your hardware wiring
#define FW  1 //beware it's depending on your hardware wiring
#define STOP 0
#define BRAKEGND 3
#define pwmMax 255 // or less, if you want to lower the maximum motor's speed
const int potMini=208;
const int potMaxi=815;
#define motLeft 0
#define motRight 1
#define potL A0
#define potR A1
//  DECLARATIONS
/*  VNH2SP30 pin definitions*/
int inApin[2] = {
  7, 4};  // INA: Clockwise input
int inBpin[2] = {
  8, 9}; // INB: Counter-clockwise input
int pwmpin[2] = {
  5, 6}; // PWM input
int cspin[2] = {
  2, 3}; // CS: Current sense ANALOG input
int enpin[2] = {
  0, 1}; // EN: Status of switches output (Analog pin)
int statpin = 13;  //not explained by Sparkfun
/* init position value*/
// INITIALIZATION
void setup()
  // serial initialization
  Serial.begin(115200);
  digitalWrite(statpin, LOW);
  for (int i=0; i<2; i++)
    pinMode(inApin[i], OUTPUT);
    pinMode(inBpin[i], OUTPUT);
    pinMode(pwmpin[i], OUTPUT);
    digitalWrite(inApin[i], LOW);
    digitalWrite(inBpin[i], LOW);
void loop()
  int sensorL,sensorR;
  readSerialData();   // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
  sensorR = analogRead(potR);  // range 0-1024
  sensorL = analogRead(potL);  // range 0-1024
void readSerialData()
  byte Data[3]={
    '0','0','0'          };
  if (Serial.available()>2){
    //parse the buffer : test if the byte is the first of the order "R"
    Data[0]=Serial.read();
    if (Data[0]=='L'){
      Data[1]=Serial.read();
      Data[2]=Serial.read();
      //  call the function that converts the hexa in decimal and that maps the range
      DataValueR=NormalizeData(Data);
    if (Data[0]=='R'){
      //  call the function that converts the hexa in decimal and maps the range
      DataValueL=NormalizeData(Data);
  if (Serial.available()>16) Serial.flush();
  //could be a parameter read from a pot on an analogic pin
  int gap;
  int pwm;
  int brakingDistance=30;
  gap=abs(targetPos-actualPos);
  if (gap<= Tol) {
  else {
    pwm=195;
    if (gap>50)   pwm=215;
    if (gap>75)   pwm=235;
    if (gap>100)  pwm=255;
    pwm=map(pwm, 0, 255, 0, pwmMax);  //adjust the value according to pwmMax for mechanical debugging purpose !
    // go forward (up)
    // go reverse (down)
void motorOff(int motor){ //Brake Ground : free wheel actually
  digitalWrite(inApin[motor], LOW);
  digitalWrite(inBpin[motor], LOW);
  analogWrite(pwmpin[motor], 0);
void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
  digitalWrite(inApin[motor], HIGH);
  digitalWrite(inBpin[motor], HIGH);
void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
  if (motor <= 1)
    if (direct <=4)
      // Set inA[motor]
      if (direct <=1)
      else
      // Set inB[motor]
      if ((direct==0)||(direct==2))
      else
      analogWrite(pwmpin[motor], pwm);
void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
  // more readable function than Jim's (for educational purpose)
  // but 50 octets heavier ->  unused
  if (motor <= 1 && direct <=4)
    switch (direct) {
      break;
      break;
      break;
      break;
// testPot
void testPot(){
  Serial.print(analogRead(potL));
  Serial.print(";");
  Serial.println(analogRead(potR));
  delay(250);
void testpulse(){
  int pw=120;
  while (true){
    motorGo(motLeft, FW, pw);
    delay(250);
    motorOff(motLeft);
    delay(250);
    motorGo(motLeft, RV, pw);
    delay(250);
    motorOff(motLeft);
    delay(500);
    motorGo(motRight, FW, pw);
    delay(250);
    motorOff(motRight);
    delay(250);
    motorGo(motRight, RV, pw);
    delay(250);
    motorOff(motRight);
    Serial.println("testpulse pwm:80");
    delay(500);
// Function: convert Hex to Dec
int NormalizeData(byte x[3])
  int result;
  if ((x[2]==13) || (x[2]=='R') || (x[2]=='L'))  //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
    x[2]=x[1];  //move MSB to LSB
    x[1]='0';     //clear MSB
  for (int i=1; i<3; i++)
    if (x[i]>47 && x[i]<58 ){//for x0 to x9
      x[i]=x[i]-48;
      if (x[i]>64 && x[i]<71 ){//for xA to xF
      x[i]=(x[i]-65)+10;
  // map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
  result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
  return result;
For the time being that's all but I'm continuing this project and I wanna ask you a couple of questions;
1- My motors have 55 rpm is it good i guess it is fast. If I use 45 rpm wiper motor will there be a change about simulator speed ?
2-If I choose 2DOF_Standard_combined or 2DOF_Standard_non_combined in X-Sim Converter are they gonna work properly with my simulator ? Because I don't wanna do profiling , is there any simple way for this condition?
Thanks for everything....
Bora
Images: 12
Re: 2DOF Simulator with Moto Monster
Postby Danphop » Fri 14. Oct 2016, 21:00
hi, just a thought to maybe answer your question regarding connecting the pots to the motor shafts. check out my work in progress.
viewtopic.php?f=37&p=19910#p19910
Danphop
Images: 13
Postby Bora » Sat 15. Oct 2016, 23:10
thank you so much,that's so useful. I'll try it ;)
Bora
Images: 12
Postby simulator1987 » Sat 26. Nov 2016, 11:05
http://mudesoglublog.blogspot.com.tr kafandaki soru işaretlerinin cevabı burda kardeşim
simulator1987
Postby Bora » Sat 17. Dec 2016, 02:10
Eyvallah abi şuan için küçük bi kit yapıp motorlara oyuna senkron hareket verdim ancak tam sistemi kurmak için motor milleri ile küresel(danagözü) mafsalları nasıl bağlayacağım hakkında ve de motorların ne kadar yük kaldıracağı konusunda kafamda soru işaretleri var.
Bora
Images: 12
Postby gokhan » Sun 15. Jan 2017, 16:13
dostum bende türküm malzemeleri almayı planlıyorum
sen naptın bittimi proje nasıl tavsiye edermisin :D
gokhan
Postby Bora » Sat 21. Jan 2017, 16:26
Merhaba Gökhan,
Projede şuan malzemeleri alıp küçük bir platform oluşturdum ve platform hareketlerini oyunla senkron hale getirdim yakın zamanda programı ve platformun videosunu atıp konuyu derleyeceğim.
Bora
Images: 12
