Just 1DOF, as I wanted to use an existing rig without having to really make any modifications to it (only had two days so time was limited).
Video:
(please excuse my bro's terrible driving, I should have probably turned some aids on or something).
Here's some pics...
- What I started with.
- Added a wheelchair motor to the back - In use it draws 15 amps @12V, not sure what sort of torque it generates as there's no label on it.
- Two low-friction wheels underneath provide stability.
- My living-room is carpeted, so I needed a frame for it all to ride on.
- Front: Potentiometer above the front bearing (made out of a broken caster wheel).
- An Arduino controls everything. (it'll look better when I have a box to put it in)
- I added a kill switch in case it all goes tits up and I need to turn the motor off sharpish.
Only got done an hour ago, didn't have time to fully calibrate the endpoints properly... It's currently only using ~75% of it's max deflection (max is 30 degrees both ways), and it's a bit jerky when making small movements. All this should be easily fixable though.
I had to write my own Arduino controller for the Monster Moto board. I tried this one but it was pretty basic and wasn't really suitable for this rig which has a lot on inertia / momentum and a relatively short potentiometer throw (60 degrees total, 30 on either side).
It was pretty cheap to make though:
- The original rig was entirely made out of reclaimed (free) timber, as was the base for it to roll around on.
- The seat was off an old truck I have rotting in a field.
- Wheelchair motor with 25:1 gearbox & drive wheel was £25 - EBay.
- Nylon trolley wheels were £10 - EBay.
- The Arduino is a clone, so was pretty cheap at £14 - EBay.
- The Monstor Moto was a knockoff and cost £15 - Deal Extreme (I had to order this quite a bit in advance, postage took ages).
- Assorted bits: potentiometer, tape, solder, etc. was probably an extra tenner.
Total: ~£70 (including all postage)
So yeah, that's "Skid Mk1".
For "Skid Mk2" I'll probably add some windscreen wiper motors to tilt the seat about and simulate G-forces.
