ARMO Race sim (start)
Postby amoras10 » Tue 6. Aug 2013, 23:20
Hello all,
Got back to project, but now more advanced ;],
i already got my electric stuff, now the big question is where to get proper schematic, how to connect all and test,
after that i already have drawings for my rig.
Now i have:
Arduino uno r3 with atmega328p-pu
10K POT
H-DRIVE from ebay
TOP view H-drive
H-Drive bottom side of motor connection in and?
12V is from computer power supply (650w)
I was using these drivers and connection schematic:
But NO result at all.
First, arduino installed and set to 57600 in com port settings (windows)
Second, i downloaded from x-sim
viewtopic.php?f=39&t=723 firmware and uploaded to arduino uno threw software (arduino)
Third i did connections for 1motor as shown i that picture or arduino post
Result NOTHING :(((((
SO GUYS :] help me to connect correctly everything, i think that i connect arduino correctly, uploaded firmware too, but
but question is which positions and which wires to connect on H-DRIVE???? Maybe you can provide me some paintings how to connect correctly???
thnx everyone for support.
amoras10
Re: ARMO Race sim (start)
Postby sirnoname » Tue 6. Aug 2013, 23:29
You did read the post?
Especially the part below the schematic and the part of the wiring information and where you can find it?
This bridge is not compatible with the firmware, you have to change the output code to drive such a device. The PID part will be the same.
Postby amoras10 » Tue 6. Aug 2013, 23:34
emz which firmware is then good for this h-bridge?
can you give me a link?
yes i read all pages after post.
amoras10
Postby sirnoname » Tue 6. Aug 2013, 23:38
No, I can't. You must program it by yourself.
This are only about 4 more lines in the output code. You have to get into what this bridge needs and then you have to set the correct bits.
Postby amoras10 » Wed 7. Aug 2013, 08:15
oh shit....
Then..., which ebay h-drives to buy what has firmware support already? any advise?
amoras10
Postby sirnoname » Wed 7. Aug 2013, 09:29
What do you think about the subsection "H-Bridge reqirements:" in the post you should read?
Postby amoras10 » Wed 7. Aug 2013, 10:23
ok i'll try
amoras10
Postby RufusDufus » Wed 4. Sep 2013, 13:56
Hi, these H-Bridges can be used with the Arduino XPID firmware.
You need to:
1. connect the H-Bridge R_EN and L_EN pins together and link to the Arduino XPID PWM output
2. connect the H-Bridge RPWM to the Arduino XPID INPUT1
3. connect the H-Bridge LPWM to the Arduino XPID INPUT2
There is a schematic for the H-Bridge attached for confirmation...
IBT-2.pdf
(7.85 KiB) Downloaded 1464 times
RufusDufus
Postby amoras10 » Wed 4. Sep 2013, 15:12
RufusDufus wrote:Hi, these H-Bridges can be used with the Arduino XPID firmware.
You need to:
Ohhh man you save me couple bucks !
you save the day ! ;] thanks
amoras10
Postby chsieh123 » Fri 15. Nov 2013, 09:09
I have got the exact same hardware as yours. There is no problem using this H-Bridge with X-PID. The connection described by Armos is correct.
Please share your Sim building progress with us. Thanks
chsieh123
