2DOF with Arduino UNO and Monster Moto Shield
Postby soraz » Tue 2. Jul 2013, 15:33
actual assembly:
2431
...racing playseat or virtual reality ?
presentation video:
I start view this web site *.
After see other project like :
http://www.gamoover.net/Forums/index.php?topic=25907.0
viewtopic.php?f=37&t=842&p=7106&hilit=siki+luna#p7106
I decide to start my project.
1736
from car demolition
1733
(first version : wiper motor fiat 500)
1734
from a race car driver
1735
from a photovoltaic installer (aluminum profiles 40x40 mm)
profili alluminio
and after some time
primoassemblaggio
and more
1736
1737
now must assembly and test controller parts.
15/07/2013
with
power supply 12V 30A
1853
Arduino UNO R3
1854
Monster Moto Shield
1855
some pins and a cooling fins
1973
Assembled as you can see
1732
if you chose not to stack the two cards:
Arduino .../... Monster
... GND .../... GND pin
..... 5V .../... 5V
.. pin 4 .../... pin 4
.. pin 5 .../... pin 5
.. pin 6 .../... pin 6
.. pin 7 .../... pin 7
.. pin 8 .../... pin 8
.. pin 9 .../... pin 9
left pot
2303
right pot
2304
install arduino software and driver
load firmware from Racingmat found here
viewtopic.php?t=943
mount motor for test
(before check isolation = download/file.php?id=2523 or http://vos-playseat-stephaned61.xooit.f ... e.htm#p642)
1856
- Left Motor power attached in A1-B1
- Right Motor power attached in A2-B2
- Left pot 10k control connect in A5
- Right pot 10k control connect in A4
like reported from racingmat, prefer CERMET (ceramic + metal) track rather than cheap carbon track.
when you power on power supply and connect Arduino to usb (i use only usb 5v), motors move in middle position. if they move continuously, you must invert A4 with A5 wire.
if mount motors in opposite position remember to attach the wires in opposite ways for one motor and relative potentiometer (the centre remain in centre).
you can test motor movement with arduino serial monitor writing L00<cr>, LFF<cr>, R00<cr>, RFF<cr> and you can see move to lower and highest position.
1974
now i have install x-sim software 3.0.x.x
in converter i configure :
- output setup the USO interface selecting the available comport (for me COM6), 8 bit resolution, binary output, 115200,8,n,1
- in datapacket : L~a01~~13~R~a02~~13~
- with the break of : from 33 to 40 ms
1857
- Math Setup : i decide to follow the video tutorial in X-SIM 3 documents, named Professional profile making by yokoyoko with some adjustement in values
1858
1859
1860
1861
- Program setup : have enable auto start and stop triggers.
3788
the result can see here :
next step final assembly
when i received last part:
1923
i can assembly my racing playset:
1924
1926
1927
1928
adding some pics with quotations; total weight 73kg
220022012202
and after some electrical and mechanical adjustments
we decide to make first video:
now i must to improve motor's mounting
and adjust x-sim profiles for improve the playset movement.
we want to extend special thanks to:
Alfio, Jody, Luca, Matteo, Mauro, Paolo, Saverio, Walter, RacingMat and sirnoname
after a shorts tests broke both motor shafts
1946
therefore i decide to different motor assembly and now i have this structure.
1947
panoramic final assembly of playseat
after further problems with pots, decide to buy cermet pots
i hope have more long life
2094
and if my mounting calibration is not perfect, buy also flexible couplings
2093
assembled
2129
and now other tests.
20/09/2013
after some adjustment the playseat move ok with new cermet pots, also reduce the break in USO datapaket from 60 to 40ms.
in a few days post a new video with Race07.
today decide to install a safety switch to break motor power.
2119
this help me for a problem in power on sequence.
i have Arduino power from pc usb and 5v for pots is from arduino.
sametime in power on, my motors rotate * with the possibility of broken.
now i power on pc, attach arduino to usb, sit on playseat and release the power for motors.
21/09/2013
i decide to add a LKM1638 ver. 1.2 to my Arduino.
connect from Arduino to LKM1638 5 pins :
LKM1638 .../... Arduino UNO R3
... pin 1 .../... 5V
... pin 2 .../... 0V
... pin 3 .../... D4 (Clock o CLK)
... pin 4 .../... D5 (Data I/O o DIO)
... pin 5 .../... D3 (Strobe0 o STB0)
in actual Arduino code from RacingMat (viewtopic.php?t=1073), import code extracted from tronicgr (viewtopic.php?t=155) with some adjustment.
for upload to board, remember to download library from http://code.google.com/p/tm1638-library/
and import in arduino programmer
2302
Code: Select all
     Arduino code for dynamic playseat 2DOF - *banned forum, plz support the X-Sim developers by removing this link* www.X-sim.de
     Created 24 May 2011 by Jim Lindblom   SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
     Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
     Updated 20 May 2013 by RacingMat in english http://www.x-sim.de/forum/viewtopic.php?f=37&t=943 in french : http://www.gamoover.net/Forums/index.php?topic=27617
     Updated 26 Sep 2013 by Soraz for adding dashboard http://www.x-sim.de/forum/viewtopic.php?t=1103
     Updated 15 Dec 2013 by Soraz improve motor perfomance with dashboard refresh timed and other
    // USO command to play : L~a01~R~a02~M~a03~S~a04~G~a05~
    // USO command to simulatorstop : Z00
    // L : left motor  (8bit - hexadecimal output)
    // R : right motor (8bit - hexadecimal output)
    // M : rpm              (16bit - binary output)
    // S : speed            (16bit - binary output)
    // G : gear             (16bit - binary output)
    // Z : clear            (to clear display and max rpm value)
    // Arduino wiring
    // for motors
    // Pin A4 : pot right
    // Pin A5 : pot left
    // for dashboard
    // Pin D3 : STB0 - strobe
    // Pin D4 : CLK - clock
    // Pin D5 : DIO - data
    // DashBoard include
    #include <TM1638.h> //can be downloaded from http://code.google.com/p/tm1638-library/
    // define a module on data pin 5, clock pin 4 and strobe pin 3
    TM1638 module(5, 4, 3);
    #define BRAKEVCC 0
    #define RV  2 //beware it's depending on your hardware wiring
    #define FW  1 //beware it's depending on your hardware wiring
    #define STOP 0
    #define BRAKEGND 3
    #define pwmMax 255; // or less, if you want to lower the maximum motor's speed
    const int potMini=208;
    const int potMaxi=815;
    #define motLeft 0
    #define motRight 1
    #define potL A5
    #define potR A4
    //  DECLARATIONS
    /*  VNH2SP30 pin definitions*/
    int inApin[2] = {7, 4};     // INA: Clockwise input
    int inBpin[2] = {8, 9};     // INB: Counter-clockwise input
    int pwmpin[2] = {5, 6};     // PWM input
    int cspin[2] = {2, 3};      // CS: Current sense ANALOG input
    int enpin[2] = {0, 1};      // EN: Status of switches output (Analog pin)
    int statpin = 13;           // not explained by Sparkfun
    /* init position value*/
    unsigned int DataValueL=512;         // middle position 0-1024
    unsigned int DataValueR=512;         // middle position 0-1024
    int sensorL,sensorR;        // for left and right pots
    // for dashboard
    int i;
    unsigned long tt;           // holds milliseconds
    unsigned int offset = -32767; // holds offset for dashboard
    unsigned int carspeed;      // holds the speed data (0-65535 size)
    unsigned int gear;          // holds gear value data (0-65535 size)
    unsigned int rpm;           // holds the rpm data (0-65535 size)
    unsigned int rpmleds;       // holds the 8 leds values
    unsigned int rpmmax = 5000; // retrieves from rpm live with minimum setting on initialization and simulatorstop
    byte speeddata = 0;         // marker that new data are available
    byte geardata = 0;          // marker that new data are available
    byte rpmdata = 0;           // marker that new data are available
    // char* neutral = "n";        // sets the character for neutral
    char* neutral = "0";        // sets the character for neutral
    char* reverse = "r";        // sets the character for reverse
    String namesz = "88888888"; // sets a custom logo start up banner
    String name = "X-Sim 3";    // sets a custom logo start up banner
    // INITIALIZATION
    void setup()
      // serial initialization
      Serial.begin(115200);
      // initialize the screen with leds test
      // module.clearDisplay();                       // clears the display from garbage if any
      // module.setDisplayToString(name);             // prints the banner
      // delay(1000);                                 // small delay 1 sec
      module.setDisplayToString(namesz);           // prints the banner
      module.setLEDs(0b11111111 | 0b00000000<< 8); // all green leds
      module.setLEDs(0b00000000 | 0b11111111<< 8); // all reds leds
      module.setLEDs(0b00000000 | 0b00000000<< 8); // turn off all leds
      digitalWrite(statpin, LOW);
      for (int i=0; i<2; i++)
        pinMode(inApin[i], OUTPUT);
        pinMode(inBpin[i], OUTPUT);
        pinMode(pwmpin[i], OUTPUT);
        digitalWrite(inApin[i], LOW);
        digitalWrite(inBpin[i], LOW);
    void loop()
      readSerialData();   // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
      // read actual position
      sensorR = analogRead(potR);  // range 0-1024
      sensorL = analogRead(potL);  // range 0-1024
      // move new position
      // refresh digit every 260ms
      // minimum recommended 120ms
      if ((millis()-tt) > 260){
        // update dashboard
        dashboard();
        tt = millis();
    void readSerialData()
      byte Data[3]={'0','0','0'};
      // parse the buffer
      if (Serial.available()>2){
        Data[0]=Serial.read();                   // read command
        if (Data[0]=='L'){                       // if right motor data
          Data[1]=Serial.read();                 // store high byte
          Data[2]=Serial.read();                 // store low byte
          DataValueL=NormalizeData(Data);        // converts the hexa in decimal and that maps the range
            Data[0]=Serial.read();               // re-read command
        if (Data[0]=='R'){                       // if left motor data
          DataValueR=NormalizeData(Data);        // converts the hexa in decimal and that maps the range
        if (Data[0]=='M'){                       // if rpm data
          rpm = ((Data[1]<<8) + Data[2]);        // concatonate bytes (shift 8 bits)
          rpm = rpm + offset;                    // offset
          rpmdata=1;                             // we got new data!
        if (Data[0] == 'S' ){                    // if speed data
          carspeed = ((Data[1]<<8) + Data[2]);   // concatonate bytes (shift 8 bits)
          carspeed = carspeed + offset;          // offset
          speeddata=1;                           // we got new data!
        if (Data[0] == 'G' ){                    // if gear data
          gear=((Data[1]<<8) + Data[2]);         // concatonate bytes (shift 8 bits)
          gear = gear + offset;                  // offset
          geardata= 1;                            // we got new data!
        if (Data[0] == 'Z' ){                          // if simulatorstop
          rpmmax=5000;                                 // reset rpmmax
          module.clearDisplay();                       // clear display
          module.setLEDs(0b00000000 | 0b00000000<< 8); // clear leds
      if (Serial.available()>40) Serial.flush();
    void dashboard()
      if (speeddata == 1) {
        // filter of negative value
        // reported from 65535 to down in Richard Burns Rally
        if (carspeed > 50000){                            // reverse velocity in some games are negative value
          carspeed = 65536 - carspeed;                    // convert positive with 16bit value
        module.setDisplayToDecNumber(carspeed, 0, false); // displays numerical the speed
        speeddata=0;
      if (geardata == 1) {
        if (gear >= 1 and gear <10 ){
          module.setDisplayDigit(gear, 0, false);         // displays numerical value of the current gear
        if (gear == 0){
          module.setDisplayToString(neutral, 0, 0);       // displays the character for neutral
        if (gear == (65535)){                             // -1 that reprecents reverse rollover so...
          module.setDisplayToString(reverse, 0, 0);       // displays the character for reverse
        geardata=0;
      if (rpmdata == 1) {
        // auto set max rpm
        // with filter of negative value
        // reported from 65535 to down in Kart racing Pro
        if (rpm>rpmmax && rpm<50000) {
          rpmmax=rpm;
        rpmleds = map(rpm,0,rpmmax*1.1,0,9);              // distributes the rpm level to the 8 leds + 1 for shift change
        if (rpmleds==0){
        if (rpmleds==1){
          module.setLEDs(0b00000001 | 0b00000000<< 8 );
        if (rpmleds==2){
          module.setLEDs(0b00000011 | 0b00000000<< 8 );
        if (rpmleds==3){
          module.setLEDs(0b00000111 | 0b00000000<< 8 );
        if (rpmleds==4){
          module.setLEDs(0b00001111 | 0b00000000<< 8);
        if (rpmleds==5){
          module.setLEDs(0b00011111 | 0b00000000<< 8);
        if (rpmleds==6){
          module.setLEDs(0b00011111 | 0b00100000<< 8 );
        if (rpmleds==7){
          module.setLEDs(0b00011111 | 0b01100000<< 8 );
        if (rpmleds==8){
          module.setLEDs(0b11111111 | 0b1111111111<< 8 );
        rpmdata=0;
      // could be a parameter read from a pot on an analogic pin
      int gap;
      int pwm;
      int brakingDistance=30;
      gap=abs(targetPos-actualPos);
      if (gap<= Tol) {
      else {
        pwm=195;
        if (gap>50)   pwm=215;
        if (gap>75)   pwm=235;
        if (gap>100)  pwm=255;
        // go forward (up)
        // go reverse (down)
    void motorOff(int motor){ //Brake Ground : free wheel actually
      digitalWrite(inApin[motor], LOW);
      digitalWrite(inBpin[motor], LOW);
      analogWrite(pwmpin[motor], 0);
    void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
      digitalWrite(inApin[motor], HIGH);
      digitalWrite(inBpin[motor], HIGH);
    void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
      if (motor <= 1)
        if (direct <=4)
          // Set inA[motor]
          if (direct <=1)
          else
          // Set inB[motor]
          if ((direct==0)||(direct==2))
          else
          analogWrite(pwmpin[motor], pwm);
    void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
      // more readable function than Jim's (for educational purpose)
      // but 50 octets heavier ->  unused
      if (motor <= 1 && direct <=4)
        switch (direct) {
          break;
          break;
          break;
          break;
    // Function: convert Hex to Dec
    int NormalizeData(byte x[3])
      int result;
        // x1
        if ( x[1]>47 && x[1]<58 ){//for xA to xF
          x[1]=x[1]-48;
        if ( x[1]>64 && x[1]<71 ){//for x0 to x9
          x[1]=x[1]-55;
        // x2
        if ( x[2]>47 && x[2]<58 ){//for xA to xF
          x[2]=x[2]-48;
        if ( x[2]>64 && x[2]<71 ){//for x0 to x9
          x[2]=x[2]-55;
      // map the range from simulator (0 <-> 255 - 8bit data) to the mechanically authorized range (potMini <-> potMaxi)
      result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
      return result;
and converter setup
Output Setup USO - RPM, Speed, Gear (16 bit, binary output)
2374
2373
2372
Output Setup USO - Command
with this string also change my left and right axis from 'binary output' to 'hexadecimal output'
in simulatorstop add Z00 to some reset needed if change car or game without reload Arduino code
2377
2375
2376
Math setup (0-32768) for Speed (Extractor input:56), RPM (Extractor input:57), Gear (Extractor input:60)
2135
i test this code with Race07, Kart Racing Pro and Dirt2
a sample video :
23/09/2013
post video with Race07 with cermet pots, dashboard (with same Arduino for wiper motor) and last profile with roll, pitch and vertical force (thanks to yokoyoko).
26/12/2013
added handbrake :
i have attach a micro-switch in parallel of a button inside the steering whell
2398
24002399
05/01/2014
added blue led strip
before .................. after
243224312430
soraz
Images: 67
Been thanked: 7 times
Re: 2DOF with Arduino UNO and Monster Moto Shield
Postby gaevulk » Wed 3. Jul 2013, 02:02
big! congratulations for the project!
gaevulk
Images: 9
Postby RacingMat » Wed 10. Jul 2013, 13:00
you can follow and trust Lipide512's design :-) in the first post you mentionned
I'm glad the Arduino code is working fine for you !!
You did a good job ! Waiting for more pics and videos !!
Postby soraz » Tue 30. Jul 2013, 21:45
i have mount the playset balanced with a person on.
when i power on arduino, playset vibrates more if no one is sitting.
how to fix this ?
thanks for any advance.
soraz
Images: 67
Postby RacingMat » Tue 30. Jul 2013, 23:09
Okay ! Let's check some points :
Have you isolated your motors ?
Postby soraz » Thu 1. Aug 2013, 21:08
electrically or mechanically ?
what you refer to ?
1924
soraz
Images: 67
Postby RacingMat » Thu 1. Aug 2013, 21:36
Electrically !
I'll search the link for you where it is explained !
edit :
one URL http://vos-playseat-stephaned61.xooit.fr/t7-Creation-d-un-simulateur-automobile-2DOF-avec-des-moteurs-d-essuie-glace.htm#p642
and one pdf attached
tutomoteur mahaow.pdf
Tutorial isolation électrique moteurs / how to isolated electrically the wiper motors
(182.08 KiB) Downloaded 3760 times
Postby soraz » Thu 1. Aug 2013, 21:54
have some doubts in this
i have a power connected to monster motor shield (pwr + and -) and output to motors (A1-B1 and A2-B2)
to the same power are conneted all fan.
soraz
Images: 67
Postby soraz » Thu 1. Aug 2013, 22:01
ops....
now read and modify.
thanks
soraz
Images: 67
Postby soraz » Thu 1. Aug 2013, 22:33
ok,
translated, readed and verified.
my motors (fiat panda) has no wire connected to the metal.
the two incoming wires are connected to the two motor brushes.
soraz
Images: 67
