Ultimate MSXR 3/4DOF
Re: Ultimate MSXR 3/4DOF
Postby Riton » Sat 13. Apr 2013, 19:44
I received the last trees and the last ball.
I prepare the case, I bought used a 3rd frequency.
I received the new extension 6DOF Thanos.
I still have a can of cutting, and when everything is ready, I'll prepare Welding fixtures, then solder
13931395139413921285
Riton
Images: 70
Been thanked: 16 times
Postby Riton » Fri 17. May 2013, 09:07
hello,
some new
The last parts are being machined, all item will be cut soon.
153815371536
I made the latest design plans.
Here is an example of what will be the Ultimate Machine:
1539
Riton
Images: 70
Postby Riton » Fri 17. May 2013, 09:24
1540
Riton
Images: 70
Postby vicpopo » Fri 17. May 2013, 11:34
Salut Richard,
Ça c'est une machine!!
Wouahh !! That will be a amazing simulator ! Thanks for sharing your simulator building! ;)
Postby tronicgr » Fri 17. May 2013, 18:11
That's really cool! Finally a good DIY Force Dynamics 4DOF ! :)
Postby Riton » Sat 18. May 2013, 23:13
I hope! the first tests will confirm...
Riton
Images: 70
Postby Riton » Mon 20. May 2013, 19:24
summary video
I waiting the final machining, then stripping sanding and sealing of the first elements
Riton
Images: 70
Postby RacingMat » Thu 6. Jun 2013, 20:26
hello !
Nice cuts !
it seems that the Evo355 raptor is doing a good job !
Is there any gap in this machine after this work ? did it became loose ?
or is it still tightened ?... I intend to buy one ;-)
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Jolis débits de profilés métalliques !! on dirait bien que la EVO355 Raptor est impeccable
Après ce boulot, elle a pris du jeu ?
ou elle est restée bien guidée ?... j'ai l'intention d'en acheter une pour ma prochaine construction ;-)
bonne continuation !!!
Mat
Postby Riton » Fri 7. Jun 2013, 08:24
Hi
it's a 355 EVO 355mm
the frame of the saw has no games running through against the saw blade shows weakness.
if I cut flat it becomes difficult to cut.
if I attack profile through a slice or an angle that cuts well.
there should be a carbide blade sharpener.
Salut
le châssis de la scie n'a aucun jeux de fonctionnement, par contre la lame de la scie montre des faiblesses.
si je coupe à plat ça devient difficile à couper.
si j'attaque les profilé en biais sur une tranche ou sur un angle ça coupe bien.
il faut prévoir une affûteuse de lame carbure.
Riton
Images: 70
Postby Riton » Wed 12. Jun 2013, 23:26
the last pieces are completed
edit
Riton
Images: 70
Users browsing this forum: No registered users and 60 guests
