CSX Motion Simulator
Re: Ynt: CSX Motion Simulator
Postby motiondave » Wed 26. Dec 2012, 23:41
nury961 wrote:
motiondave wrote:PID settings.
P 4/4
I 0/3
D 4/4
Max accell 400
Max Duty cycle 400
Max current 0
Max duty cycle while feedback is out of range 400.
Dunno about effects with FSX...
I did some exercises on the given parameters... but want to get some effect number to put them in math setup... any help???
GT-I9300 cihazımdan Tapatalk 2 ile gönderildi
http://www.youtube.com/watch?v=PQaKTaKEvCo video of how to make a profile, maybe it will help.
Postby nury961 » Wed 26. Dec 2012, 23:49
motiondave wrote:
P 4/4
I 0/3
D 4/4
Max accell 400
Max Duty cycle 400
Max current 0
Dear motiondave... thank you for your answer ..i saw this video maybe 5-6 times... the problem is which effect should be in math setup... x lateral acceleration which is number 29 is only one i *... can you give me another effect for pitch or bank effects???
Thanks a lot !
nury961
Images: 12
Re: CSX Motion Simulator
Postby motiondave » Thu 27. Dec 2012, 14:10
Just use the drop down list to find the force you want.
I only use lateral as an example, refer to the video and you will see the drop down list.
Postby sirnoname » Fri 4. Jan 2013, 18:18
Hi there, please also update your first thread, this will be the post others will read!
The first picture in the first thread will be shown as project gallery picture, you do not have one.
Postby nury961 » Sat 12. Jan 2013, 11:47
sirnoname wrote:Hi there, please also update your first thread, this will be the post others will read!
thank you for your information given...
I want to give you some details about the current situation...
I am doing the turning effects from the center of the platform, because of that I have to have more power to turn 150 kg which includes me and the platform itself.
Firstly I put 1:54 gear on my 2400 rpm 250 watt motor but that was so fast for FSX, finally I add second gear to the end of first gear, the second gear has a ratio of 1:16... now the output of motor is 3,24 rpm. the speed of platform is very good for now, I did the angles max 35 degree but need to decrease 25 degree because at the 35 degree you have to hold somewhere for not throwing out of platform.
I have a serious problem that I want to ask to sim experts,
I use pololu cards; but I think the communication between the card and converter is not so fast because the target changes simultaneously not continuosly, I mean when the airplane turn 30 degree to the left, ıt divides the 5 or 6 pieces and send the commands one by one, I think I cannot explain good but mainly when turning right or left it turns but like start stop...
If I can add a video I can explain it I think... but first of all does anyone had this problem and solved it? or is it pololu communication caracteristic?
Thanks a lot !
nury961
Images: 12
Postby motiondave » Sat 12. Jan 2013, 14:03
might be best if you post a video, also post all pics of jrk utility setup and one pic of converter in output section, to see USO commands
Postby nury961 » Sun 27. Jan 2013, 04:29
Dear Motiondave sorry for the late response, I didnt get time to work on simulator, but today I changed alot of things with my simulator...
Up to today I wanted to rotate my platform from center axis, because of that I bought 250watt 2400 rpm 12 v motors... after all I assembled 1:54 gear and then another 1:16 gear to get more power, because I couldnt get motion when the angle is more than 25 degree... So today I decided to change the system and did pulley system from the corner like thanos joyrider system. That seems ok with respect to old system but almost I have a problem with having non-continuous movement of platform.
My PID settings : 25/0 , 0/3 , 1/3 ( I know 25/0 is high but when I lower it platform power is decrease)
I use effect nr 29 for bank effect with a value of 6000.
I couldnt get some photos because I forgot to take them sorry, but I think there should be a very simple problem with communication of computer and platform.
Thanks a lot !
nury961
Images: 12
Postby motiondave » Sun 27. Jan 2013, 09:16
no worries, take your time
Postby denizelmas » Mon 4. Mar 2013, 00:41
what is your last position- a video? maybe
Mind Before Money,Creativity Before investment
denizelmas
Images: 16
Users browsing this forum: No registered users and 83 guests
