6 DOF Stewart platform prototype
Re: 6 DOF Stewart platform prototype
Postby hellraizer » Tue 6. Jan 2015, 12:31
Great work Guys!!! Kudos!!!
Like many other enthusiasts on this forum we all try and achieve 6DOF for as cheap as possible ;) or maybe it is just me! I'm also an Arduino fan which really highlighted your project! After seeing your post I wiped together 6 servos and an extra Arduino and started coding :roll:
Thank goodness there are some code snippets that helped with the maths I'm finally able to get movement. :o
But I'm a bit stuck with the "middleware" between X-Sim and the Arduino. I'm not sure how to configure X-Sim and the output then sent by X-Sim. In my opinion it does not matter on a small scale where the calculations happen to convert the output then sent by X-Sim to servo movement at this point. I just want end to end communication to take place from X-Sim to middleware (if needed) to Arduino.
Is there any advice that can be given here?
hellraizer
Postby kaiezer1980 » Thu 16. Jun 2016, 05:31
I have a problem with the code it shows me the error "uninitialized const 'servo_min' [-fpermissive]"
kaiezer1980
Postby lupus » Fri 24. Jun 2016, 01:05
I am at your same stage,,, did you solve this ?
lupus
Postby Gunni » Fri 2. Apr 2021, 16:56
there is a lot missing, where is the whole part of the serial input.
Gunni
Users browsing this forum: No registered users and 53 guests
