My home built 6DOF platform
Re: My home build 6DOF platform
Postby Riton » Fri 3. May 2013, 08:17
what is the real question?
Nominal working frequency of an inverter is 50 Hz
this frequency can be mounted at 100Hz.
But Lea Work with 50Hz.
this frequency is "adjusted" by the Thanos electronic .
Riton
Images: 70
Been thanked: 16 times
Postby lealjay » Tue 7. May 2013, 02:29
Hi , here's a video of my 6DOF platform using x-sim and thanos 6DOF plugin with Rfactor (i know i really need to put some oil)
lealjay
Images: 2
Been thanked: 9 times
Postby vicpopo » Tue 7. May 2013, 06:41
Hi Jeremy,
Yes please some grease ....
Looks great , it's a little bit difficult because we don't watch the car movements but it seems to work well.
I tried to watch the acceleration effect but dificult to make me a feeling.It seems ok for roll, vibration and brake.
It's a good news for my further 6dof!! :lol:
Postby motiondave » Tue 7. May 2013, 07:27
if its noisy, turn the volume up.... :D
Postby vicpopo » Tue 7. May 2013, 07:27
Hi Jeremy,
Could you make the same try with your PC connected to your video projector into your cockpit.
In this way we could watch the car movements and in the same time your simulator moving ?
Merci d'avance!
Gilles
Postby lealjay » Tue 7. May 2013, 19:53
Here's another video of my 6DOF but this time with Dirt 2 under x-sim and the 6DOF plugin by Thanos , i still need to tune up the profile a little bit but it's already good i think , finally i've put some oil so it's a lot better now ! no more noise !
http://www.youtube.com/watch?v=mSwyjoOSn7U
lealjay
Images: 2
Postby Racerr87 » Tue 7. May 2013, 21:04
Cool! 8-) keep them movies coming :geek:
wish i had the time and sources to build some thing like that.
are you running it at full speed?
Racerr87
Images: 7
Been thanked: 5 times
Postby lealjay » Tue 7. May 2013, 21:50
For Dirt 2 my profile need some tweaking for the movements , the motors are running at normal speed (50HZ) and can go up to 400HZ with the inverters !
lealjay
Images: 2
Postby lealjay » Wed 8. May 2013, 22:36
Here's a new video of my home built 6DOF platform with Nolimits Rollercoaster with Kodiak (round 4) track running under x-sim and Thanos 6DOF plugin .
As we can see , speed and reactivity are really good !
lealjay
Images: 2
Postby tronicgr » Wed 8. May 2013, 22:49
Wow!!! This is great!!! Great job!!!
Does it provide Yaw rotation as well?
