tronicgr wrote:You cannot use these magnetic encoders for quadrature encoding without reprogramming them (via SPI commands). They come ready for analog/PWM output signal only.
Also you cannot use quadrature encoders on AMC1.6 board yet as I haven't had the time for such upgrade yet. You could use a 10 turns potentiometer or a 25 turns to place it like on your schematic.
Also for the YAW rotation you could leave a potentiometer connected in middle position and let the motor rotate freely around accelerating to each direction. You will need a 0-ring sliding power adapter for that though.
tronicgr wrote:What I meant was that you can still connect a potentiometer and set it in middle position (value 127) BUT NOT connect it on the axle of the motor. This way you can still get correct direction and speed output but NO Position reference. This way the motor will keep rotating to one direction or the other simulating rotation (YAW) accelerations. Neat trick, huh??
Users browsing this forum: No registered users and 75 guests
