Sim Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Re: Sim Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Postby zecaEU01 » Sun 2. Dec 2012, 20:01
Buongiorno Kevin 123, forse in italiano è meglio?
Io sono una guida troppo qui in Brasile e si è parabeni per il vostro progetto e io sono con un dubbio.
Visualizza vm110n ha collegamenti con l'uscita digitale non capisco i collegamenti con 5V GND 08 05 01, l'immagine è troppo piccola, si potrebbe aiutarmi a un'immagine che è al di sotto parlare Partiamo dal K8055 VM110.
Ho messo l'immagine è dubbio all'interno del cerchio rosso ok.
grazie
Zeca
Hello Kevin 123, perhaps in Italian is better?
I am a guide too here in Brazil and has parabens for your project and I am with out a doubt.
View vm110n has connections with the digital output does not understand the connections with 5V GND 08 05 01, the image is too small, you could help me with an image that is below start from the talk K8055 VM110.
I put the image inside the red circle is definitely ok.
thanks
Zeca
zecaEU01
Postby floriske » Mon 3. Dec 2012, 11:20
Hi Zeca,
Would you mind posting in English as well? Posting in portuguese might confuse other readers. If you do prefer to talk to kevin in portuguese you can use personal message or the portuguese forum for that.
thx!
floriske
Images: 96
Postby zecaEU01 » Mon 3. Dec 2012, 11:42
Good morning floriske
Already made ​​the correction sorry
zeca
floriske wrote:Hi Zeca,
thx!
zecaEU01
Postby floriske » Mon 3. Dec 2012, 11:45
zecaEU01 wrote:Good morning floriske
zeca
thx!
No problem, thanks for adding english!
floriske
Images: 96
Postby kevin123 » Tue 4. Dec 2012, 20:18
zecaEU01 wrote:Buongiorno Kevin 123, forse in italiano è meglio?
grazie
Zeca
thanks
Zeca
Hi zeca
Even if you translate from Portuguese into Italian or German or Spanish at the end with google you can always tell the evil phrases :D
however see if the image fits this one looks better ...
What you say you are all digital outputs that I have not used in my configuration I used the analog outputs
I know that the digital outputs are used to control relays, however, I suggest you read your manual K8055 http://www.velleman.eu/downloads/0/modu ... vm110n.pdf ;)
Best Regard
Kevin
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby zecaEU01 » Tue 4. Dec 2012, 21:31
OK Kevin
I understand very well what you wrote and the pdf file was also very good and enlightening.
Big hug and salute
zeca
zecaEU01
Postby tronicgr » Tue 4. Dec 2012, 22:01
Just to remind you that the Sabertooth 2X12 and Sabertooth 2X12RC are not the same cards...
They have different input signals. :roll:
Postby zecaEU01 » Wed 5. Dec 2012, 13:04
Good morning tronicgr
You are quite right actually checking the 2x12RC she works with small engines and low torque.
I bought wrong.
Thank you
zeca
tronicgr wrote:Just to remind you that the Sabertooth 2X12 and Sabertooth 2X12RC are not the same cards...
zecaEU01
Postby floriske » Fri 7. Dec 2012, 16:14
Kevin has requested a topic for his project in the finished project section.
The new topic can be found here: viewtopic.php?f=36&t=620
This topic will be closed and further discussion about this great build can be done in the finished project section.
floriske
Images: 96
Users browsing this forum: No registered users and 60 guests
