Thanks for having stripped your seat! I'll watch your video tonight...
I'm curious : Can you explain why did you use 2 arduinos? as only 1 arduino can drive the 4 motors together. You expected to have a better refresh rate?
Thks
Mat
what linkage did you use from the belt wheels to the flaps?
Is there enough movement that the TrackIR picks it up and changes your view?
Do you ever fly Falcon mod BMS 4.32?
That's ok, it was a long time ago and the G Suit pneumatics were the biggest challenge.Bergison wrote:Hi Snake122,
thanks for your nice post! I'm sorry your G-Seat building didn't work out for you!
I can definitely see that you made a efficient setup as I saw at your site. I'm trying to find out what is the specific ball joint linkage types that go from the wheel to seat flap and also seat belt wheel to motor. They look like maybe car shifter linkages that go from the motor to wheel. Are the off the shelf parts or ones you made?My seat uses two different mechanical units for the back resp. the seat flaps/belts. The assembly can bee seen on some of the pictures here: http://meintourenbuch.net/simpit/g-seat-pictures I tried to keep it as simple as possible and therefore looked for a way to drive the belts and flaps each with one single motor. There might be other sulutions to this, but this setup is what fitted best into the limited space available inside the seat.
I agree! I just know the TrackIR can be pretty sensitive, glad to hear it is a non-issue (and thanks for the double reply to me over at Youtube). It's a lot like learning to fly and you finally learn to cobtrol the yaw with how you feel in the seat. Those are really small changes, something like this will be great. I also love the belts, it remeinds me of the first time I went inverted in a plane and was hanging in the harness!No, the movement of the seat does not affect the view at all! Thats the point in the G-Seat approach: the body is not really moving, you just feel the onset or removal of pressure and the brain interprets it as acceleration.
That's really the inly thing I see potentially stopping me from doing this, I pretty much only fly Falcon. I dabble with DCS and others, but anything I do is Falcon first. I've started to play with the x-sim software and hopefully can make it work.Although I flew Falcon 4.0 I have not tried BMS yet!
alphatoomega7 wrote:Just wanted to say that I've build a g seat and it is awesome. Thanks to Bergison for his guide and instructions.
