3DOF power simulator
Re: 3DOF power simulator
Postby tronicgr » Fri 24. May 2013, 19:08
prodigy wrote:What is going on here, in the last few weeks there are a lot of 6DOF and 3DOF projects, it feels like 2DOF is yesterdays news :)
Anyway, it looks good, show us the moves! :)
I think it has to do with the price tag of 3DOF and 6DOF that has dropped a lot lately... ;)
Regards
Postby thecure » Sat 25. May 2013, 00:19
next week...a short video :D
thecure
Been thanked: 5 times
Postby thecure » Sat 25. May 2013, 10:40
Racerr87 wrote:Very nice! How is the actuator moving?
in this way http://www.youtube.com/watch?feature=pl ... lDzDbicBTc
thecure
Postby Racerr87 » Sun 26. May 2013, 13:08
I know :) , i meant how is your actuator moving with that engine?
Racerr87
Images: 7
Postby basthard » Thu 6. Jun 2013, 20:16
Hello guys,
maybe tomorrow will post a video of the first test run ... :D
if we can solve the problem that we have seen;
when the system is under power (24Vdc), randomly on '"xsim2" (we do not have internet connection in the box :roll: ) comes a write error on a COM, the 3 in our case that sends us stalled everything! :evil: :evil:
you know what it could be? maybe the parameters of plugins for the game,
or the port settings? ... oooor
if it has happened to someone let us know how to fix it ... thanks
Basthard
basthard
Postby tronicgr » Thu 6. Jun 2013, 20:28
What controller are you using? Maybe its currents leaking from the motors and cause most of the interfaces USB "fuse" to disconnect...
Give some more details about what you have connected where and we might help find what's wrong.
If you can't afford to donate for the x-sim3 offline version, you could make a 3 page presentation of your simulator project to get an offline key. The old x-sim2 version is not very compatible with 64-bit or windows 8... and that might be another reason!
Best Regards,
Postby basthard » Thu 6. Jun 2013, 21:15
Thanks Thanos,
we are using 4 Pololu High-Power Motor Driver 24v23 CS
connected directly to the engine without any sort of insulators ...
we have them connected to the AMC 1.6 with the latest firmaware ...
We work with two PCs in the LAN network, one for games that running with win7 64bit, while the other that drives the AMC 1.6 running win7 32bit.
The Connection between the AMC and the Pololu has been done correctly, I think,
we know that no-load operation is perfect, continuously without jamming!
There is some doubt about just setting the time on the USO screen ...
maybe it is them that does not work?
thanks
then attach photos / videos if we can not solve ....
basthard
Postby basthard » Fri 7. Jun 2013, 13:01
PROBLEM SOLVED! (we believe) :D
This morning we checked the whole system and we realized
that in the box was not connected to ground ... so :oops: :oops: :oops:
In the afternoon, allowing patience, we will post a small demo video! :mrgreen:
Thank you for now see you soon!
basthard
Postby thecure » Fri 7. Jun 2013, 18:15
thecure
Postby Racerr87 » Fri 7. Jun 2013, 18:29
Looking good!! 8-)
Hopefully it will be as good under load!
Racerr87
Images: 7
