3 DOF Sarrus Amc1.6 DIY Dc-worm gear
Re: 3 DOF Sarrus Amc1.6 DIY -? driver-dc-worm gear
Postby denizelmas » Sat 24. Nov 2012, 21:01
motiondave wrote:
denizelmas wrote:
motiondave wrote:I agree on the build it yourself idea with the amc. Looks like you maybe be brainier than me with circuit boards :D .
Just a suggestion on JRK as it is almost plug and play and easy to set up.
The big motors look good. Quite a few guys here including me use big motors these days . Better, stronger and faster than wipers. Sometimes cheaper in comparison to cost of a new wiper.
oops again jrk, the joy, where is it, :?: shall I ask my friend for jrk together with atmega644 chip -- confused (look there is fuse! broken :D ) please encourage me ..... :lol: is there an option for a driver with feedback like jrk12v12 may be I may find here :?:
Not that I know of.
Advances are bring made with the AMC and research is being done on the Arduino as control boards that need separate h-bridges.
I want to try both in time as well, but for the time being, the boring old JRK will have to do.
Up to you, AMC is good, but needs assembly and parts, unless you can swindle Thanos to build you one for a cost, but at least you have the option of using whatever h-bridge you like. So if you find a fat 12v h-bridge, you can use that, or even 24 or 240v.
JRK is restricted to 13.8 volts at 30 amps continuous , but is an all in one.
thank you for comment,, but I will go with AMC (if tronicgr gives me the right order code for ATmega644 chip)
Mind Before Money,Creativity Before investment
denizelmas
Images: 16
Postby vicpopo » Sat 24. Nov 2012, 21:26
Hi ,
Atmega644 20pu(20 mhz ) ,look at the partlist in Thanos amc1.6 thread.
An exemple that I bought:
Best Regards
Postby denizelmas » Tue 27. Nov 2012, 15:43
vicpopo wrote:Hi ,
Best Regards
Thank you, I realized after I have send the message while digging another topic about ac motor I guess, BTW I checked your blog it fabolousso..
denizelmas
Images: 16
Postby denizelmas » Sat 1. Dec 2012, 17:50
motinedave,
when I want to add my progreses shall I do it on adit base or a new post? can you please guide me on that
denizelmas
Images: 16
Re: Ynt: 3 DOF Sarrus Amc1.6 DIY Dc-worm gear
Postby nury961 » Sat 1. Dec 2012, 20:56
denizelmas wrote:motinedave,
GT-I9300 cihazımdan Tapatalk 2 ile gönderildi
Thanks a lot !
nury961
Images: 12
Postby motiondave » Sun 2. Dec 2012, 00:42
If this is your original project, add it here...
Users browsing this forum: No registered users and 83 guests
