CSX Motion Simulator
Re: CSX Motion Simulator
Postby nury961 » Mon 26. Nov 2012, 15:07
Hello motiondave;
5 min ago I found only one 1 JRK from e-bay (turkey)... I paid 200 TL ( € 87,00 )...
Firstly I will do joyrider after a while when getting a little bit professional on X-sim I want to build very big motion simulator like the 360 degree 2 dof brasilian paltform..
What is your offer for motor selection, Should I use AC motor on that JRK ??? kw, rpm , torque...
Thanks a lot !
nury961
Images: 12
Postby motiondave » Mon 26. Nov 2012, 21:58
JRKS are only 12 volts so the most used is http://www.motiondynamics.com.au/worm-d ... -180w.html , or an ebay Equivalent.
If you are going to build a big simulator like the 360 deg rolling sim, you will need big 240v motors for sure. Not sure what to use on that.
Postby tronicgr » Tue 27. Nov 2012, 02:41
nury961 wrote:What is your offer for motor selection, Should I use AC motor on that JRK ??? kw, rpm , torque...
I would really love to see that! :shock:
Postby nury961 » Tue 27. Nov 2012, 11:26
I think I am also confused about some terminologies...sorry for mentioned AC motor, but I will do another sim with AMC644 + Servo's ;)
I selected 12VDC, 2800 rpm, 250w motor... Gearbox ratio 1:20... Any comments from sim experts???
Thanks a lot !
nury961
Images: 12
Postby motiondave » Tue 27. Nov 2012, 22:02
do you have a link for the motor? Looks good from those specs.
Postby nury961 » Wed 28. Nov 2012, 11:32
250w MUGUL.pdf
(34.31 KiB) Downloaded 893 times
Thanks a lot !
nury961
Images: 12
Postby motiondave » Wed 28. Nov 2012, 14:06
nury961 wrote:
250w MUGUL.pdf
Looks ok to me, they just need a gearbox
Postby nury961 » Wed 28. Nov 2012, 14:22
motiondave wrote:
nury961 wrote:
250w MUGUL.pdf
Gearbox 1:20 is it good enough??
Thanks a lot !
nury961
Images: 12
Postby motiondave » Thu 29. Nov 2012, 01:36
2800 / 20 = 140 rpm. Yep, ok.
Postby nury961 » Thu 29. Nov 2012, 13:43
Today I got my pololu cards, I think I bought the last 2 cards in Turkey, because I called maybe 10 dealer but they didnt have this card, last change I bought one from a person I dont know him, and the other bought from a very small dealer and asked for anothers but he said that this was the last one...
Thanks a lot !
nury961
Images: 12
