X-SIM 360° 3DOF Flight Simulator with VR
Re: X-SIM 360° 2DOF Flight Pit width XPID, Arduino
Postby asticher » Wed 4. May 2016, 00:50
"No Brain, No Pain"
asticher
Images: 20
Postby asticher » Tue 17. Oct 2017, 00:30
"No Brain, No Pain"
asticher
Images: 20
Postby scottgze » Thu 7. Dec 2017, 14:56
asticher -
Sehr gut!!
Keep working on the stick, I'm keen to see how you go with seperate aileron/ elevator forces.
Are you using the X-Sim FFB?
Danke
scottgze
Re: X-SIM 360° 2DOF Flight Pit width XPID and VR!
Postby asticher » Tue 22. Jan 2019, 23:06
Update: I added a Export lua with a 360° Pitch position finally!
https://drive.google.com/open?id=14ZJzK ... q1lrF7J0qb
Look for pitch_final. May this is usefull for you.
Value is now +0 to 3,14 and -3,14 to -0
Also i added a quarter detection (quarter_final), so you alway knows in what Quarter Pitch your AC is.
I try to use this Quarters now, to cancel the bank flip.
Therefor i switch to relative roll value (acc_x in m/s) when the roll flip zone advances.
"No Brain, No Pain"
asticher
Images: 20
Re: X-SIM 360° 3DOF Flight Pit width XPID and VR!
Postby asticher » Mon 1. Apr 2019, 00:28
Heads UP Pilots!
With this Export.lua for DCS World you can counter this Effekt!
https://drive.google.com/open?id=1Z7dsO ... EkotDJPCys
You can make forward / backward / inverted loops as you like,
For example, you can cancel the climb at 80° PitchUp,
You can even roll a bit at 90° pitch,
You can go up to 4 degrees off the track through the vertical.
If you don´t hit vertical, the "normal" Bankflip occours and Pitch will decrease as "normal".
Some rare miss behaviors and small stutters are still a issue, but you *..
Have Fun!
"No Brain, No Pain"
asticher
Images: 20
Postby guivi » Wed 26. Jun 2019, 00:15
Hola, yo tambien quiero armar un simulador de 2 DOF 360 grados de libertad. Me podes pasar las vueltas finales de pich y roll y las reductoras que relacion tienen como la potencia de los motores. Muchas gracias
guivi
Postby asticher » Wed 26. Jun 2019, 02:05
Sorry, no habla espanol. But everthing you ask for, you will find one the first post in this forum.
"No Brain, No Pain"
asticher
Images: 20
Engine reference
Postby Flight » Fri 9. Aug 2019, 11:06
Hello Asticher, to continue the discussion started in mp is what you could provide me the excate reference of Transtecno engines because I do not find the model on their site based on the information provided on the forum. Thank you in advance;
Marc
Flight
Postby asticher » Fri 9. Aug 2019, 11:40
"No Brain, No Pain"
asticher
Images: 20
Postby Flight » Mon 12. Aug 2019, 10:36
Okay thanks for the information , Asticher. I'll look into it
A+
MARC
Flight
Users browsing this forum: No registered users and 58 guests
