2DOF "motionkart" with Arduino/MonsterMoto
Re: 2DOF "motionkart" with Arduino/MonsterMoto
Postby wpjartsa » Tue 3. Feb 2015, 14:24
Problems with first serial test solved, at least it moves to the right directions now :lol: Still don't know what the problem with the movements ever was, just made the wires and connections rebuild and no problems anymore, seems like somewhere there was a connection failure or something like that.
https://www.youtube.com/watch?v=7LeHGMkpnMM
Next step x-sim setups & some game-installings.... got Grid2 ( steam ) , RBR and Dirt3....we will see if I ever manage to get some of those working...later then some tuning and part-assembly to the chassis itself to get this proto look a bit more beautiful as it does *
At first need a lot of studying of using and setting up x-sim :oops:
Young brains, swet inside.
wpjartsa
Images: 12
Postby wpjartsa » Thu 5. Feb 2015, 00:04
Little confucing *...Extractor in my gaming-PC seems to be quite ok, same the converter in the second PC ( laptop ) . Only communication between these is lost....network otherwise ok with both PC:s, connection between those by wire ( not wlan ).
Firewalls off, tried to clean registers with sim-tool, even re-installed x-sim etc, but still the converter says extractor not connected... Not so easy/simple cause I'm not an expert with computers either :?
wpjartsa
Images: 12
Postby wpjartsa » Thu 5. Feb 2015, 00:09
Here You can see the first random movements of this motionkart ( before the pots installed ) :mrgreen:
https://www.youtube.com/watch?v=34Mr9VHFRp4
wpjartsa
Images: 12
Postby RacingMat » Thu 5. Feb 2015, 15:43
very good! soon, you will have a good ride!!
