MY 2dof wiper motor seat mover
Re: MY 2dof wiper motor seat mover
Postby pipis2014 » Mon 22. Sep 2014, 20:15
No video yet ... the construction is not complete ... because i didn't have a lot of spare time to go on with the build.
No Cad either.
The steel sheets are 4mm thick.
You can see the chassis dimensions in the following pic:
3247
The motors are designed to work From -45 degrees to +45 degrees from rest (horizontal rod) position.
Why only +/- 45 degrees?
If you go above 45 degrees from resting point a lot of linearity is lost. That is above +/- 45 degrees ... the motors turn but the tilt speed is very slow compared to the rotation of the motor.
So a combined use of both motors can output a maximum of about :
10 degrees LEFT or RIGHT,
OR
5 degrees Front or BACK,
tilt on the seat.
3248
pipis2014
Images: 105
Been thanked: 5 times
Postby Petar2 » Mon 22. Sep 2014, 23:31
Thanks for the pictures and explanation, I will ponder the next step.
Just one thing, the answer is not the most efficient engines in both torque and rpm, working at 24V?
Petar2
Images: 30
Postby pipis2014 » Tue 23. Sep 2014, 11:41
Yes, you are right, if the motors are powered with 24 volt PSU the motion is faster, the torque may be A little more and the amperes will be probably less.
But if you want just to tilt the seat and not a platform of seat-steering wheel-pedals then the motion is ok.
If you want to be able to feel vibration also, then you might need 24volts.I will answer this as soon as I complete my rig and have it working with
sirnoname's newest firmware.
Also, the used 600 watt server 12 volt PSU is very cheap compared to a 24 volt 600watt PSU.
pipis2014
Images: 105
Postby RacingMat » Sun 8. Mar 2015, 11:36
Great job here! 8-)
Postby javo5 » Wed 8. Apr 2015, 17:01
Hi, great job!! Do you have a video moving under load?
javo5
Postby pipis2014 » Sat 11. Apr 2015, 10:45
I will post one as soon as I can.
pipis2014
Images: 105
Postby pipis2014 » Sat 11. Apr 2015, 10:50
This first clip is just a test with me sitting on the seat.
Its purpose is to demonstrate how quiet the motors are with racingmats ultrasonic code.
ultrasonic pwm test: http://youtu.be/ch_GJ-_nNMc
pipis2014
Images: 105
