Sim Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Re: Blue Sim racing - 2DOF Wiper Motors
Postby kevin123 » Sun 2. Sep 2012, 12:37
UPDATE 01/08/2012
Hello to all
I took some time to work on my sim and I still have much work to do
Work carried out:
Replaced hub central joint (the first was noisy)
Replaced with a racing seat
Added belts OMP racing
Painted the whole structure
Changed the pedals
Replaced gear knob
Added articulated arms for horizontal oscillation
Added aluminum in the structure
Here are some other photos I add them in the main post
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby motiondave » Sun 2. Sep 2012, 13:05
looking real good!
Re: Sim Racing Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Postby kevin123 » Sun 23. Sep 2012, 12:04
Thank you very much David
I have a question to ask
I wanted to add a second monitor to your pc or mobile phone with Android on my steering wheel g for 27 km / h speed rpm and has OBD2 or you just have to use the application?
can you please link a guide
Thanks in advance
kevin123
Images: 132
Postby motiondave » Sun 23. Sep 2012, 15:46
kevin123 wrote:Thank you very much David
Thanks in advance
Dunno about that, I think Sirnoname or Bob can answer that.
I only run 2 screens, one for game and other for x-sim display.
Re: Sim Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Postby Cabrelon » Sat 20. Oct 2012, 12:31
Loved your project. I'm new here. And I do not know anything yet.
How did you do the movements of the roller coaster, Can you teach me?
att
Luiz
Brazil.
Cabrelon
Postby kevin123 » Sat 1. Dec 2012, 12:31
Cabrelon wrote:Loved your project. I'm new here. And I do not know anything yet.
att
Luiz
Brazil.
Hello Cabrelon
Then with x-sim 3 stage 2 you can use the memory driver then activated from the database online at x-sim 3 download the profile for roller coster you have to write in the search NoLimits and then you see the image that I put you and you're done
Best Regards
kevin123
Images: 132
Postby zecaEU01 » Sat 1. Dec 2012, 13:31
Good morning Kevin 123
I'm riding one too here in Brazil and you're parabens by your project and I'm with a doubt.
Seeing vm110n has links to the digital output does not quite understand the connections with 5V GND 08 05 01, the picture is very small, you could help me
thank you
Zeca
zecaEU01
Postby kevin123 » Sat 1. Dec 2012, 15:59
zecaEU01 wrote:Good morning Kevin 123
thank you
Zeca
Good morning to you zecaEU01
If I understand correctly is that you can not see the links because the image is too small? simply click on the image and enlarges
Hello
Kevin
kevin123
Images: 132
Postby zecaEU01 » Sat 1. Dec 2012, 16:26
thank you
Zeca
Hello
Kevin
Sorry Kelvin 123 unfortunately is not working and the image below is what I said from the start We K8055 VM110
zeca
zecaEU01
Postby kevin123 » Sun 2. Dec 2012, 17:11
Hello Zeca
I would like to help you, but you should explain better to understand your problem .... ;)
You say that the image is enlarged and you can not see the links?
or you have connected your cards with the wiring diagram that I put your sim and does not work?
If you can please answer the questions because to translate with google I can not understand I'm sorry but I do not know English
EDIT:Modified wiring diagram I hope you understand better
kevin123
Images: 132
Users browsing this forum: No registered users and 37 guests
