2DOF with Arduino UNO and Monster Moto Shield
Re: 2DOF with Arduino UNO and Monster Moto Shield
Postby RacingMat » Thu 1. Aug 2013, 23:12
Next step : can you describe more what is your test : what are you doing ? :-)
- are you connected with Xsim ? or are you using the Arduino Monitor ? or did you just power the Arduino ?
- is it your first test ? did you make some previous tests that worked before ?
- you are talking about more vibration ... Compare to what (when nobody is sitted ?) in this case what happend ?
Postby soraz » Sat 3. Aug 2013, 20:40
to RacingMat:
thanks for your reply.
i have re-assembled all part that have painted and replaced potentiometers.
the 'vibrations' do not occur.
i see this 'vibrations' when power on arduino, before launch x-sim.
i think the problem was the potentiometers.
best regards
1947
soraz
Images: 67
Been thanked: 7 times
Postby RacingMat » Sat 3. Aug 2013, 22:15
good news !
everything looks nicely fitted ;)
for potentiometer, prefer CERMET (ceramic + metal) track rather than cheap carbon track.
Postby soraz » Mon 12. Aug 2013, 23:13
i have edit main post also modifying converter USO section :
- with the break of : from 33 to 60 ms, with result of smoother motion (copied from racingmat)
soraz
Images: 67
Postby RacingMat » Tue 13. Aug 2013, 06:59
Congratulations Soraz !
you did an excellent handcraft work ... and a beautiful post ! with many videos ;)
it looks easy ! that's a sign it has been well shown and explained !
Mat
PS : can you just link to the Arduino's code (instead of copy/paste) : it would be easier for * if there is only ONE place
for me and for people looking for the last release
Postby zecaEU01 » Wed 18. Sep 2013, 16:41
Congratulations on your project
A doubt as you determine the center of gravity or the distance of the universal joint in relation to accent
hugs
josé
zecaEU01
Postby soraz » Wed 18. Sep 2013, 22:21
for position of seat relative of the joint i have do scientific calculations very complicated..... :lol:
positioned the frame with seat on joint with my son (60kg) and moved back until equilibration.
After this I set the joint on the base and over the frame with the seat.
regards
soraz
Images: 67
Postby soraz » Sat 21. Sep 2013, 00:32
today install a safety switch to break motor power for security reason and power on problem.
2119
soraz
Images: 67
Postby soraz » Mon 23. Sep 2013, 23:32
added dashboard with LKM1638 ver. 1.2, controlled with tha same Arduino Uno R3 of wiper motor.
on bottom of first post, you can see new code and video.
2139
soraz
Images: 67
Postby merchane » Wed 16. Oct 2013, 01:01
Very good job, congratulations and thanks for sharing.
merchane
Images: 9
