Postby Tombo » Sat 2. Nov 2013, 12:43
thanks for info. I have jumpered everything but there is no motor movement. If I run the sample code from pololu and use it as a shield it works but if jumper it there's no function. Did i miss something?
I connected like in the pikture shown here http://www.pololu.com/docs/0J49/4.b
Arduino -> VNH5019
2 -> M1INA
4 -> M1INB
9 -> M1PWM
GND -> GND
5V -> VDD
Tombo
Images: 36
Postby RacingMat » Sat 2. Nov 2013, 16:56
Hello Tombo
If you use my arduino code, I could try to help you :-)
but if you use another code, it is too much work: reading this example code, try it and see what's wrong...
please describe more your first attempt
yours
Mat
Postby Tombo » Sat 2. Nov 2013, 16:59
im using your firmware and like i said i modified pinouts in code and as shield direcktly sticked into arduino is working. But i want to place it next to th arduino in a box so i want to connect it with wires. But if i wire it up like shown in last post it doesm't work. I don't know why so i'm asking if i' missing a wire or something else.
Ps: Great thanks to you and kalarius with your help i got my electronics a big step towards my goal
Tombo
Images: 36
Postby kalarius » Wed 6. Nov 2013, 14:35
TO RacingMat
at you code you have a potmin =208 and pot max=815 values that are the limits of the pots.
I want the limits to be from 22H to EEH because of my pots
do you know the min and max values for this?
Kalarakis
kalarius
Postby RacingMat » Wed 6. Nov 2013, 15:15
@Kalarius: Hello!
I converted your hex values to decimal values here : http://sebastienguillon.com/test/javascript/convertisseur.html
22F -> 559
EEH -> 238
Postby aboodix5 » Thu 7. Nov 2013, 08:36
dear friend
i built my simulator. i use your confg. for covertor and use your code for arduino
so can you help me to set x-convertor and x-extractor
thanks
aboodix5
Postby oomaniacoo » Thu 7. Nov 2013, 12:39
Is it posible to not use 2 computeres ?
I am going to make this seat it looks really nice !
And what are the diemension on the tubes.
do you have futher drawings.
oomaniacoo
Postby kalarius » Thu 7. Nov 2013, 14:26
you can use just one computer
but the cpu must be i7 at 3GHz
with slower the game seems to stack.
It is better to use 2 computers with lower and cheaper profile
for the game I have use I5 anf Gforce 630gt and 8GB ram windows 7 pro
for the motors windows xp home Pentium 4 2Gb ram Video on the board
the lenght is 67cm but it depend on the position of the seat. Place the seat horizontal and mesure the length
kalarius
Postby RacingMat » Thu 7. Nov 2013, 22:41
oomaniacoo wrote:I am going to make this seat it looks really nice !
And what are the dimension on the tubes.
Hi oomaniacoo! Thanks for your appreciation 8-)
Good luck for your project!
Re-read the (long) post, the dimensions are at the end:
tube 30x20x1,5 (1,1 kg/m) 5,4m
tube 16x16x1,5 (0,7 kg/m) 4,1m
Sorry I haven't more drawings: it depends on your size and seat, and wheel!
Postby johnnyfive » Tue 19. Nov 2013, 12:10
Hi.
I've been experiencing some freezes with Arduino code based on yours. When I start Converter, the sim runs fine but after a while it freezes for seconds...Coincidence or not, it usually happens when there's a harsher game movement. Looking at arduino, I'd say that the extractor doesn't stop sending game values (USO: LxxRxx), because the Rx led keeps blinking.
Any clues?
Ever happened to you?
I'll probably set up a network port for USO values for debugging.
Cheers
johnnyfive
Images: 2
