Postby lequibao » Sun 27. Aug 2017, 05:03
First of all, I need to congratulate you for your job, I saw your building process and with other 2 friends I'm building one at my college. I'm writing a post with detailed steps, but check it out: https://goo.gl/photos/8qia2eTiDdv7Ed936
lequibao
Postby stuz » Wed 30. Aug 2017, 03:53
Hi, Im starting to buy my items for my sim but the only thing I can't find where to buy my racing seat from in Australia unless I want to buy a proper one and they are $600+.
Any help please!!!
stuz
Postby Sidy197839 » Mon 5. Feb 2018, 17:12
Olá a todos, parabéns amigo por este post maravilhoso eu seguir sua ideá, porem eu estou usando apenas um computador e não consigo fazer com que o
X SIM encontre minha placa controladora ( Arduino) alguém pode me ajudar???? agradeço
Sidy197839
Postby albertoborges » Mon 12. Feb 2018, 19:47
eu não consigo instalar os 2 pc ,tenho o cabo cruzado mais não sei configurar os dois, tambem não consigo configuara o ardoino no x-sim
albertoborges
Postby sajeerqtr » Wed 7. Mar 2018, 08:46
Dear
please help any one to connect wiper motor to arduino , arduino not detectiong x sim software , how to make work please help us
sajeerqtr
Postby Laurent » Fri 19. Oct 2018, 17:08
salut j ai une question j ai ma carte arduino avec la carte motomonster j ai cablé est mis ton code pour l arduino rien ne fonctionne j ai essayé de bougé les potentiomètre mais rien ne va si éventuellement tu aurais des test a faire pour essayé .
merci d avance
Laurent
Re: Terminado 2DOF 12V DC limpador arduino playseat
Postby fernando » Sat 26. Jan 2019, 20:01
Good afternoon, I'll start putting together the project similar to yours. I'm new to the subject. I have a lot of doubts and I do not know anyone to help me. Thanks, if anyone can give me a support with the programming.
fernando
Postby CooKy » Thu 28. Mar 2019, 23:39
I wish you a nice evening
I have been on the Xsim program for several days *
I have the Converter and Extractor installed.
I played the .ino file on the Arduino.
The motors can be driven via the serial monitor.
Wiring is ok.
In the converter, I have loaded the profile of Kalarius described by page one in the appropriate folder and called in the converter.
Everything is recognized in the output setup under USO. ComPort 3 is accepted.
Axes in the Math Setup have already been created automatically.
  In the interface settings, I can not call this but Arduino and can not control the engines on the program.
How do I make the Arduino connect to the program?
Please help me on the jumps.
Sit there for a few days off.
Nice evening and lovely greetings
Sascha from Germany
CooKy
Postby zapata » Fri 29. Mar 2019, 09:44
CooKy wrote:I wish you a nice evening
Wiring is ok.
Sascha from Germany
Attach USO configuration image and details of the firmware loaded in arduino
zapata
Postby CooKy » Fri 29. Mar 2019, 12:12
Hello zapata
I took screenshots of the USO and Synaptrix.
Is the scetch flsch that he does not show me the axes?
How do I increase the mean of the potentiometer? Partially my engines jerk because they do not find the middle position.
Thank you very much for helping me
EDIT:
If I reload the Sketch on the Arduino and then the converter starts it shows me the error message "does not find an output interface"
Do you have the right sketch for the arduino with a sparkfun motomonster?
sketch.txt
Arduino Sketch
(9.63 KiB) Downloaded 1390 times
USO Screenshot
Synaptrix Screenshot
CooKy
