floriske wrote:Looking good indeed!
Do you have enough clearance on the motor arms so they can make a full rotation? This shouldn't happen in perfect conditions, but while testing it does once in a while.
dearn wrote:floriske wrote:Looking good indeed!
Nope, it will hit the wood. Is it necessary that they can make a rotation? If so, i will need to higher up the motors...
floriske wrote:Another option would be to place the switches between the feedback signal and set up the JRK's to stop on feedback loss, that would solve the JRK reset problem as well. Simply turn your arm back in range and you are good to go again.
motiondave wrote:this would be the simplest option as Bob stated http://www.jaycar.com.au/productView.asp?ID=SP0786 , if something goes haywire, hit button, fix problem, reset switch.
