Postby moj9999 » Wed 25. Feb 2015, 18:19
you are right the authentificated way is good and simple but i had problem with it and it didn't detect my arduino therefor i wrote my program
i think it help my confidence on c#
please help me to improve my knowledge and complete my simulator thank you for response
c#.txt
code
(8.52 KiB) Downloaded 957 times
moj9999
Postby moj9999 » Wed 25. Feb 2015, 18:20
code
c#.txt
(8.52 KiB) Downloaded 908 times
moj9999
Postby RacingMat » Thu 26. Feb 2015, 19:30
moj9999 wrote: it didn't detect my arduino therefor i wrote my program
what is exactly the error message?
what is the reference of your arduino: is it an arduino clone or an original?
as it's not a code problem, it's a settings problem maybe? did you check the windows com port setup? speed?
Postby moj9999 » Thu 26. Feb 2015, 20:15
my program send data to com port correctly and TX led on arduino blinking , I want change my program to work with your arduino program,i want joint these two program together .
i need your knowledge please help me
thanks.
moj9999
Postby RacingMat » Thu 26. Feb 2015, 21:39
We have to find out first why my program did not work previously. Can your answer my questions?
If not, there is no use to merge your program with something that not works :-/
Postby moj9999 » Fri 27. Feb 2015, 10:55
every time i want to joint arduino in interface section it didn't detect my interface , and in your instruction i cant see any thing about this problem!!
we need step by step instruction on X-Sim soft please.
before arduino i follow the AVR board by thanos and my board work correctly and programed successfully but in x-Sim can't be detected!! and in thanos guide video he work with x-Sim version 1.8 and search on internet for that but i didn't see any useful page.
if you can resolve my problem with x-Sim software it's so good.
thanks.
moj9999
Postby moj9999 » Fri 27. Feb 2015, 11:00
sorry your program in arduino !!
in pot test working!! but in software testing with x-Sim ,i don't know because my problem is x-Sim!! that didn't detect my board not your arduino program!
I believe your program working! therefor i said i need your help!!
moj9999
Postby RacingMat » Fri 27. Feb 2015, 20:33
is your arduino a clone or a true arduino? Windows sees it but not Xsim? strange
by the way, my code don't need XPID plugin
Postby moj9999 » Fri 27. Feb 2015, 21:18
my arduino is UNO , and my window detect my board correctly.
what is XPID plugin?
can describe for me what to do on x-sim or how connect my program to your arduino program!
moj9999
Postby RacingMat » Fri 27. Feb 2015, 23:12
XPID is an interface of Xsim often used because it goes along with sirnoname XPID code for arduino ;)
since I have sold my 2DOF, I no longer have a dynamic playseat at the moment: so I cannot help you on seting up Xsim more than what I wrote into the tutorial
but other builders can help you hopefully :)
