Postby RacingMat » Fri 19. Dec 2014, 14:28
Hello
You dont mention the potentiometers...
Can you post pictures of your wiring? I cannot give you any clue with so few information ;-)
Postby moj9999 » Fri 19. Dec 2014, 17:03
hi
i found my mistake and my problem resolved
thank you.
i have x-Sim profiler 2.1 how i work with it ! how it detect my arduino ! and so ..(my game is Microsoft flight simulator x)
thank you.
moj9999
Postby RacingMat » Fri 19. Dec 2014, 18:29
Hi! Good news!
That would be very nice i you could share your mistake :-) this may help someone in the future
Dont be shy :-D
Did you follow the steps of the tutorial?
Arduino setup in windows?
In IDE?
In Xsim?
Postby moj9999 » Fri 19. Dec 2014, 19:05
hi
no where is the tutorial and arduino set up in windows ? i didn't see it !
may board response to the serial monitor and work properly all that's for your help,thank you .
moj9999
Postby moj9999 » Fri 19. Dec 2014, 19:38
i follow your instruction but the arduino didn't response!
i don't know what to do! i become confuse!
please help.
thank you.
i take this picture form my profiler:
http://www.photobox.co.uk/my/photo/full ... 8455328970
moj9999
Postby moj9999 » Sun 21. Dec 2014, 10:01
when i connect motto monster to arduino i think motto monster feedback thru arduino and USB port comes to system and some time my monitor blink!!!
moj9999
Postby impalone » Mon 22. Dec 2014, 12:46
(Sorry for my bad English) Hello I am "impalone," and I'm working on a project with reference to this
good job. But using the same objects, I
to present a problem for me, maybe you can help me with
your experience.
I connected just like you, but in the first test there is some
something that does not work well. The right engine responds well to commands
potentiometer inversion accordance with the instructions of the two
potentiometer (0-5ohm the motor turns to the left and the engine runs 5-10ohm
right), while the left motor does not change direction,
going in one direction and responds to commands from the
potentiometer in one direction, from 0 to 10 Ohm always to the right.
What could be wrong?
- Arduino Uno
- MotoMoster Shield
Thanks in advance.
impalone
Postby moj9999 » Mon 22. Dec 2014, 14:38
hi
in my first potentiometer test i have an error like you ! my right dc motor work good and left didn't response ,i think when one dc motor work properly your job is OK! i check my wiring in A4 and A5 and ground and 5v ,and i detect my error was from wiring.
you must check your wiring on A4,A5,ground and 5v.
i believe you can finish it...
good luck.
moj9999
Postby impalone » Mon 22. Dec 2014, 16:38
Thanks, this evening i will try and test the elettrical circuit.
impalone
Postby impalone » Mon 22. Dec 2014, 21:11
Hello, I corrected my mistake, I was wrong to solder an electrical cable and I created an error between pins that control the direction of the motors. Now everything works well and will continue.
Thank You.
impalone
