FINISHED! - 2DOF Wormgear Race Simulator by Arno
Re: 2DOF Wormgear Race Simulator by Arno - UPDATE P3!
Postby motiondave » Sat 29. Sep 2012, 01:18
Looking good there. I like the seat re-furbish job. You can sew better than me!
Postby floriske » Sat 29. Sep 2012, 14:00
Some great progress you've made arno!
Starting to look really good. Nice work on the seat indeed.
floriske
Images: 96
Postby dearn » Mon 1. Oct 2012, 12:22
Thanks! :)
Past weekend I found the correct place for the pivot. At this moment i'm working on the motors and lever arms, it's difficult to lock the M12 shaft in the hollow axle.
dearn
Images: 139
Postby motiondave » Mon 1. Oct 2012, 14:41
dearn wrote:Thanks! :)
Can you take a photo of what you are doing?
Postby dearn » Tue 2. Oct 2012, 22:11
Tnxs bob for the picture!
@motiondave, i will take some pictures and keep you posted!
Floriske has also given me a few tips recently :)
Today i've buyed for 30 euros bolts and washers again, next update will be coming soon! The pivot is allready in place atm.
dearn
Images: 139
Postby yokoyoko » Tue 2. Oct 2012, 22:19
:shock: How many bolts and washers you bought. Sounds like importing them from germany is interesting :D
Postby dearn » Tue 2. Oct 2012, 22:38
They are all gold plated! :D
Haha no, just kidding. Now I am sure that i will have enough bolts and nuts when its sunday and the local shops are closed ;)
dearn
Images: 139
Postby floriske » Tue 2. Oct 2012, 22:51
One can't have enough nuts and bolts indeed :D
Regarding the 12mm shaft: At this moment I'm just using a long m12 bolt tightened very firmly (so no pin yet) and all stays nicely in its place so far. I've made m12 tread in my arm to make shure it can't turn easilly. (as mentioned in my pm)
floriske
Images: 96
Postby motiondave » Wed 3. Oct 2012, 00:02
Same here, I got a 12mm bolt that has been tightened the @#$% out of and it holds.
Re: 2DOF Wormgear Race Simulator by Arno - UPDATE P4!
Postby dearn » Tue 9. Oct 2012, 20:44
Small update :!:
I haven't found a lot of time for my sim past week(s). The motors are ready to mount at this point, but i still need to make some levers for the potentiometers.
PICS :D
M10 rod-ends and I made some small steel levers on the M12 shaft:
364365
Differs approximately 10 cm in height, must be enough...
366
Big gamble... about here :lol:
367
Bolted on the 18mm birchwood with some M8 bolts.
368 369
I still need to cut the bolts to correct size, but for now its good enough.
Grtz,
Arno
dearn
Images: 139
