Postby Monaco85 » Tue 18. Mar 2014, 23:13
Thanks for your settings.with my logitech momo everything works fine. Crazy :)
Monaco85
Postby RacingMat » Wed 19. Mar 2014, 14:10
@Kalarius: you did a very good job! It seems that Monaco85 is happy with his sim! :D
Postby Monaco85 » Wed 19. Mar 2014, 15:41
You all guys are the Best.
Monaco85
Postby Monaco85 » Thu 20. Mar 2014, 21:12
@Kalarius Your Settings a perfekt. I freaked out in my seat :-)
But Sometimes my power suply unit goes off.
Is it to much power for it?
Monaco85
Postby kalarius » Fri 21. Mar 2014, 09:55
if your power supply is goes off then you want a bigger one
I have 12V/16A X2 for the motors
kalarius
Postby Monaco85 » Fri 21. Mar 2014, 12:39
I have same as matracing. Dps 600pb 12v 47A.
I will test with 24v. Then the current should be the half.
I hope my pololu will survive :) :)
Monaco85
Postby RacingMat » Fri 21. Mar 2014, 21:14
Yes, check the Pololu specs first!
You can lower a bit PwmMax.
Or a car battery would prevent any pb also.
With my nephews sometimes is happended because they were too light : i guess that the seat goes too far...
Postby Monaco85 » Sat 22. Mar 2014, 12:21
Thank u Mat.
I lowered the PWM from 255 to 245. Then it works.
But i wanted to know whats going on with 24V.
The Wiper are a litte bit stronger. But not as i thought. If your seat is very heavie you maybe have to Change from 12V to 24 V but not for movement.
Monaco85
Postby seanbig » Mon 28. Apr 2014, 16:41
Hi, racingMat,
you are awesome for sharing this good work. please pardon my english coz i am com from Taiwan. You got a fan in asia *
Recently i am building my own sim based on your idea, but the valeo motors are difficult to find in Taiwan. Could you teach me how to choose motors here, can i use 12v wiper motors from japan car(toyota altis) or how many torque that ok to me, i am 170bls/80kg weight. thanks for your reply in advance.
Sean
seanbig
Postby RacingMat » Mon 28. Apr 2014, 16:50
Hi Seanbig! Welcome!
As I don't know your japanese wiper motors, I can tell you:
- choose the biggest you can find (monospace, bus...), that would fit!
- if you can, choose a 12V motor, it's simplier to find PowerSupplyUnit and Hbridge
Yours
Mat
