Kart Racing Pro
Kart Racing Pro
Postby prodigy » Sun 24. Mar 2013, 19:01
There was an update recently for Kart Racing Pro, I see that an plugin exist in X-Sim, but it seems that it doesn't work.
When I add the game and press play in Extractor the game starts, START button turns red in Converter but I get no data in the game. I have allowed kart.exe through firewall, so nothing is blocked.
Is there maybe any call parameter for .exe to enable motion in-game?
This is latest update
http://kartracing-pro.com/?page=news
I see here on KRP forum that discussion was made, but I can't understand if plugin is working with X-Sim or not
http://forum.kartracing-pro.com/index.p ... opic=194.0
Re: Kart Racing Pro
Postby sirnoname » Mon 25. Mar 2013, 02:26
->Bug tracker
Re: Kart Racing Pro
Postby abs2 » Thu 26. Sep 2013, 06:22
i experience the exact same problem. there is a slight jolt and then nothing , no communication. I run both plugins in the righ directories and beta 9 version of kart racing pro.
any news Sirnoname on this?
abs2
Re: Kart Racing Pro
Postby prodigy » Thu 26. Sep 2013, 08:27
Few months ago we have made this work, you should have "cartplugin.dlo" and "telemetry.dlo" in you KartPro/plugins folder.
We had discussion in Bugtracker before but I can't see it anymore. I don't know if Sirnoname included updated cartplugin.dlo file in new versions of X-Sim. Before it was called cartplugin.dll, but we had to change it to .dlo to make it work.
Re: Kart Racing Pro
Postby abs2 » Thu 26. Sep 2013, 14:25
hello, i downloaded the lastversion of x-sim in another computer to nor mess with may current installation. I see only one file (dll) in the other stuff/kartracingpro folder . I dont see any telemetry file .
i believe i am missing that telemety file to make it work. since i can (i pressume) change dll to dlo by renaming the extentions ?
Could you make available those files for download ?
thanks for the quick response
abs2
Re: Kart Racing Pro
Postby prodigy » Thu 26. Sep 2013, 15:05
Put this two files from *.zip file in attachment in your KartPro/plugins folder and try.
In Extractor under MotionDriver for KartPro choose KartRacing plugin.
I have b8 version of the game, I don't know if the game was updated since I didn't use it or months.
But if they didn't change anyhing to telemetry output, this should work.
http://i.imgur.com/EuCYKaj.jpg
kr_pro_plugins.zip
(74.11 KiB) Downloaded 2981 times
Re: Kart Racing Pro
Postby sirnoname » Thu 26. Sep 2013, 22:04
Game Wizard -> scan with setup -> cart racing pro is detected and plugins are installed.
Why a manual setup?
Re: Kart Racing Pro
Postby abs2 » Thu 26. Sep 2013, 23:16
the game is detected via the wizard . the plugin also
however , i hit the play button
the start remains green
when i press the start the connection "seems" to be made
however no motion is happening
I returned to the dll plugin that is inxsim/plugin folder
i copied the dll plgin that is the xsim/otherstuff/kartracing folder to programfile/katracing/plugin folder
is there somethjing missing ?
abs2
Re: Kart Racing Pro
Postby prodigy » Fri 27. Sep 2013, 03:33
Plugin in the kartgame/plugins folder should be renamed cartplugin.dlo, not .dll.
Have you tried copying files from my previous post?
Re: Kart Racing Pro
Postby abs2 » Fri 27. Sep 2013, 06:18
Hello
thanks for the files
renaming the file ins xsim/otherstuff/kartracepro/kartplugin.dll to dlo does not work (that dll as is does not work either)
but using the kartplugin.dlo you provided did the trick
so now i have motion
(these are according my back and forth long testings so all this should be reconfirmed)
Ok then thanks a lot
abs2
